clock / timer thermostat
PDP8
Domoticz version: V4.9700
Post by PDP8 »
I'm not sure where to ask. Is there a simple way to put in a timer / clock thermostat in Domotics?
I would like to have a simple user interface where someone can set several temperatures at given times.
My guess was that this would be one of the basics of an automation system. But it seems not to be...
I'm using de a Rasberry Pi with a temperature sensor, a cooling compressor and several lights connected to the gpios.
The system runs fine at fixes times and temperatures. But Someone without programming skills should
set the temperatures as well...
http://www.domoticz.com/forum/viewtopic ... 34&t=17028
emme
Domoticz version: latest
Re: clock / timer thermostat
Post by emme »
add the Dummy hardware and then create a virtual thermostat sensor
once in the UTILITY tab, you will be able to setup timers ;)
I have it in that way and works great!
ciao
"We always done this way"
PDP8
Post by PDP8 »
Ahhh you made my day :D :D :D Thanks a lot for pointing me there!
Now I can set a value at a certain time... Great!
