Error in my scale script
capman
Post by capman »
Domoticz version beta # 3.7468 on synology with python plugin
A have a bathscale that's working 4 sometime. All readings are send to domoticz 4 each person. But sudenly a get a error in my log.
[string "commandArray = {}..."]:43: bad argument #1 to 'sub' (string expected, got nil)
A have searching for it , but don't find anything. Line 43 is year = string.sub(s, 1, 4)
Is there someone to have a look for what is wrong ? Thanks
if (devicechanged['Weegschaal']) then
print('scale data received')
data = otherdevices_svalues['Weegschaal']
weightMiddle=75
if tonumber(data) == 0 then
print('Gewicht gelijk aan 0')
if (tonumber(data) <= weightMiddle and tonumber(data) > 60 ) then
print('Dit is Sabine')
strDeviceNumber="120"
strDeviceName="Gewicht Sabine"
if tonumber(data) >= weightMiddle then
print('Dit is Kris')
strDeviceNumber="119"
strDeviceName="Gewicht Kris"
if (tonumber(data) >= 55 and tonumber(data) <= 60 ) then
print('Dit is Robin')
strDeviceNumber="122"
strDeviceName="Gewicht Robin"
print('Dit is Milan')
strDeviceNumber="121"
strDeviceName="Gewicht Milan"
t1 = os.time()
s = otherdevices_lastupdate[strDeviceName]
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
difference = (os.difftime (t1, t2))
--only update database if 30 seconds has passed since last entry (my oregon gr101 device sends 11 requests over about 10 seconds)
if difference > 30 then
strData = tostring(data) ..'"'
strProgram= 'curl -s -i -H -f --max-time 2 --connect-timeout 2 -0 "Accept: application/json" "http://xxx.xxx.xxx.xxx:xxxx/json.htm?type=command&param=udevice&hid=2&idx='
strProgram2 ='&dunit=4&dtype=93&dsubtype=1&nvalue=0&svalue='
strCmd = strProgram .. strDeviceNumber .. strProgram2 .. strData
commandArray['SendNotification']= strData
os.execute(strCmd)
jvdz
Domoticz version: 4.107
Re: Error in my scale script
Post by jvdz »
Wild guess: Variable doesn't get filled so this statement fills s with nil:
Just add some logging by putting in some print statements before the line in error.
Jos
capman
Post by capman »
jvdz wrote:Wild guess: Variable doesn't get filled so this statement fills s with nil:
Jos
I had a print(s) command before line 43 but nohing in the log. Except the error.
The script is in the lua scripting window. It's settings are Weegschaal | Lua | Device.
It's like he recognize the command 'otherdevices_lastupdate' anymore, a think. :geek:
jvdz
Post by jvdz »
What bout this version? What does it show in the Log?
	weightMiddle = 75
		if (tonumber(data) <= weightMiddle and tonumber(data) > 60) then
			strDeviceNumber = "120"
			strDeviceName = "Gewicht Sabine"
		elseif tonumber(data) >= weightMiddle then
			strDeviceNumber = "119"
			strDeviceName = "Gewicht Kris"
		elseif (tonumber(data) >= 55 and tonumber(data) <= 60) then
			strDeviceNumber = "122"
			strDeviceName = "Gewicht Robin"
			strDeviceNumber = "121"
			strDeviceName = "Gewicht Milan"
		print('Gewicht is ', data, '    strDeviceName=', strDeviceName)
		t1 = os.time()
		print('Lastupdate is ',s)
		t2 = os.time{year = year, month = month, day = day, hour = hour, min = minutes, sec = seconds}
		difference = (os.difftime(t1, t2))
			strData = tostring(data)..'"'
			strProgram = 'curl -s -i -H -f --max-time 2 --connect-timeout 2 -0 "Accept: application/json" "http://xxx.xxx.xxx.xxx:xxxx/json.htm?type=command&param=udevice&hid=2&idx='
			strProgram2 = '&dunit=4&dtype=93&dsubtype=1&nvalue=0&svalue='
			commandArray['SendNotification'] = strData
			os.execute(strCmd)
Jos
capman
Post by capman »
Copy / past the script. Executed.
Logs.
  • 2017-05-27 18:49:48.275 (RFXtrx433) Weight (Weegschaal)
    2017-05-27 18:49:49.696 LUA: scale data received
    2017-05-27 18:49:49.696 LUA: Dit is Kris
    2017-05-27 18:49:49.696 LUA: Gewicht is
    2017-05-27 18:49:49.697 LUA: 82.4
    2017-05-27 18:49:49.697 LUA: strDeviceName=
    2017-05-27 18:49:49.697 LUA: Gewicht Kris
    2017-05-27 18:49:49.697 LUA: Lastupdate is
    2017-05-27 18:49:49.697 Error: EventSystem: in Weegschaal: [string "commandArray = {}..."]:32: bad argument #1 to 'sub' (string expected, got nil)
jvdz
Post by jvdz »
You are sure you have a device that is called "Gewicht Kris"? ( verify spaces,Caps en Lowercase!)
Jos
capman
Post by capman »
jvdz
Post by jvdz »
How did you create the device "Gewicht Kris" as it has an unknown for Hardware?
Shouldn't that be a Dummy Hardware device?
Jos
capman
Post by capman »
jvdz wrote:How did you create the device "Gewicht Kris" as it has an unknown for Hardware?
Jos
I get this code in my browser >
http://ipdomoticz:port/json.htm?type=command&param=udevice&hid=2&did=4000&dunit=4&dtype=80&dsubtype=1&nvalue=0&svalue=80
So a creating a new device. This was before the dummy intgration in domoticz. Hmmm.. maybe a try it with a dummy now. :o
I follow the tutorial from a old forum http://www.domoticz.com/forum/viewtopic ... 6078#p6078
But it not exist anymore.
capman
Post by capman »
That did the trick :lol: . Stupid to do this not from the beginning :oops: . Strange that it's not working sudenly anymore :roll: .
But what dummy sensor can a use? I had dummy sensor distence but it's cm or inches. And I can't change icon. Let's try it all. Or there must be
a weight sensor comming ;) . Thanks 4 thinking this out.
Log
  • 2017-05-28 13:35:34.630 LUA: Gewicht Dummy
    2017-05-28 13:35:34.631 LUA: Lastupdate is
    2017-05-28 13:35:34.631 LUA: 2017-05-28 13:35:27
    2017-05-28 13:35:35.883 LUA: scale data received
    2017-05-28 13:35:35.884 LUA: Dit is Kris
    2017-05-28 13:35:35.957 LUA: Gewicht is
    2017-05-28 13:35:35.957 LUA: 82.9
    2017-05-28 13:35:35.957 LUA: strDeviceName=
Script
weightMiddle = 75
strDeviceNumber = "375"
strDeviceName = "Gewicht Dummy"
t1 = os.time()
os.execute(strCmd)
Edit: With custom sensor en aslabel Kg. Now I can choose different icons to. Super Happy (and my wife to ;) )
THANKS !
jvdz
Post by jvdz »
Sweet .. now the weight is visible to the whole family so no hiding anymore. ;)
Jos
capman
Post by capman »
Yep :D , and I have it already integrated in my dashticz dashboard. ;)
