Luxtronic Heatpump controller
BobbyNL
I'm using a alpha innotec heatpump in my house. I can read and control it by connecting with a webbrowser at http://192.168.0.125:8889
Would it be possible to add this as hardware in domoticz? Or use json to read/write some values?
found this: https://github.com/pfandfrei/luxtronik2
Rpi-Domoticz +RFXtrx433E | Rpi-Openelec | Rpi-Runeaudio | unRaid 6 server | Intel NUC-Linux Tvheadend + Oscam
poostrom
- Domoticz version: Latest
Re: Luxtronic Heatpump controller
Hi Bobby,
Did some stealing of code and managed to read values from a Luxtronik 2.0 in python.
It's very beta, but works for me though. Able to create a dummy sensor for kWh's and put the values with json to domoticz.... I only did the kWh, working on other things, just testing this now....
For the record in the json IDX 191 is my virtual sensor for kWh's.... You might want to comment this out first, first see if there's any output. There should be output like this:
Temperatuur buiten : 8.3
Temperatuur voorloop : 21.5
Temperatuur naloop : 21.5
Rucklauf Soll : 21.7
WQ Eingangstemp : 24.9
WA Ausgangstemp : 26.0
Betriebszeit Verdichter 1 : 314 days, 7:53:36
Impulse VD1 : 3863
Betriebsstunden WP : 314 days, 7:53:35
Betriebsstunden Heizung : 222 days, 21:58:30
Verbruik verwaming (kWh) : 48323.1
Verbruik heet water (kWh) : 8061.3
Betriebsstunden WW Erzeugung : 91 days, 9:55:05
Status Zeile 1 (code) : 1
Status Zeile 2 (code) : 0
Status Zeile 3 (code) : 1
Status seit : 5:14:26
WMZ Durchfluss l/h : 0.0
Below the python code:
#!/usr/bin/python
import socket
import struct
import datetime
import httplib
# Luxtronik 2.0 IP
hostHeatpump = '192.168.200.107'
# Luxtronik 2.0 port (standard 8888)
portHeatpump = 8888
s = socket.socket( socket.AF_INET, socket.SOCK_STREAM)
s.connect( (hostHeatpump, portHeatpump))
s.send( struct.pack( '!i', 3004))
s.send( struct.pack( '!i', 0))
if struct.unpack( '!i', s.recv(4))[0] != 3004:
print 'Error: REQ_CALCULATED CMD'
exit()
stat = struct.unpack( '!i', s.recv(4))[0]
len = struct.unpack( '!i', s.recv(4))[0]
array_calculated = []
for i in xrange(len):
array_calculated.append(struct.unpack( '!i', s.recv(4))[0])
print 'Calculated'
print stat
print len
print array_calculated
print '\n\n'
print "Temperatuur buiten : ", (str(float(array_calculated[15])/10))
print "Temperatuur voorloop : ", (str(float(array_calculated[10])/10))
print "Temperatuur naloop : ", (str(float(array_calculated[11])/10))
print "Rucklauf Soll : ", (str(float(array_calculated[12])/10))
print "WQ Eingangstemp : ", (str(float(array_calculated[19])/10))
print "WA Ausgangstemp : ", (str(float(array_calculated[20])/10))
print "Betriebszeit Verdichter 1 : ", (str(datetime.timedelta(seconds=int(array_calculated[56]))))
print "Impulse VD1 : ", (str(array_calculated[57]))
print "Betriebsstunden WP : ", (str(datetime.timedelta(seconds=int(array_calculated[63]))))
print "Betriebsstunden Heizung : ", (str(datetime.timedelta(seconds=int(array_calculated[64]))))
print "Verbruik verwaming (kWh) : ", (str(float(array_calculated[151])/10))
print "Verbruik heet water (kWh) : ", (str(float(array_calculated[152])/10))
print "Betriebsstunden WW Erzeugung : ", (str(datetime.timedelta(seconds=int(array_calculated[65]))))
print "Status Zeile 1 (code) : ", (str(array_calculated[117]))
print "Status Zeile 2 (code) : ", (str(array_calculated[118]))
