- Mooseknuckle
Has anybody succesfully added the following wireless switch to the gateway?
http://www.gearbest.com/access-control/pp_626695.html
I tried to add it as a round wireless switch but It doesn't work. Maybe I just have to wait for a gateway update but I was curious if others did succeed in adding the switch.
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
levynger
xiaomi released a new wireless switch ?Mooseknuckle wrote:Hi,
if this is the case, it may use a different ID.
can you paste logs after clicking it, it should show "unknown device" with the ID..
I think he actually means he's unable to add it to the gateway through the app. I wonder why they made this revision of buttons and temperature sensors. As a light switch I think I prefer the old switch style as you can hit the entire switch, not just the middle.
- Mooseknuckle
It is what quack3d said, adding it to the gateway does not work. The strange thing is that when I add it, the mihome app counts it as a device but I cannot see it under the devices. Also in Domoticz I see the new switch but nothing changes when I press the button. I can add other devices to the gateway so I think I have to wait for a firmware update from Xiaomi.
levynger
So you are able to add it to mi home apl?Mooseknuckle wrote:Hi,
In this case, you won't see it in domoticz devices if it uses new ID.
After paring it in mi home app, click on it, and in domoticz logs you should see the unknown line with the new device id.
Paste it here, and corbin would be able to do his magics..
Sent from my SM-N920G using Tapatalk
- Mooseknuckle
Hi,levynger wrote:So you are able to add it to mi home apl?Mooseknuckle wrote:Hi,
Paste it here, and corbin would be able to do his magics..![]()
That does not work. As I said, after adding it with the mihome app the switch is not visible in the app, while it does count as a device. I see the switch in Domoticz but it doesn't change and nothing appears in the log when I push the switch. The last update time remains on the time I added the switch.
The problem starts with adding it to the gateway, this has to work before making it work in Domoticz. But anywayz, I was just wondering if ppl with this switch have similar problems or that maybe my switch is broken. All other switches work perfectly.
Anyone tested the new temperature monitor version? The one shaped like a square.
Coldman
Hello Corbin,corbin wrote:Was the error when smoke was detected?
You can enable the raw gateway messages to appear in the Domoticz log by creating a user variable 'XiaomiMessage' of type Integer and value 1. (Setup -> More Options -> User Variables). Then restart the Gateway hardware in Domoticz. from http://www.domoticz.com/wiki/Xiaomi_Gat ... leshooting
Thanks alot for your great job!
Could you please add Gas Sensor to Domoticz, logs:
XiaomiGateway: unhandled model: natgas
{"cmd":"report","model":"natgas","sid":"158d0001112b11","short_id":14003,"data":"{\"alarm\":\"0\"}"}
{"cmd":"report","model":"natgas","sid":"158d0001112b11","short_id":14003,"data":"{\"density\":\"0\"}"}
{"cmd":"heartbeat","model":"natgas","sid":"158d0001112b11","short_id":14003,"data":"{\"voltage\":3600}"}
- IMG_20170530_210847.jpg (133.46 KiB) Viewed 4556 times
- IMG_20170530_210833.jpg (77.16 KiB) Viewed 4556 times
- Screenshot_20170530-210209.png (15.33 KiB) Viewed 4556 times
StefanoA
PROBLEM OF COMMUNICATION AFTER REBOOT
I don't know if this is normal/happening to everyone, but for me it's a problem
After restart/reboot of Raspberry Pi3 & domoticz, if I look at LOG I always find communication problems like below
I figured out that if I go to HARDWARE page, select xiaomi gateway line and just push UPDATE button, the communication thread is restarted and communication is fixed and everything's working properly like shown below
so again, is this normal/happening to everyone else ?
is there any way to prevent this problem automatically in case of reboot/power loss ?
thanks
thanks
lamouette
Same "problem" on my side since ... the beginning
chatainsim
- Domoticz version: v4.11307
Maybe Domoticz start to quickly after startup of the Pi?
Swifty
Not sure if it helps, as I don't seem to have this problem, but if you run 'raspiconfig' I think there is an option in there to 'Wait for network on boot' (or something along those lines).StefanoA wrote:PROBLEM OF COMMUNICATION AFTER REBOOT
thanks
Maybe try to turn that on so that the network stack is fully up and address allocated etc. before Domoticz starts?
Mat2Vence
- Domoticz version: 3.7449
is there anyway to know easily in Domoticz which voltage device correspond to which sensor?
I saw reference of the hex code in another post, but there is nothing matching on my device list... anything I am doind wrong?
- corbin
Thanks, have added to https://github.com/corbinmunce/domoticzColdman wrote: Could you please add Gas Sensor to Domoticz, logs:
Setting it as a smoke detector, type same as the actual smoke detector. Anyone know if there is a more suitable device type for Gas?
Coldman
Thanks a lot!corbin wrote:Thanks, have added to https://github.com/corbinmunce/domoticzColdman wrote: Could you please add Gas Sensor to Domoticz, logs:
UPD: additional information, what's inside:
- IMG_20170530_213410.jpg (135.52 KiB) Viewed 4324 times
- IMG_20170530_213339.jpg (119.54 KiB) Viewed 4324 times
- IMG_20170530_213315.jpg (130.91 KiB) Viewed 4324 times
- corbin
If you don't have many devices, try matching them by battery level on the devices pageMat2Vence wrote:is there anyway to know easily in Domoticz which voltage device correspond to which sensor?
- corbin
Mat2Vence
I have 11 of them... not that easy... anyway I can identify at least some of them.corbin wrote:If you don't have many devices, try matching them by battery level on the devices page
Mat2Vence
One more question... is there any easyway to make the alarm ringtone keep ringing for a while? By default, if switch on, it only remains active for a short period of time which is not that practical for using as an alarm siren.
I guess there is no way to do in blocky script and I should go though lua, isn't it?
ben53252642
My smoke detector has arrived, this is appearing in the Domoticz status logs:
2017-06-02 11:02:44.854 2017-06-02 11:02:44.854 XiaomiGateway: unhandled model: smoke
I can't see the smoke detector in the devices list, I've rebooted the Domoticz server twice.
Build 3.7602
Any ideas?
Build 3.7602
Any ideas?
