Some of you can link me a guide on how to make domoticz switch the sonoff relay? I followed many how to on this forum but I can't make this work. I installed espeasy on my sonoff. Thanks so much for your help, I'm sorry for posting this again
Sonoff
marcotrumpet
Sonoff
Hi all.
mKotek
Re: Sonoff
If you have installed ESPEasy on Sonoff, take a look at: https://www.letscontrolit.com/wiki/index.php/Relais
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
marcotrumpet
Re: Sonoff
Mmm ... I’m a bit confused. How con I know the pin? I want to connect a light bulb to the sonoff and then turn on/off the light from domoticz and the physical wall switch.
EDIT
I think I can't use sonoff to switch my bulb on/off both from domoticz and wall switch.. some of you know a way to do this?
Inviato dal mio iPad utilizzando Tapatalk
EDIT
mKotek
Re: Sonoff
With Sonoff, the button is attached to GPIO 0 and the relay to GPIO 12. You can also have GPIO 14 available if you soldier all 5 pins on the board. The one on the most left is GPIO 14.
As for the switching, you need to use rules - take a look at the forum for ESP Easy, we have discussed that there.
marcotrumpet
Re: Sonoff
Ok so I need to solder the in wall switch to the button on sonoff great! I'm surfing the esp easy forum, if you have some usefull link I appreciate
Inviato dal mio SM-G950F utilizzando Tapatalk
stephenmhall
Re: Sonoff
if I were you I would switch to the Sonoff-Tasmota firmware, really does just work out of the box.
You do need a MQTT server, I have mosquitto running on my Synology alongside Domoticz.
Flash the firmware, access the device web page on a tablet or phone, config the type of sonoff switch and your domoticz details including the idx of the virtual switch you are linking it to and bang it works.
https://github.com/arendst/Sonoff-Tasmota
marcotrumpet
Re: Sonoff
Thank you everybody.. I used espeasy and soldered wires from gpio0 button to my wall switch
marcotrumpet
Re: Sonoff
Can you tell me ehy to lrefere tasmota instead espeasy?stephenmhall wrote:if I were you I would switch to the Sonoff-Tasmota firmware, really does just work out of the box.