print "Status Zeile 3 (code) : ", (str(array_calculated[119]))
print "Status seit : ", (str(datetime.timedelta(seconds=int(array_calculated[120]))))
print "WMZ Durchfluss l/h : ", (str(float(array_calculated[155])))
conn = httplib.HTTPConnection("192.168.200.15:8080")
conn.request("HEAD","/json.htm?type=command¶m=udevice&idx=191&svalue=" + (str(float(array_calculated[151])*100)))
# res = conn.getresponse()
#print res.status, res.reason
s.close()
Impulse VD1 : 3863
#!/usr/bin/python
import socket
import struct
import datetime
import httplib
# Luxtronik 2.0 IP
portHeatpump = 8888
exit()
print 'Calculated'
print stat
print len
print '\n\n'
s.close()
tweakertje
- Target OS: -
Is there any progress on the alpha innotec luxtronic pump
Im using it for 6 months now and I love to get it in domotics
Fluxtronic in the playstore is a nice program to change temps and read values but an automation would be nice
Verstuurd vanaf mijn SM-G930F met Tapatalk
Aandegrens
- Domoticz version: 2020.2
I am also curious whether there is progress in this project.
Is there someone how could explain how to use/install the Python code?
tweakertje
- Target OS: -
I'm trying now to get the script working but i'll get
File "luxtronic.py", line 24
IndentationError: expected an indented block
What am i doing wrong Python 2.7.12
Aandegrens
I've got it working for the printing part of the data
When you make a new script file, change permissions so you are able to execute it.
I'm using Python 3.4 and had to change some coding.
The script:
#!/usr/bin/python
import socket
import struct
import datetime
#import httplib # This is not working yet and gives an error
# Luxtronik 2.0 IP
hostHeatpump = '192.168.1.12'
portHeatpump = 8888
print("Error: REQ_CALCULATED CMD")
#exit() #Removed this because it give an error but have to look in to this.
for i in range(len):
print("Calculated")
print(stat)
print(len)
print(array_calculated)
print("\n\n")
print("Temperatuur buiten : ", (str(float(array_calculated[15])/10)))
print("Temperatuur voorloop : ", (str(float(array_calculated[10])/10)))
print("Temperatuur naloop : ", (str(float(array_calculated[11])/10)))
print("Rucklauf Soll : ", (str(float(array_calculated[12])/10)))
print("WQ Eingangstemp : ", (str(float(array_calculated[19])/10)))
print("WA Ausgangstemp : ", (str(float(array_calculated[20])/10)))
print("Betriebszeit Verdichter 1 : ", (str(datetime.timedelta(seconds=int(array_calculated[56])))))
print("Impulse VD1 : ", (str(array_calculated[57])))
print("Betriebsstunden WP : ", (str(datetime.timedelta(seconds=int(array_calculated[63])))))
print("Betriebsstunden Heizung : ", (str(datetime.timedelta(seconds=int(array_calculated[64])))))
print("Verbruik verwaming (kWh) : ", (str(float(array_calculated[151])/10)))
print("Verbruik heet water (kWh) : ", (str(float(array_calculated[152])/10)))
print("Betriebsstunden WW Erzeugung : ", (str(datetime.timedelta(seconds=int(array_calculated[65])))))
print("Status Zeile 1 (code) : ", (str(array_calculated[117])))
print("Status Zeile 2 (code) : ", (str(array_calculated[118])))
print("Status Zeile 3 (code) : ", (str(array_calculated[119])))
print("Status seit : ", (str(datetime.timedelta(seconds=int(array_calculated[120])))))
print("WMZ Durchfluss l/h : ", (str(float(array_calculated[155]))))
#Haven't got this below running yet.
