"Disable event" -button? Topic is solved
tapas
Post by tapas »
has anyone figured out a way to disable certain blockly event with a single click (with a button for example)? I understand that I can do that via "Event active" -selection, but it would be very cool to have a "manual" -button in dashboard and when pushed my automation would not work and I could manage things manually.
I hope you can understand my explanation :lol:
pvm
Domoticz version: 4.10538
Re: "Disable event" -button?
Post by pvm »
Not exactly what you where looking for but : I've solved this by adding an extra check to the blocky statement(s) 'manual control'
tapas
Re:
Post by tapas »
pvm wrote:Not exactly what you where looking for but : I've solved this by adding an extra check to the blocky statement(s) 'manual control'
I'm interested! How did you do that exactly, can you share your solution?
pj-r
Domoticz version: V3.8650
Post by pj-r »
For a virtual switch you could call json api at its on/off url: viewtopic.php?t=12557#p119552
LXC(x64 Ubuntu Xenial), RFXtrx433E, MySensors
pvm
Post by pvm »
I've created a virtual switch 'manual control' and added that to all IFs in blockly , checking it is off.
tapas
Re:
Post by tapas »
pvm wrote:I've created a virtual switch 'manual control' and added that to all IFs in blockly , checking it is off.
This solved my problem, thanks a lot! Also thanks for the other suggestors!
