Terrarium control
Lebo2d9
Domoticz version: L stab
Terrarium control
Post by Lebo2d9 »
Today i finished my high voltage control for my terrarium. It contains an RPI 3 , an 8channel relay card and a ULN2803 to invert the outputs of the RPI because the relay relay card is active high.
On the picture the GPIO link cable is not installed. All GPIO ports are availible on the interface board. Later i can add I2C and 1W devices to the interface board.
Now i can start creeating my blocky scripts.
Kind regards
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
Derik
Re: Terrarium control
Post by Derik »
mmm have a terrarium to...
You could build this with a esp relais board....
A string of Dallas is useful...
You can control then temp and hum to...
Bearded dragon?
Lebo2d9
Post by Lebo2d9 »
1 leopard gecko I had 3 but they went ill and only one survived
2 viper geckos
More to come
Derik
Post by Derik »
mmm what are the black things you use in the first picture
Lebo2d9
Post by Lebo2d9 »
Derik wrote:mmm what are the black things you use in the first picture
It is the back side of 3 "legrand 077112" 220V outlet socket mounted in a tripple frame .
I have 3 of this frames. 8 outlets controlled with domoticz and 1 constant 220V.
More to come
Derik
Post by Derik »
ok... when i found them i will upload some of my pictures...
I did setup my heating and light wit Zwave devices....
And a few esp for the tempsensors..