#conn = httplib.HTTPConnection("192.168.1.5:8080")
#conn.request("HEAD","/json.htm?type=command¶m=udevice&idx=191&svalue=" + (str(float(array_calculated[151])*100)))
s.close()
The command to run the script:
pi@raspberrypi:~ $ sudo /home/pi/domoticz/scripts/WP.py
The output results looks like this:
Calculated
1
183
[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 540, 402, 279, 329, 741, 75, 101, 481, 475, 98, 87, 750, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 1, 0, 1, 0, 0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 24306508, 24307, 0, 0, 31, 0, 0, 24306508, 18093265, 6208256, 0, 0, 0, 0, 0, 168, 0, 132, 0, 99, 0, 0, 11, 1, 5, 86, 49, 46, 54, 49, 0, 0, 0, 0, 0, -1062731508, -256, -1062731265, -1062731266, 1478479227, 1478341711, 1478093318, 1477767105, 1477387553, 715, 715, 715, 715, 715, 5, 9, 9, 9, 0, 9, 1493951602, 1493954767, 1493957919, 1493962391, 1493948480, 0, 1, 0, 1, 132, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 0, 0, 0, 1493962522, 1, 0, 0, 0, 0, 0, 0, 0, 0, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
('Temperatuur buiten : ', '7.5')
('Temperatuur voorloop : ', '54.0')
('Temperatuur naloop : ', '40.2')
('Rucklauf Soll : ', '27.9')
('WQ Eingangstemp : ', '9.8')
('WA Ausgangstemp : ', '8.7')
('Betriebszeit Verdichter 1 : ', '281 days, 7:48:28')
('Impulse VD1 : ', '24307')
('Betriebsstunden WP : ', '281 days, 7:48:28')
('Betriebsstunden Heizung : ', '209 days, 9:54:25')
('Verbruik verwaming (kWh) : ', '0.0')
('Verbruik heet water (kWh) : ', '0.0')
('Betriebsstunden WW Erzeugung : ', '71 days, 20:30:56')
('Status Zeile 1 (code) : ', '1')
('Status Zeile 2 (code) : ', '0')
('Status Zeile 3 (code) : ', '1')
('Status seit : ', '0:02:12')
('WMZ Durchfluss l/h : ', '0.0')
The script:
#!/usr/bin/python
import socket
import struct
import datetime
# Luxtronik 2.0 IP
portHeatpump = 8888
print("Calculated")
print(stat)
print(len)
print("\n\n")
s.close()
Calculated
1
183
- Westcott
Hi Aandegrens,
I use the 'requests' lib to send data to, and get data from, Domoticz.
Each request runs in its own thread.
Here's a snippette-
Here's a snippette-
import threading
import requests
URL_DOMOTICZ = 'http://localhost:8080/json.htm?type='
def DomoticzData(cmd, get=False):
try:
url = URL_DOMOTICZ + cmd
response = requests.get(url)
if response.ok:
jsonData = response.json()
if get == True:
return jsonData
elif jsonData["status"] != "OK":
Log("Status " + jsonData["status"] + " for " + cmd)
else:
print("GET failed with " + str(response.status_code))
except(requests.ConnectionError, e):
Log('Request Failed %s - %s' % (e, url) )
def UpdateDevice(idx, val):
data = 'command¶m=udevice&idx=PARAM_IDX&svalue=PARAM_CMD'
data = data.replace('PARAM_IDX', idx)
data = data.replace('PARAM_CMD', str(val))
threadReqHome = threading.Thread(target=DomoticzData, args=(data,))
threadReqHome.start()
tweakertje
- Target OS: -
hi all
I've got it working
the scripts keeps running and updates every 30 seconds
the first sleep is 90 seconds so you can make an cron for start @boot
# !/usr/bin/python
import socket
import struct
import datetime
import httplib
# Luxtronik 2.0 IP
hostHeatpump = '192.168.1.5'
portHeatpump = 8888
