Dashticz - Function - Trigger action on specific value
jake
Re: Dashticz - [BETA] - Function - Do something at a specific value
Post by jake »
htilburgs wrote: Thnx... And updated the wiki too....
I would like to propose a litte change in the Wiki regarding the change of color, based on value xyz:
- Start with the paragraph about finding the right variable for monitoring, so before explaining what to add to custom.js (common practice for manuals, since people try to follow the manual line by line and won't recognize the next paragraph while they get stuck in the paragraph before)
- Don't use the example json command for all devices, but start with the one for the specific device, since that is what the user is after in the first place:
/json.htm?type=devices&rid=IDX
and point for all other json command to the Domoticz wiki: http://www.domoticz.com/wiki/Domoticz_A ... rtain_type
mvveelen
Post by mvveelen »
htilburgs wrote:
I also noticed a minor in .trashcan. After height the : is missing. (I know, I'm a nitpicker ;-))
Hahaha, added the : after height :D
htilburgs
Post by htilburgs »
I understand what you mean. Take a look at it tomorow...
Hardware:
htilburgs
Post by htilburgs »
Finaly found some time and changed the Wiki. Thanks for your possitive reply.
Btw, when you've an account, you can edit the wiki yourself....;-)
Hardware:
EdwinK
Re: Dashticz - Function - Trigger action on specific value
Post by EdwinK »
Why wouldn't this work?
// temp
function getStatus_176(idx,value,device){
   if(parseFloat(device['Data'])>20){
      $('div.block_176').removeClass('warning').addClass('warningorange');
   else if(parseFloat(device['Data'])>23){
      $('div.block_176').removeClass('warningorange').addClass('warning');
   else {
      $('div.block_176').removeClass('warning').removeClass('warningorange');
mvveelen
Post by mvveelen »
EdKo66 wrote:Why wouldn't this work?
// temp
   else {
Change Data to Temp :)
EdwinK
Post by EdwinK »
Of course... Thanks ;)
gielie
Domoticz version: latest β
Post by gielie »
I have tried this one, but it doesnt work, can someone tell me why and give me a solution.
// temp
function getStatus_304(idx,value,device){
   if(parseFloat(device['Temp'])>20){
      $('div.block_304').removeClass('warningred').removeClass('warningorange').addClass('warning');
   else if(parseFloat(device['Temp'])>22){
      $('div.block_304').removeClass('warning').removeClass('warningred').addClass('warningorange');
   else if(parseFloat(device['Temp'])>24){
      $('div.block_304').removeClass('warningorange').removeClass('warning').addClass('warningred');
   else {
      $('div.block_304').removeClass('warning').removeClass('warningorange').removeClass('warningred');
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
htilburgs
Post by htilburgs »
gielie wrote:I have tried this one, but it doesnt work, can someone tell me why and give me a solution.
// temp
   else {
I think there are two errors:
- the device['Temp'] and should be device['Data']
- Start with the highest and work down to the lowest temperature
   if(parseFloat(device['Data'])>24){
      $('div.block_304').removeClass('warning').removeClass('warningorange').addClass('warningred');
   else if(parseFloat(device['Data'])>22){
   else if(parseFloat(device['Data'])>20){
      $('div.block_304').removeClass('warningorange').removeClass('warningred').addClass('warning');
   else {
Hardware:
EdwinK
Post by EdwinK »
Don't know why it wouldn't work for you. You did put it in custom.js?
I have the problem because it is a sensor with a '_1' in it.
Mmm. Yesterday I was told to change it from 'Data' to 'Temp'.
Even rain isn't flashing anymore :(
htilburgs
Post by htilburgs »
EdKo66 wrote:Don't know why it wouldn't work for you. You did put it in custom.js?
That can be, but it's not right...;-)
When you check your device with http://domoticz_url:port/json.htm?type=devices&rid=304, you wil see there is no parameter Temp. What you find is Data. So it should be Data. :idea:
Furthermore, you started with the lowest values. In that case the formule won't work. Work down from high to low.
Example in you're case when it is 22,5 degree the warningorange AND warningred are true. Which one should be picked?? :?:
Hardware:
EdwinK
Post by EdwinK »
but... there is a Temp parameter. Are so I think.
"result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 100,
         "CustomImage" : 0,
         "Data" : "18.1 C, 0 %",
         "Description" : "",
         "DewPoint" : "18.10",
         "Favorite" : 1,
         "HardwareID" : 13,
         "HardwareName" : "RFXcom",
         "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
         "HardwareTypeVal" : 1,
         "HaveTimeout" : false,
         "Humidity" : 0,
         "HumidityStatus" : "Dry",
         "ID" : "1001",
         "LastUpdate" : "2017-06-09 13:10:33",
         "Name" : "Buiten temp",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : 6,
         "SubType" : "Rubicson/IW008T/TX95",
[b]         "Temp" : 18.100000000000001,
[/b]
htilburgs
Post by htilburgs »
Ok, that differs from mine. Use this code in config.js and it should work.
   else if(parseFloat(device['Temp])>20){
   else {
Hardware:
EdwinK
Post by EdwinK »
Put this in, but for now it will not be working because of the multi-sensor thing even if the humidity doesn't really work
EdwinK
Post by EdwinK »
htilburgs wrote:Ok, that differs from mine. Use this code in config.js and it should work.
Shouldn't it be in custom.js?
htilburgs
Post by htilburgs »
Sorry, it should be config.js. My mistake...
Hardware:
EdwinK
Post by EdwinK »
*flashing buttoons*
*flashing buttoons*
Screen Shot 2017-06-09 at 14.03.31.png (108.15 KiB) Viewed 4249 times
Yes... It works. Had fixed a little typo (You forgot the closing ' ).
htilburgs
Post by htilburgs »
Ok, happy and sorry.... Probably a Cut & Paste error.
Nice to hear it works!!
Hardware:
gielie
Post by gielie »
Yes the code works, tanks. And like Ed told, the last Temp misses a '
- FIBARO FGS223
- Toon
- Kodi Media Server
lukev
Post by lukev »
Any method to extract temp from tem/hum sensor?
My data reads this:
Data	"27.8 C, 47 %"
so the tigger doesn't work...
