How to get a new line in output file raspberry Pi
I would like to monitor some devices and write the values to a file using the rasp.
file = io.open("/home/pi/domoticz/scripts/logfiletemp.txt", "a")
file:write(datum,';',weekdag,';',tijd,';',tempnieuw,';',afgerond,';',opwarmgraden,';',buitentemp,';',windrichting,';',wind,';'
,windvlaag,'\n')
file:close()
The problem is the output is printed on one line. How can I fix that. \n is not working.
,windvlaag,'\n')
file:close()
Re: How to get a new line in output file raspberry Pi
file:write("\n") maybe?
Hmm, weird. This works on the CLI version of LUA
#!/usr/bin/lua
file = io.open("/ram/logfiletemp.txt", "a")
datum = 'datum'
weekdag = 1
tijd = '10:00'
tempnieuw = 23
afgerond = 2
opwarmgraden = 2
buitentemp = 23
windrichting = 'nw'
wind = 7.5
windvlaag = 'ja'
-- This line should be one line
,wind,';',windvlaag,'\n')
file:close()
output of cat /ram/logfiletemp.txt
datum;1;10:00;23;2;2;23;nw;7.5;ja
Do you run this from a Domoticz LUA script? If yes, it looks like something in the embeded LUA
#!/usr/bin/lua
datum = 'datum'
weekdag = 1
tijd = '10:00'
tempnieuw = 23
afgerond = 2
opwarmgraden = 2
buitentemp = 23
windrichting = 'nw'
wind = 7.5
windvlaag = 'ja'
file:close()
Thanks for the quick reply.
I run this from a lUA script of Domoticz. I have tested it on my windows PC and it then it is working. But using it on the rasp-B (Lunix) all the output is printed on one line.
If I run the above script on a Raspberry as a script_time_test.lua script on Domoticz 1.1664, i got the output line by line every minuteJan- wrote:But using it on the rasp-B (Lunix) all the output is printed on one line.
Thanks for your help and support! This one is working on my rasp.:
file:write(datum,';',weekdag,';',tijd,';',opwarmtijd,';',tempnieuw,';',afgerond,';',opwarmgraden,';',gevoelstemperatuur,';',windrichting,';',wind,';',windvlaag)
file:write("\n")
file:close()
file:write("\n")
file:close()
Hello I tried this script but returns
Error: EventSystem: /home/pi/domoticz/scripts/lua/script_time_test.lua:15: attempt to index global 'file' (a nil value)
- Domoticz version: 2022.2
What exactly is in line 15 and which variables are used.
It looks like one of them has no value.
- jvdz
- Domoticz version: 4.107
That means that this statement failed:
Did you check the path for the file you try to open?
Jos
Jos
Thank you, It was wrong syntax
I open another thread on my work viewtopic.php?f=23&t=8928