import time
time.sleep(90)
while 1==1:
if struct.unpack( '!i', s.recv(4))[0] != 3004:print 'Error: REQ_CALCULATED CMD'
#exit()
for i in xrange(len):array_calculated.append(struct.unpack( '!i', s.recv(4))[0])
print 'Calculated'
print stat
print len
print '\n\n'
print "Temp boiler : ", (str(float(array_calculated[17])/10))
print "Tapwater Ingesteld : ", (str(float(array_calculated[18])/10))
print "Temperatuur Retour Berekend : ", (str(float(array_calculated[12])/10))
print "Temperatuur Bron In : ", (str(float(array_calculated[19])/10))
print "Temperatuur Zuiggasleiding Comp. : ", (str(float(array_calculated[176])/10))
print "Compressor 1 inschakelpulsen : ", (str(array_calculated[57]))
print "Bedrijfsuren WP : ", (str(datetime.timedelta(seconds=int(array_calculated[63]))))
print "Bedrijfsuren Verwarmen : ", (str(datetime.timedelta(seconds=int(array_calculated[64]))))
print "Bedrijfsuren WW : ", (str(datetime.timedelta(seconds=int(array_calculated[65]))))
conn = httplib.HTTPConnection("192.168.1.10:8084")
# conn.request("HEAD","/json.htm?type=command¶m=udevice&idx=141&svalue=" + (str(float(array_calculated[151])*100)))
conn.request("HEAD","/json.htm?type=command¶m=udevice&idx=142&svalue=" + (str(float(array_calculated[17])/10)))
conn.request("HEAD","/json.htm?type=command¶m=udevice&idx=143&svalue=" + (str(float(array_calculated[15])/10)))
# print res.status, res.reason
time.sleep(30)
s.close()
I've got it working
# !/usr/bin/python
import socket
import struct
import datetime
import httplib
# Luxtronik 2.0 IP
portHeatpump = 8888
import time
time.sleep(90)
while 1==1:
#exit()
print 'Calculated'
print stat
print len
print '\n\n'
time.sleep(30)
s.close()
Aandegrens
I can't get it working to write the data from Python to Domoticz.
When I enter contents of the strings strDomoticz+strJson directly in the browser the value in Domoticz is changed.
192.168.1.5:8080/json.htm?type=command¶m=udevice&idx=82&svalue=16.5
So I'm guessing the strings are correct.
Because i'm using Python 3.4.2 i had to change httplib to http.client
I'm not getting error messages in Python itself but this is what the last printcommand returns:
Status: 401 Reason: Unauthorized
What's going wrong, anyone?
strDomoticz = '192.168.1.5:8080'
strJson='/json.htm?type=command¶m=udevice&idx='+str(idxTempBuiten)+'&svalue='+TempBuiten
print(strDomoticz+strJson)
conn = http.client.HTTPConnection(strDomoticz)
conn.request("HEAD",strJson)
print('Status: '+str(res.status)+' Reason: '+str(res.reason))192.168.1.5:8080/json.htm?type=command¶m=udevice&idx=82&svalue=16.5
- Westcott
You could try using the 'requests' library instead.
Here's an incomplete fragment -
import requests
url = 'http://localhost:8080/json.htm?type=' + cmd
if response.ok:
if f jsonData["status"] != "OK":
print("Status " + jsonData["status"] + " for " + cmd)
else:
Aandegrens
Hi Westcott,
I tried the following:
It returns no errors from Python but print the message "Response not OK!!!: 401"
When I enter strDomoticz+strJson in the browser directly i'm getting the 401 error also.
When I change localhost to the ip adres of Domoticz it works in the browser, but not in Python. Same Response not OK!!! 401 error in Python.
