After installing the plugin you get a few switches: (beacuse the colorpicker won't work within python) One for each color (red/green/blue/(warm)white), A global on/off switch and a auto option. This will turn on/off the light and changes color at a random interval. Made this beacuse I am lazy
Settings: For connection and for the automatic light option.
The automatic light option switches on based on the current sunset times. I am not able to retrieve them directly from Domoticz so I used a JSON call. To make this work you must update the domoticz username/password in the plugin.py
Source (with images) can be found here: https://github.com/ericstaal/domoticz/t ... in/ledenet
