Domoticz on RPi Zero W
Kierewiet
I'm new to this forum so I'm not sure if this post in the correct place but I have a question about installing Domoticz on a Raspberry Pi Zero W. I can't find it anywhere on this forum but my plan is to connect three TCRT5000 sensors to the RPi Zero W, install Domoticz on it and acces it through Wifi but I'm not sure if Domoticz can be installed on the RPi Zero W. Can someone tell me if this is possible?
Thanks in advance!
Thanks in advance!
antwan
- Domoticz version: Latest
Re: Domoticz on RPi Zero W
Should be No problem
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
Jumper3126
I have it running like a charm
Kierewiet
Tanks for the fast reply. I'm going to order my products then, and probably return to this forum when I have issues with getting everything to work
Misiek1977
- Target OS: -
Hello
Jumper How "big" is your system and what is the load?
I'm thinking about changing Pi 3B on Zero W .....
Hobbybob
Running it on hardware like a Pi zero W would be awesome.
I would also like to know how big the system is, and if it is responsive enough or that the hardware is barely capable.
TugaDog
- Domoticz version: V3.4834
I have one running very smooth on a RPi Zero W.
It's Perfect for installing anywhere.
sailmich
Hello to all who are able to use zero w and Z-Stick GEN5. And all other who might help me with my setup. I have the newest beta V3.8144 running on my pizero w. In Hardware I added a Z-Stick GEN5, Serial Port is select to dev/ttyAMA0. Setup button in domoticz is red and when I click on that button I forwarded to next side with nodes. All is empty, so the Z-Stick isn't set as a controller nor as a switch.
In log of domoticz I got "Error: OpenZWave: Driver Failed!!" does anybody know where I can get this driver from and which driver is missing. For Z-Stick or for pizero w?
I installed Jessie lite and afterwards domoticz the easy way by sudo curl .........
Thx for helping me
I already spent couple of hours to google the issue without success. That include this forum too, if I didn't find the solution I might used wrong search words. Please forgive me and just sent me a link
Mike
Thx for helping me
Mike
mivo
Hi,Misiek1977 wrote: Sunday 16 April 2017 20:15 Hello
Zero W is nice small piece of hardware, but be aware, it has notably less CPU power than RPI3. It is de facto overclocked RPi 1 model B - 1 CPU core vs. 4 cores of RPI3 and half of RAM
My toys:
Raspberry Pi 3 + UPS PIco HV3.0 A Stack
Minibian (Raspbian Jessie) + Domoticz beta
RFLink 433 Gateway, 1wire DS18B20 temp sensors (GPIO)
RaZberry module + 2x Comet Z-Wave + Z-wave socket
Plugins: WeMo Switch, UPS PIco HV3.0A on GitHub
- DewGew
- Domoticz version: V4.10618
Have domoticz running on a NanoPi NEO-air. Installed on the eMMC. Works lika a charm
MsbS
I have a domoticz instance running on RPi1 model B, as slave (RFlink gateway). 1 usb port for WiFi, 1 port for RFLink. CPU usage is always below 10% (mostly stays below 5%).
DAVIZINHO
hello.
I bought a raspi zero yesterday and i trying to install domoticz on it.
The use the same tutorials like raspberry pi3 and dont work. I have some problems
Can someone tell me what tutorial use to install domoticz in a pi zero?
thanks a lot!!!!
thanks a lot!!!!
pvm
- Domoticz version: 4.10538
Which version of rasbian are you installing and which version of domoticz?
You can search the forum for libssl problems with latest raspbian
DAVIZINHO
i use the last version of raspbian and then I follow this tutorial:pvm wrote: Sunday 17 September 2017 15:07 Which version of rasbian are you installing and which version of domoticz?
https://diyprojects.io/domoticz-install ... ry-pi-3-2/
maybe i make something wrong
EDIT: with last jessie version of raspbian i can make it works but I cant make works miio library