Looks like Python doesn't have any rights to write directly to Domoticz.
strDomoticz = 'http://localhost:8080'
response = requests.get(strDomoticz+strJson)
if response.ok:
print("Status " + jsonData["status"] + " for " + strJson)
else:
else:
print('Response not OK!!!'str(response.status_code))When I enter strDomoticz+strJson in the browser directly i'm getting the 401 error also.
tweakertje
- Target OS: -
In domoticz go to setings system and put the ipadres of your server in ip adres without authentication
Aandegrens
Yip, That's it.
Or removing the username for the website does the trick also.
But adding an ip range is a beter solution.
Made a function that does the writing to Domoticz form me now:
Thank you all for your assistance.
import socket
import struct
import datetime
import http.client
import time
import requests
#Schrijf data naar Domoticz
def Domoticz(strIdx, strVal):
strJson='/json.htm?type=command¶m=udevice&idx='+strIdx+'&svalue='+strVal
#print(strDomoticz+strJson)
if str(res.status) == '200':
x=1
#print(Tijd+" Ok")
else:
print(Tijd+" IDX = "+strIdx+" ("+strVal+") "+str(res.status)+' Reason: '+str(res.reason))
return
#\Schrijf data naar Domoticz
vaevictis
Is this script compatible with Python 2 or 3?
When I run this script with Python 3.2 and the correct IP addresses and dummy device ids it just hangs. When I break it off with CTRL-C:
/luxtronic.py: line 12: portHeatpump: command not found
./luxtronic.py: line 14: syntax error near unexpected token `('
./luxtronic.py: line 14: `s = socket.socket( socket.AF_INET, socket.SOCK_STREAM)'
Can someone post the integral working version of this script? Thanks.
Aandegrens
My script is running on Python 3.4
vaevictis
Can you post your latest version?Aandegrens wrote:My script is running on Python 3.4
The webserver is protected with a default password 888888 and got recently an update to firmware V3.79 can this be the reason the script doesn't work?
Aandegrens
#!/usr/bin/python
import socket
import struct
import datetime
import http.client
import time
import requests
import json
import sys
import codecs
#Write data to Domoticz
def Domoticz(strIdx, strVal, strDesc = '', strWP_ID = ''):
x=1
#print(Tijd+" Ok")
print(strDesc+'; '+strVal+'; DomoticzID; '+strIdx+'; WP_ID; '+strWP_ID+'; Upload')
else:
return
#\Write data to Domoticz
#Read data from Domoticz
def DomoticzRead(strIdx, strVal = ''):
intS = 0
intE = 0
intFound = 0
strCont = ""
strJson='/json.htm?type=devices&rid='+strIdx
conn.request("GET",strJson)
conn.close
strCont = str(res.read())
intS = strCont.find('"Data" : "',0)+10
intFound = strCont.find(strVal,intS)
print('Waarde voor '+strIdx+' gevonden op positie:'+str(intFound))
return str(intFound)
#\Read data from Domoticz
#Settings of the Heatpump
# Luxtronik 2.0 IP
# Luxtronik 2.0 port (standard 8889)
portHeatpump = 8888
#/Settings of the Heatpump
Tijd = str(time.asctime(time.localtime(time.time())))
