Raspb Pi 3 and 1wire
Moderators: fantom, leecollings
piotrlis
Post by piotrlis »
I'm using Pi3 and GPIO 1wire - I'm able to get temp from sample device.
Freshly installed Domoticz - when adding hardware - got only option for OWFS - I'm not using OWFS - how to get it working?
regards
piotrlis
antwan
Domoticz version: Latest
Re: Raspb Pi 3 and 1wire
Post by antwan »
Emty: OWFS Path in hardware
Rasp Pi 2B: 3x DS18S20 (1-wire), BME280 (i2c)
Cubietruck 1: Aeotec Z-Wave+, RFXtrx433XL+P1, RFXtrx868, TE923 display, SolarEdge API
Cubietruck 2: Aeotec Z-Wave, Voltcraft CO-20
emme
Domoticz version: latest
Post by emme »
If you specify OWFS Path, Domoticz assume you are using it (see the wiki), if you leave it empty it will detect 1Wire bus
I've done with no OWFS for my 4 DS18B20 probes on my central heating pipes and works really good!
"We always done this way"
lynex93
Post by lynex93 »
emme wrote:If you specify OWFS Path, Domoticz assume you are using it (see the wiki), if you leave it empty it will detect 1Wire bus
Hi, im trying this, but my domoticz doesnt detect the ds18b20, can u help me?
Thanks in advance
emme
Post by emme »
first check if the 1wire bus is ok:
put here the result of:
ls -l /sys/bus/w1/devices
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
