I'm totally new with Domoticz. I'm using a raspberry pi with the z-wave me stick and saw yesterday this cheap 868,3 MHz Roller Shutter from Renkforce:
https://www.conrad.de/de/rs2w-funk-jalo ... 1-S1584751
Is there any way to include this device into Domoticz, maybe with the z-wave me stick as this is also communicating arround the 869 MHz.
Renkforce 868,3 MHz Roller Shutter with Raspberry
Haeuslebauer30
Haeuslebauer30
Re: Renkforce 868,3 MHz Roller Shutter with Raspberry
Does anybody have an idea?
Thanks in advance
Thanks in advance
I think you can use it togther e.g. with RFLINK on Domoticz. So you have to buy something more .... If you use the roller-shutter-2 it will be work without any other things.
Haeuslebauer30
Thanks. Probably it could be worth to buy this RFLINK, because I need a lot of roller shutters.
Will I need any additional software to make this RFLINK fit for communication under the protocol of this renkforce module?
I don't know. Nehme die Fibaro...,:-) you will have much more functions with Domoticz, like closing between 0-100%....