print(Tijd+" Error: REQ_CALCULATED CMD")
exit()
print('\n'+Tijd+'\n')
print("\n")
#Data to variabelen and Domoticz
val = str(float(array_calculated[10])/10)
Domoticz('86', val, 'Temperatuur Aanvoer', '10')
val = str(float(array_calculated[11])/10)
Domoticz('87', val, 'Temperatuur Retour', '11')
val = str(float(array_calculated[12])/10)
Domoticz('88', val, 'Temperatuur Retour Berekend', '12')
val = str(float(array_calculated[13])/10)
Domoticz('89', val, 'Temperatuur Retour Extern', '13')
val = str(float(array_calculated[14])/10)
Domoticz('90', val, 'Temperatuur Heetgas', '14')
val = str(float(array_calculated[15])/10)
Domoticz('91', val, 'Temperatuur Buiten', '15')
val = str(float(array_calculated[16])/10)
Domoticz('92', val, 'Temperatuur Gemiddeld', '16')
val = str(float(array_calculated[17])/10)
Domoticz('93', val, 'Temperatuur Tapwater', '17')
val = str(float(array_calculated[18])/10)
Domoticz('94', val, 'Temperatuur Tapwater ingesteld', '18')
val = str(float(array_calculated[19])/10)
Domoticz('95', val, 'Temperatuur Bron-in', '19')
val = str(float(array_calculated[20])/10)
Domoticz('96', val, 'Temperatuur Bron-uit', '20')
val = '-1.5'
Domoticz('97', val, 'Temperatuur VW Offset', '--')
val = str(round(int(array_calculated[56]/3600),0))
if DomoticzRead('100',val) == '-1':
Domoticz('100', val, 'Uren compressor', '56')
val = str(array_calculated[57])
if DomoticzRead('101',val) == '-1':
Domoticz('101', val, 'Impulsen compressor', '57')
val = str(round(int(array_calculated[63]/3600),0))
if DomoticzRead('102',val) == '-1':
Domoticz('102', val, 'Uren WP', '63')
val = str(round(int(array_calculated[64]/3600),0))
if DomoticzRead('103',val) == '-1':
Domoticz('103', val, 'Uren Verwarming', '64')
val = str(round(int(array_calculated[65]/3600),0))
if DomoticzRead('104',val) == '-1':
Domoticz('104', val, 'Uren Tapwater', '65')
##idx = ''
##wp = '116'
##val = str(datetime.timedelta(seconds=int(array_calculated[116])))
##print('; '+val+'; DomoticzID; '+idx+'; WP_ID; '+wp)
##idx = ''
##wp = '117'
##val = str(datetime.timedelta(seconds=int(array_calculated[117])))
##idx = ''
##wp = '118'
##val = str(datetime.timedelta(seconds=int(array_calculated[118])))
val = str(int(array_calculated[119]))
if val == '0':
omschr = 'Verwarmen'
elif val == '1':
omschr = 'Geen_Vraag'
elif val == '2':
omschr = 'Netz-Einschaltverzoegerung'
elif val == '3':
omschr = 'SSP-zeit'
elif val == '4':
omschr = 'Sperrzeit'
elif val == '5':
omschr = 'Tapwater'
elif val == '6':
omschr = 'Estrich-programm'
elif val == '7':
omschr = 'Abtauen'
elif val == '8':
omschr = 'Pumpenvorlauf'
elif val == '9':
omschr = 'Thermische_Desinfectie'
elif val == '10':
omschr = 'Koelen'
elif val == '11':
omschr = '11:???'
elif val == '12':
omschr = 'Zwembad'
elif val == '13':
omschr = 'Verwarmen_Ext.'
elif val == '14':
omschr = 'Tapwater_Ext.'
elif val == '15':
omschr = '15:???'
