RFLink and Synology problems/challenges
433Mhz opensource Receiver & Transmitter.
veteiks
Domoticz version: 3.5877
Re: RFLink and Synology problems/challenges
Post by veteiks »
hi, i have CH340 (this set https://www.nodo-shop.nl/nl/rflink-gate ... tenne.html), but with or without modification is same state..
Synology DS216play, RFlink -> NODO, Domoticz -> jadahl.com
jumbotroll
Post by jumbotroll »
Stuntteam wrote:Do you have an Arduino with CH340 or Atmega serial chip?
The Ch340 does not need the anti reset modification..
Log in to you NAS with ssh or Telnet and type: dmesg
you should have some output on ch341 like this:
[ 120.600809] usbcore: registered new interface driver usbserial
[ 121.050817] usbcore: registered new interface driver ch341
[ 121.056450] usbserial: USB Serial support registered for ch341-uart
[ 121.062865] ch341 6-2:1.0: ch341-uart converter detected
[ 121.083617] usb 6-2: ch341-uart converter now attached to ttyUSB0
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
veteiks
Post by veteiks »
hi, this is from ssh synology
[ 67.866220] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 68.198774] usbcore: registered new interface driver ch341
[ 68.204354] usbserial: USB Serial support registered for ch341-uart
[ 68.210778] ch341 2-1:1.0: ch341-uart converter detected
[ 68.239893] usb 2-1: ch341-uart converter now attached to ttyUSB0
this is "full" of usb part..
[ 67.814734] usbcore: registered new interface driver usbserial
[ 67.860378] usbcore: registered new interface driver ftdi_sio
[ 68.038073] usbcore: registered new interface driver cp210x
[ 68.043739] usbserial: USB Serial support registered for cp210x
[ 68.146980] usbcore: registered new interface driver pl2303
[ 68.152684] usbserial: USB Serial support registered for pl2303
[ 68.304752] usbcore: registered new interface driver ti_usb_3410_5052
[ 68.311299] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
[ 68.319089] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
[ 69.449213] usbcore: registered new interface driver snd-usb-audio
[ 69.773979] usbcore: registered new interface driver snd-usb-hiface
jumbotroll
@veteiks
Yes, but I was interested in the:
and i the drivers seems to be ok.
Have you tested the RFLink on a another device?
Did you program the RFLink on a windows pc and confirmed that the software is in place?
Jumbotroll
veteiks
Post by veteiks »
jumbotroll wrote:@veteiks
i uploaded firmware to rflink with windows pc via rflink loader, after upload i turn on serial port logging:
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R45;
20;01;MiLight=OFF;NO NRF24L01;
10;version;
20;02;VER=1.1;REV=45;BUILD=09;
10;status;
20;03;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=ON;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
jumbotroll
@veteiks
I have not tested my synology with serial port logging, but you can always test to disable serial port logging and see if that helps.
Jumbotroll
Stuntteam
Post by Stuntteam »
When you activate serial port logging in RFLink Loader it is only active until the next reboot.
veteiks
Post by veteiks »
hi, all is ok now, i found wrong soldered components on rflink mainboard, but i found defect :-)
here is log from synology:
2017-02-08 17:28:29.905 RFLink: Using serial port: /dev/ttyUSB0
2017-02-08 17:28:30.754 RFLink: Controller Initialized!...
2017-02-08 17:28:30.829 RFLink Detected, Version: 1.1 Revision: 45 Build: 9
thank you for support;-)
Cyberwizzard
Post by Cyberwizzard »
I'm having issues with the RFLink board as well - where do I enable serial logging and how can I see the serial communications?
Cyberwizzard
I figured out I also have problems with /usr/syno/sbin/synousbmodemd
Domoticz first opens the serial port and then synousbmodemd seems to claim it - I now manually kill the process every reboot but how do I disable it?
peterkps
Post by peterkps »
Last week i bought an "RFLink - all in one package" for the Synology DS216 at nodo-shop.nl.
However, problems with operating the KAKU devices. Regular timeout notifications.
This package included an original (Made in Italy) Arduino Mega with amtel serial chip. Now I replaced these with an aliexpress cloon with a CH340 serial chip and did not see the error message anymore.
It seems like that amtelchip i.c.m. The Synology is not going well.
Sinds afgelopen week in het bezit van een "RFLink - alles in een pakket" voor de Synology DS216. Gekocht bij nods-shop.nl.
Echter problemen met het bedienen van de KAKU devices. Regelmatig timeout meldingen.
Bij dit pakket zat een originele (Made in Italy) Arduino Mega met amtel seriele chip. Nu heb ik deze vervangen door een aliexpress-cloon met een CH340 seriele chip en heb de foutmelding niet meer gezien.
Het lijkt er toch op dat die amtelchip i.c.m. de Synology niet lekker gaat.
sincze
Domoticz version: 2024.4
Post by sincze »
Issue at my parents house DS211 DSM 5.2 (so no more Jadahl updates unfortunately).
This Synology and Domoticz Stable have been running for over a year without problems.
SInce last 2 weeks... Lights did not turn on. Restarted Synology and Domoticz package (both).
2018-08-23 08:39:06.000 Error: RFLink: TX time out...
2018-08-23 08:39:06.000 Error: Error sending switch command, DevID: 38, Time: 2018-08-23 08:39:01
The Arduino mega has a CH340.
[  149.220000] USB Serial support registered for ch341-uart
[  149.230000] ch341 1-1.3:1.0: ch341-uart converter detected
[  149.430000] usb 1-1.3: ch341-uart converter now attached to ttyUSB0
[  149.440000] usbcore: registered new interface driver ch341
If I just go to settings hardware.. select rflink (v46) and press update it will run for a while.
2018-08-23 19:58:49.081 RFLink: Serial Worker stopped...
2018-08-23 19:58:49.543 RFLink: Using serial port: /dev/ttyUSB0
2018-08-23 19:58:50.419 RFLink: Controller Initialized!...
2018-08-23 19:58:50.499 RFLink Detected, Version: 1.1 Revision: 46 Build: 0
2018-08-23 20:04:04.406 RFLink: 20;08;PONG;
2018-08-23 20:04:56.907 RFLink: 20;09;PONG;
But will stop eventually with the same time-outs. What did I miss??
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
