Dashticz - Bug report
qwerk
Re: Dashticz - Bug report
I just tried the thermostat + and -
when clicking my temperature will change, but in seconds it will go back to the old value.
so it kinda works , but not really.
robgeerts
- Domoticz version: 3.7067
It should be loaded, could you check network-tab in console?
- htilburgs
robgeerts wrote:It should be loaded, could you check network-tab in console?
Hardware:
qwerk
if this is for the thermostat, then it still is not working.htilburgs wrote:robgeerts wrote:It should be loaded, could you check network-tab in console?Oops, it's loaded, but I didn't upload the correct CSS.... Stupid, could have seen this....
what do you want me to check?
qwerk
When I set the thermostat, it takes such a long time that dashticz thinks nothing happened
also when I use the url
http://192.168.x.xxx/json.htm?type=comm ... 4418679044
by hand it takes a very long time for domoticz to respond/react.
SwordFish
- Domoticz version: V4.11375
I just installed the latest beta and now i have what it seems to be one scrolling page?
Or did i miss something
robgeerts
I was testing something where it should scroll on smartphone, but not on tablets
To make this better, could you send me your user agent string? You can find it on:
http://www.whoishostingthis.com/tools/user-agent/
SwordFish
Like thisrobgeerts wrote:I was testing something where it should scroll on smartphone, but not on tablets
- Screenshot_2017-05-10-16-19-00.jpg (91.09 KiB) Viewed 5202 times
robgeerts
Please try latest beta!
mikeoo
Your quickrobgeerts wrote:Should be fixed in latest beta!mikeoo wrote:Updated to latest beta and cleared the cache.
I use some door sensors with Xiaomi Mi Smart Home Gateway 2.
Added them to Dashticz and try to use some other icons instead of the default ones because i want to use the doorsensor as a windowssensor.
For the test i use this in config.js
But it keeps the default doorsensor icon .Code: Select all
blocks[1980] = {} blocks[1980]['icon'] = 'fa-window-close'; blocks[1980]['title'] = 'Voordeur'; blocks[1980]['show_lastupdate'] = true;
When i do the same for a dummy switch it is working fine.
Working fine now.
SwordFish
Its working again, thanksrobgeerts wrote:Please try latest beta!
- Phantom
- Domoticz version: 4.11652
Thanks for the fast fixSwordFish wrote:Its working again, thanksrobgeerts wrote:Please try latest beta!
Blueone
Working again, thanks!robgeerts wrote:Thanks for finding the bug, will fix this asap!
- wizjos
@robgeerts: Testing heavily with the latest beta (I hope, because you're so fast!)...
Having trouble getting the nu.nl rss feed to life: nothing shows...
But besides that issue I've noticed for some time (and thus different beta's) when debugging with Edge the console logs: '140 > 'getBlock_140' is undefined' (where the numbers are varied, so this is just an example). I can see where it's generated, but what causes it?
Regards,
Wizjos
Regards,
Wizjos
Teunissm
- Domoticz version: V3.5858
I downloaded the latest beta version, put my original config.js (wich worked at the releases before) and now i get the message: "Error: TypeError: icsURL.replace is not a function. icsUrl.replace is undifined?
Do i forget something?
Regards Marcel
Regards Marcel
robgeerts
I suggest to remove the calendar from your columns for the time being, I'm rewriting the calendar module. Please stay tuned for the calendar module to be fixed in the calendar-topic
robgeerts
How is it defined in your config?wizjos wrote:@robgeerts: Testing heavily with the latest beta (I hope, because you're so fast!)...
Regards,
Wizjos
Console logs are gone in latest beta
- wizjos
I hope it returns to the state it was.... That let me use an internal url... By redirecting via a json service the address became unresolvable...robgeerts wrote:I suggest to remove the calendar from your columns for the time being, I'm rewriting the calendar module. Please stay tuned for the calendar module to be fixed in the calendar-topic
Wizjos
robgeerts
How does your local-address look like?
So I can fix this in next release
Teunissm
This worked for now.robgeerts wrote:I suggest to remove the calendar from your columns for the time being, I'm rewriting the calendar module. Please stay tuned for the calendar module to be fixed in the calendar-topic
Thanx
