Qubino ZMNHAD1 switches instantly on and off
Gravityz
Domoticz version: 2026.3
Post by Gravityz »
Lately i noticed that my qubino module switches on after dusk(like it should) and instantly switches off.
e.g. the light never goes on.
i can switch it on manually without any problems but scheduled it sometimes does this
anybody has the same problems
this is what it looks like from the log
2017-05-22 22:00:01	Off
2017-05-22 22:00:01	On
YcKe
Re: Qubino ZMNHAD1 switches instantly on and off
Post by YcKe »
Have you checked the settings of the module?
There is a setting to switch of the module after x time. Also check the input 1 type setting.(push button or not)
Greetz YcKe
Gravityz
Post by Gravityz »
1: input switch is set to push type
11:automatic turning off =0
12:automatic turning on=0
i do not use any physical switches in the module so setting 1 should not matter.
are you telling me that with the pushtype it might be sensitive to false switching?
the problem only occurs once in a while and it is not because the module did not receive the switch on command because looking at the log it did
i have thise module scheduled to switch on 20 minutes after sun set
YcKe
Post by YcKe »
Can you post a screenshot of your scene/timer?
Greetz YcKe
Gravityz
Post by Gravityz »
here it is
nothing complex
YcKe
Post by YcKe »
Mmmm, indeed. I have something similar except the 20 minutes delay, can you remove the 20 minutes delay and see if the problem still occurs?
Greetz YcKe
Gravityz
Post by Gravityz »
i will
i also changed the everyday in ma,di,wo,th,fr,sat,sun in case there is a bug in that setting
YcKe
Post by YcKe »
Gravityz wrote:i will
I'm using the latest beta with the everyday setting so I don't see a problem occurring there.
Keep us posted how it goes!
Greetz YcKe
lost
Post by lost »
Or a bug in the device firmware, as the relay control side of another qubino product: The smart-meter?
http://www.domoticz.com/forum/viewtopic ... 79#p130079
The Lua device script at the end handles an automatic command that reverse last one if 2 commands follows each others with close timings.
So when you get an ON (you required) immediately followed by a OFF (unwanted), the scrip sends another ON a few seconds (configurable) later in order to get a stable ON state.
It makes the smart-meter relay control work despite of it's crappy firmware.
Gravityz
Post by Gravityz »
Mmm,
might be a bug in the module.
the thing is this module performed flawless for 1 year now.
Yesterday i noticed that it did not switch off on a scheduled time.
the same off command, this time send from a scene did the job.
i am golinfg to delete and make the timer settings again to make sure they are not corrupted somehow
Gravityz
Post by Gravityz »
checked my log yesterday and indeed it looks like the module switches itself back on
it was supposed to switch off at 23:40:00 but this is what happened.
2017-05-26 23:40:03	On
2017-05-26 23:40:01	Off
YcKe
Post by YcKe »
Did you check if there might be an unwanted openzwave association somewhere with the device?
Gravityz
Post by Gravityz »
how can i check that?
i haver the switch with its timing settings
besides that it is only mentioned in an all off scene which works at a certain time.
that scene turns all modules off in case some are left on(if the faiul to switch off
never experiened that this functionality is needed because normally all modules doo exactly like the are supposed to do.
Also if the firmware in the Qubino is buggy why did it function perfect for almost a year, never one failure.
nixalsschrott
Post by nixalsschrott »
Gravityz wrote: ... tuinlampen.jpg
Is that configuration really meant to scheduled to switch on 20 minutes after sun set?
Since the value description of time means value (time) between 00:01 and 23.59 ...
Would be great if this is the way to delay action after sunrise or sunset.
Kind regards
matty
Domoticz Beta | Aeon Labs Z-Wave USB Stick Gen5 | Cyrus SmartHome 4-in-1 Multisensor | Qubino ZMNHCD1 - Roller Shutter | NEO COOLCAM NAS-WR01ZE Power Plug | Fibaro FGRGB-101 | WEMOS D1 MINI (ESP8266) Sensors CO2/TEMP/BARO |
Gravityz
Post by Gravityz »
Yes it is
time is indeed from 00:00-23:59
Type however describes the contect of that time
on time means: switch on exactly on the time specified
after sunset means: use the time specified as a delay after sunset
You have lot of other types
like
before sunset
after sunset
before dunrise
after sunrise
fixed date/time
odd week number
etc etc
nixalsschrott
Gravityz wrote:... Yes it is
Confirmed. Yes it is working pretty good for me. And finally I have got e quite simple blockly to move my shutter up and down on a certain time after sunset and sunrise. Needed to use a virtual day/night switch with time functionality, a user variable and a group with open/close percentage for my shutter ...
Thanks all 4 sharing your ideas in the forum.
matty