elif val == '16':
omschr = 'Durchflussueberwachung'
elif val == '17':
omschr = 'ZWE-betrieb'
if DomoticzRead('106',omschr) == '-1':
## print("Reslutaat lees "+DomoticzRead('106', omschr))
Domoticz('106',omschr,'WP Status','119')
## print('Status; '+val+'; '+omschr+' ; DomoticzID; '+idx+'; WP_ID; '+wp)
##idx = ''
##wp = '120'
##val = str(datetime.timedelta(seconds=int(array_calculated[120])))
##print('VD-stand; '+val+'; DomoticzID; '+idx+'; WP_ID; '+wp)
##idx = ''
##wp = '121'
##val = str(datetime.timedelta(seconds=int(array_calculated[121])))
##print('HRM-tijd; '+val+'; DomoticzID; '+idx+'; WP_ID; '+wp)
##idx = ''
##wp = '122'
##val = str(datetime.timedelta(seconds=int(array_calculated[122])))
##print('HRW-tijd; '+val+'; DomoticzID; '+idx+'; WP_ID; '+wp)
##idx = ''
##wp = '123'
##val = str(datetime.timedelta(seconds=int(array_calculated[123])))
##print('TDI-tijd; '+val+'; DomoticzID; '+idx+'; WP_ID; '+wp)
##idx = ''
##wp = '124'
##val = str(datetime.timedelta(seconds=int(array_calculated[124])))
##print('Blok. tapwater; '+val+'; DomoticzID; '+idx+'; WP_ID; '+wp)
##idx = ''
##wp = '125'
##kWhVerwarming = str(float(array_calculated[151])/10)
##kWhHeetWater = str(float(array_calculated[152])/10)
##StatusZeile1 = str(array_calculated[117])
##StatusZeile2 = str(array_calculated[118])
##StatusZeile3 = str(array_calculated[119])
##LphDurchflussWMZ = str(float(array_calculated[155]))
Tijd = str(time.asctime(time.localtime(time.time())))[11:-5]
val = str(Tijd)
Domoticz('105', val, 'Script laatste run', '--')
#\Data to variabelen and Domoticz
print("Klaar")
s.close()
vaevictis
Ok, got it working by using port 8889 and indenting the script with tabs.
However when the script prints out the text I still get some error:
IndexError: list index out of range
Aandegrens
Does the print(array_calculated) command return any values?
It should return something like this:
[0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 403, 385, 150, 360, 333, 261, 208, 465, 475, 293, 306, 750, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 1, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 24508085, 24460, 0, 0, 31, 0, 0, 24508085, 18218266, 6284792, 0, 0, 0, 0, 0, 0, 0, 42625, 0, 353876, 0, 0, 11, 1, 5, 86, 49, 46, 54, 49, 0, 0, 0, 0, 0, -1062731508, -256, -1062731265, -1062731266, 1478479227, 1478341711, 1478093318, 1477767105, 1477387553, 715, 715, 715, 715, 715, 5, 9, 9, 9, 9, 9, 1496326851, 1496383675, 1496118204, 1496168953, 1496240691, 0, 1, 0, 1, 42625, 0, 0, 0, 1, 0, 0, 1, 0, 0, 0, 0, 0, 0, 1496426298, 1, 0, 0, 0, 0, 0, 0, 0, 0, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
vaevictis
Yes but different positions in the array. The output is:"Aandegrens wrote:Does the print(array_calculated) command return any values?
Calculated
0
249
[1077014636, 1077014636, 0, 0, 7043360, 263938, 32, 16, 0, 117575680, 179, 200, 150, 50, 244, 247, 214, 537, 580, 143, 158, 750, 0, -32, 179, 180, 50, 1500, 50, 1, 0, 1, 0, 1, 1, 1, 0, 0, 0, 1, 0, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 3163640, 1244, 0, 0, 697987, 342041, 0, 3163640, 2588492, 574936, 373931, 1, 0, 0, 0, 0, 0, 39031, 0, 8714, 0, 0, 59, 1, 5, 86, 51, 46, 55, 57, 0, 0, 0, 0, 0, 171049632, -256, 171049727, 171049473, 1482491133, 1482161448, 1481642408, 1481636688, 1481207735, 751, 751, 751, 733, 751, 5, 9, 0, 9, 0, 9, 1496295401, 1496357693, 1496357694, 1496385802, 1496385803, 1, 1, 0, 10, 39031, 0, 0, 207966, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1496424834, 0, 180, 750, 0, 0, 1, 0, -32, -32, 3, 0, 1, 1, 0, 0, 0, 62609, 12217, 0, 4159, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 800, 1, 0, 248, 0, 83, 60, 1216, 1210, 0, 100, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 232, 200, 0, 0, 0, 165, 166, 0, 0, 0, 0, 0, 0, 0, 100, 0, 0, 640, 0, 0, 0, 0]
