EDIT:
Video sent, and I pointed towards my test notes which they clearly didnt read last time... :/
Looks like it will take another week
App is not out yet, I am waiting for validation. Samsung rejected the application this morning since they didnt understand what the app did. I have resubmitted it with a video showing them how to do it.JoXeTe wrote:I can not find the application from the Samsung Gear application portal ... is there any problem ?. I'm looking for "Gearoticz" ....
What you see there is the part in settings where you add your switches. These switches will appear on the first screen if you step back from settings.pwhooftman wrote:just installed the app on my S3, entered the credentials, all my switches show up fine but they do not switch if i press them...
pwhooftman wrote:suggestions:
- switches should have a 1 sec press & hold to prevent switching when scrolling
- when i switched a certain switch and use the back key 1 or two times, every now and then the screen shows "Settings" header in blue, then the name of the last switch, and then "Settings" as a white button. Other times, only the Settings button is showing. The gui is inconsistent when using the back key
- the state of the switches is not shown (all are off), and switching does not work
- this app would benefit or using favourites or shortcuts to limit the switch list to most used.
- other categories (energy etc) most welcome!
EDIT: app just lost all entered server info, switches still showing but not functioning....
Ok, what should the watchface do to complement Domoticz?BluesBro wrote:There really should be a watchface to complement Domoticz ont the Gear. I'm no good in programming it my self, but I surly would pay for one!
Really nice to hear, thanks!Henrik wrote: Tuesday 29 August 2017 8:48 Hi
Love this app. Works great on my S3 Classic.
However there is one small thing, I would like to address. I'm using a "Push On Button" for my garage door, which by definition should always be off.
However on the Gear it always shows as On, so I have to press the button twice to activate it. Once for turning it off, which does nothing, and then again for turning it on.
I don't know if its a bug in Domoticz, but I have also made this post: http://domoticz.com/forum/viewtopic.php?f=6&t=19145
Maybe you could look at the "Data" field too?
Thanks foor the feedback!tinytomos wrote: Wednesday 20 September 2017 0:10 Hi
I really findthe app great, after i have selected swiched can i then decide which switch is at the top of the list??
Like the change order of appearance
Thanks for the app
