I'm having the same problem as you earlier. So the only way for you to fix that is to do a fresh install of everything?jlites00 wrote:I did a fresh install of Domoticz 3.7, Python 3.5 & Broadlink modules on Raspberry Pi V3. It seems to be working now.
Any idea what the error message below is? I get it every time SAFE is hit despite the int file saved in the Broadlink folder.
Error
Filter:
X
2017-04-02 16:41:34.801 Error: (TEST100) ini file not found: /home/pi/domoticz/plugins/Broadlink\BroadlinkRM2-8-1.ini
2017-04-02 16:41:37.156 Error: (TEST100) ini file not found: /home/pi/domoticz/plugins/Broadlink\BroadlinkRM2-8-1.ini
2017-04-02 16:41:38.959 Error: (TEST100) ini file not found: /home/pi/domoticz/plugins/Broadlink\BroadlinkRM2-8-1.ini
2017-04-02 16:42:28.534 Error: (TEST100) ini file not found: /home/pi/domoticz/plugins/Broadlink\BroadlinkRM2-8-1.ini
2017-04-02 16:42:36.948 Error: (TEST100) ini file not found: /home/pi/domoticz/plugins/Broadlink\BroadlinkRM2-8-1.ini
2017-04-02 16:42:37.149 Error: (TEST100) ini file not found: /home/pi/domoticz/plugins/Broadlink\BroadlinkRM2-8-1.ini
2017-04-02 16:42:37.400 Error: (TEST100) ini file not found: /home/pi/domoticz/plugins/Broadlink\BroadlinkRM2-8-1.ini
2017-04-02 16:43:05.704 Error: (TEST101) Error Connecting to Broadlink device....
2017-04-02 16:43:18.353 Error: (TEST101) Error Connecting to Broadlink device....
2017-04-02 16:43:18.380 Error: (TEST101) 'onCommand' failed 'gaierror'.
2017-04-02 16:43:18.380 Error: (TEST101) ----> Line 118 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function onCommand
2017-04-02 16:43:18.380 Error: (TEST101) ----> Line 326 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function learn
2017-04-02 16:43:18.380 Error: (TEST101) ----> Line 455 in /usr/lib/python3.4/broadlink/__init__.py, function enter_learning
2017-04-02 16:43:18.380 Error: (TEST101) ----> Line 255 in /usr/lib/python3.4/broadlink/__init__.py, function send_packet
2017-04-02 16:43:24.971 Error: (TEST101) Error Connecting to Broadlink device....
2017-04-02 16:43:24.994 Error: (TEST101) 'onCommand' failed 'gaierror'.
2017-04-02 16:43:24.994 Error: (TEST101) ----> Line 118 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function onCommand
2017-04-02 16:43:24.994 Error: (TEST101) ----> Line 326 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function learn
2017-04-02 16:43:24.994 Error: (TEST101) ----> Line 455 in /usr/lib/python3.4/broadlink/__init__.py, function enter_learning
2017-04-02 16:43:24.994 Error: (TEST101) ----> Line 255 in /usr/lib/python3.4/broadlink/__init__.py, function send_packet
2017-04-02 16:43:30.980 Error: (TEST101) Error Connecting to Broadlink device....
2017-04-02 16:43:31.002 Error: (TEST101) 'onCommand' failed 'gaierror'.
2017-04-02 16:43:31.002 Error: (TEST101) ----> Line 118 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function onCommand
2017-04-02 16:43:31.002 Error: (TEST101) ----> Line 326 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function learn
2017-04-02 16:43:31.002 Error: (TEST101) ----> Line 455 in /usr/lib/python3.4/broadlink/__init__.py, function enter_learning
2017-04-02 16:43:31.002 Error: (TEST101) ----> Line 255 in /usr/lib/python3.4/broadlink/__init__.py, function send_packet
2017-04-02 16:43:34.833 Error: (TEST101) Error Connecting to Broadlink device....
2017-04-02 16:43:34.859 Error: (TEST101) 'onCommand' failed 'gaierror'.
2017-04-02 16:43:34.859 Error: (TEST101) ----> Line 118 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function onCommand
2017-04-02 16:43:34.859 Error: (TEST101) ----> Line 326 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function learn
2017-04-02 16:43:34.859 Error: (TEST101) ----> Line 455 in /usr/lib/python3.4/broadlink/__init__.py, function enter_learning
2017-04-02 16:43:34.859 Error: (TEST101) ----> Line 255 in /usr/lib/python3.4/broadlink/__init__.py, function send_packet
2017-04-02 16:43:37.086 Error: (TEST101) Error Connecting to Broadlink device....
2017-04-02 16:43:37.108 Error: (TEST101) 'onCommand' failed 'gaierror'.
2017-04-02 16:43:37.108 Error: (TEST101) ----> Line 118 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function onCommand
2017-04-02 16:43:37.108 Error: (TEST101) ----> Line 326 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function learn
2017-04-02 16:43:37.108 Error: (TEST101) ----> Line 455 in /usr/lib/python3.4/broadlink/__init__.py, function enter_learning
2017-04-02 16:43:37.108 Error: (TEST101) ----> Line 255 in /usr/lib/python3.4/broadlink/__init__.py, function send_packet
2017-04-02 16:43:39.138 Error: (TEST101) Error Connecting to Broadlink device....
2017-04-02 16:43:39.159 Error: (TEST101) 'onCommand' failed 'gaierror'.
2017-04-02 16:43:39.159 Error: (TEST101) ----> Line 118 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function onCommand
2017-04-02 16:43:39.159 Error: (TEST101) ----> Line 326 in /home/pi/domoticz/plugins/Broadlink/plugin.py, function learn
2017-04-02 16:43:39.159 Error: (TEST101) ----> Line 455 in /usr/lib/python3.4/broadlink/__init__.py, function enter_learning
2017-04-02 16:43:39.159 Error: (TEST101) ----> Line 255 in /usr/lib/python3.4/broadlink/__init__.py, function send_packet
2017-04-02 16:44:15.241 Error: (TEST101) Error Connecting to Broadlink device....
2017-04-02 16:46:15.239 Error: (TEST101) Error Connecting to Broadlink device....
Is the LEARN process same as IR & RF 433?
Is there a way to auto-discover the Broadlink hub existing connected devices on Domoticz?
Last but not least, is the plugin compatible with Broadlink TC2 Switches?
Overall great learning curve as I've learned quite a bit. Thanks, ZAK45...
Do you install 3.7 straight or do you install 3.5 release and upgrade it to 3.7?
If so, how do you install 3.7 beta without installing 3.5 first?
Also is your broadlink 0.3.0 or 0.4?
Thanks.
