thecosmicgate wrote:Okay back again : domofence was working for a fews days (i think) but at the moment when we entered the zone , it doesn't send the "on" signal.
When we manually press the "test connection" it is working fine ;(
Then I'm afraid I'm out of options Maybe someone else has any ideas?
The code is the same, I only didn't build the app for the latest android version (7.1). So it should use functionality of android 6.
When the app doesn't switch your virtual switch, could you try to disable and then enable your wifi? I would like to know if it switches the switch after this action.
Same issues here. Switch will not turn Off.
When I push the test connection button on 3G the switch is updated by an On command. But by the second push I see a new On command.
So the connection is working fine. Should I see an Off command by the second push?
The test button only sends a 'on' command. The second time you press it, it will also send an 'on' command.
I have this issue as well - When I add the fence it updates the first time, but then not the off (even if i get a notification that i left the area). I will reinstall and see what happens.
sundberg84 wrote:I have this issue as well - When I add the fence it updates the first time, but then not the off (even if i get a notification that i left the area). I will reinstall and see what happens.
Appesteijn wrote:Has the IDX code of your virtual switch changed?
Nope...but i changed my switch to protected and this is what it was causing.
Thanks for sharing. I just had the same thing happening and couldn't figure out why.
Now it only shows me entering or entering the Geofence, even if I click the button and it says 'Geofences removed'. btw. Is it possible to make something in the app so we can see if the fences are on or off?
Duh... My phone was trying to connect to a wrong gateway.
What is your android version?
6.0.1 on my phone (Samsung S6). Will check my wifes phone (S6 edge) which version.
My first feeling on my phone is that it works better but my wifes phone is buggy... but let me come back to you with results.
DomoFence has been working great for a long time and the issues began with a Samsung update my wife did to her phone.
If I don't hear of any bugs, I'll release it in a few days.
Sorry - its not working for me or my wife on our samsung S6 + S6 edge.
The application freezen and android terminate it as soon as i try to add a fence or when we enter/exit.
Thank you for letting me know, I also saw some crashes and I (think) I fixed them in the new beta (2.8.5), but I want to test for a whole day to see if it is correct now. You can help by installing the beta.
Appesteijn wrote:Thank you for letting me know, I also saw some crashes and I (think) I fixed them in the new beta (2.8.5), but I want to test for a whole day to see if it is correct now. You can help by installing the beta.
I got two updates over the past day I think. Now it works much better.
The program is sending off sometimes when im home which it didnt do before but i guess thats something changed in Samsung geo service.
Thx for letting me know. Getting the release stable was a bit messy as I didn't have enough test-devices and I had to beta-release to see if it worked correctly. Unfortunately I got some 2 star ratings because of that, so my average has dropped
I'm going to see if I can add the functionality to have more that 1 geofence in the app in a next release.
