Debug RFXCOM with RasPi ?
kevster
Post by kevster »
Been using Domoticz along with RFXCOM for a while. I havent used it to transmit for a while (party due to other work) but its been recieving perfectly about 15 sensors and modules.
I tried last night to pair it to some HomeEasy light controllers. I have used both their HE200 and HE300 controllers. Domoticz see's the command perfectly although they end up getting decoded as the following:
HE200W
garage-cr-he200w	Chime	SelectPlus	On
Strangely the HE300 is seen as two devices
garage-cr-he300-1	Lighting 2	AC
garage-cr-he300-2	Lighting 2	HomeEasy EU
However when I use Domo to send the command nothing happens. As the light and plug controller are very near (1meter) i dont think there is an issue that way.
I do have some other devices that used to work and again these dont work (although may be out of range - not 100% sure)
How can I verify the RFXCOM is actually transmitting ? Is there a debug mode ?
I have flashed RFCCOM last night up to 1019 in case it was an issue....
RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
Version: Ext2/1019
Thanks anyone who may be able to assist.
Lebo2d9
Domoticz version: L stab
Re: Debug RFXCOM with RasPi ?
Post by Lebo2d9 »
Have you tried tu send the command with rfxmgr?
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
kevster
Post by kevster »
Nope as that means getting it from what's the pi is and connecting it to a windows pc.
If that is the only real way to test and debug then fine. Just a shame there are no tools internally
Lebo2d9
Post by Lebo2d9 »
I have the same problem.
My domoticz is installed at the attic
I'm thinking about to switch over to RFXCOM via LAN.
But I don't know if this will work. For the moment i have 20 devices connected to my RFXCOM this will be a task when i have plenty off spare time...
If this work you can also connect your RFXMGR to this lan port
More to come
b_weijenberg
Post by b_weijenberg »
the reason is that the remote is using 3 protocols and the module is switched with the HE8xx protocol which is not received.
Please see http://blog.rfxcom.com/?p=5
RFX-433, RFX-433EMC, RFX-868
kevster
Post by kevster »
OK thanks for the advice. I'll give it a go today
