ropske
Domoticz version: V3_8394
Post by ropske »
i didn't change anything yet, just my ip of domoticz
var _LANGUAGE 				= 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ		  	= 'http://192.168.1.175:8080';
var _DOMOTICZ_REFRESH		= 5; //in seconds
var _DASHTICZ_REFRESH		= 30; //in minutes
var _THEME 					= 'default'; // default = dashticz default theme
var _HOST_ZIGGO_HORIZON	  	= ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND  	= '';
var _WEATHER_CITY 			= 'Eindhoven';
var _WEATHER_CITYNAME 		= ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY 		= 'NL';
var _USE_AUTO_POSITIONING 	= true; //don't want to configure positions, use auto positioning
var _USE_FAVORITES			= true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK  = false; //do not show the seconds in the clock
var _NEWS_RSSFEED			= 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT			= false;
var _USE_BEAUFORT 			= true; //Bft instead of m/s
var _TRANSLATE_SPEED 		= false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES  = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER 		= 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE 		= true;
var _LASTUPDATE_FORMAT 		= 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT 	= 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
var _APIKEY_MAPS			= '';
var _MAPS_LATITUDE			= '';
var _MAPS_LONGITUDE			= '';
var _AUTO_SWIPEBACK_TO		= 1; //when no activity, swipe back to main screen after x seconds
var _AUTO_SWIPEBACK_TIME	= 10; //seconds
ropske
Post by ropske »
i normally should already show some of my devices?
htilburgs
Post by htilburgs »
Normaly it should show your Domoticz favorites.
Let me check.
Hardware:
EdwinK
Post by EdwinK »
Did you have favorites set in Domoticz?
ropske
Post by ropske »
hmm, it doesn't show temperatures? I only had those in my favorites.
now i added 2 switches and they are shown now in dashticz
htilburgs
Post by htilburgs »
@ropske, I think your calling the wrong URL. Can you try:
http://192.168.1.175:8080/dashticz/
Hardware:
ropske
Post by ropske »
htilburgs
Post by htilburgs »
I just made a clean install (Master version, not beta), copy CONFIG_DEFAULT.js to CONFIG.js, edit CONFIG.js with correct settings and for me it works out of the box.
Hardware:
ropske
Post by ropske »
mine is the beta, maybe i try with master version first
htilburgs
Post by htilburgs »
If you've installed Dashticz in \domoticz\www\dashticz then normaly you give the Domoticz portnumber in the URL. In your case this would be:
http://192.168.1.175:8080/dashticz/index.html
This should work for beta and master. If you give me 1 minute I'm doing a fresh beta install.
Let me come back to you.
Hardware:
ropske
Post by ropske »
mine is not installed in domoticz\www\
it's installed in /var/www/html/dashticz/
ropske
Post by ropske »
now i got this:
but i have a lot of temperatures added to my favorites, but dashticz does not show any of them
htilburgs
Post by htilburgs »
Ok, but this is more than before...;-)
Maybe the temperatures are not recognized by Dashticz. Can you post the output of:
http://192.168.1.175:8080/json.htm?type ... order=Name
Hardware:
ropske
Post by ropske »
its to much lol :D
some specific you want to see, know?
htilburgs
Post by htilburgs »
Output of 1 or 2 temperatures devices??
I've looked in my case, the Pi temperature is also NOT showing for me.
Maybe only switches are shown by default....
Hardware:
ropske
Post by ropske »
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 73,
"CustomImage" : 0,
"Data" : "22.3 C",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 3,
"HardwareName" : "ZWAVE",
"HardwareTypeVal" : 21,
"HaveTimeout" : false,
"ID" : "0901",
"LastUpdate" : "2017-05-18 19:59:57",
"Name" : "Kraan Living2",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "LaCrosse TX3",
"Temp" : 22.300000000000001,
"Timers" : "false",
"Type" : "Temp",
"TypeImg" : "temperature",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "62"
htilburgs
Post by htilburgs »
This is not a device that's in your favorites.... (Favorite:0), so this should not show
Hardware:
htilburgs
Post by htilburgs »
I have to leave right now, but be back in about 1,5 hour.
If you still have the problem I try to pick it up further....
Hardware:
ropske
Post by ropske »
i added it now:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "22.2 C",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 3,
"ID" : "0901",
"LastUpdate" : "2017-05-18 20:14:42",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Temp" : 22.199999999999999,
"Timers" : "false",
"Type" : "Temp",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "62"
htilburgs
Post by htilburgs »
I can't simulate this... Maybe the subtype is not recognized, but as I said, my Pi temperature isn't shown also in Favorites.
Try adding it to the CONFIG.js manualy using the wiki.
Hardware:
Locked
