Locked
EdwinK
Re: Dashticz v2.0, custom positioning and multiple screens
Post by EdwinK »
Staying tuned :)
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
NEW FUNCTION IN BETA!
Want your block to show up differently then Dashticz generates and do you have a little bit of coding skills?
Add to custom.js the following function:
function getBlock_233(device,idx){ //change 233 to the idx of your device!
	$('.block_'+idx).attr('onclick','switchDevice(this)');
	var html='';
	html+='<div class="col-xs-4 col-icon">';
		if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon');
		else html+=iconORimage(idx,'fa-toggle-on','','on icon');
	html+='</div>';
	html+='<div class="col-xs-8 col-data">';
	html+='<strong class="title">'+device['Name']+'</strong><br />';
	if(device['Status']=='Off') html+='<span class="state">AFWEZIG</span>';
	else html+='<span class="state">AANWEZIG</span>';
	if(_SHOW_LASTUPDATE) html+='<br /><span class="lastupdate">'+moment(device['LastUpdate']).format(_LASTUPDATE_FORMAT)+'</span>';
	html+='</div>';
	return html;
Change '233' in the function-name to the idx of your device!
This is a sample-function, you can do whatever you want inside this function.
In the show your dashboard topic you can show what you've created. If it may usefull for other users to, I can include it in the core of Dashticz!
b00n
Post by b00n »
Still having the 2 hour time issue in last beta :(
EdwinK
Post by EdwinK »
robgeerts wrote:NEW FUNCTION IN BETA!
This is a sample-function, you can do whatever you want inside this function.[/quote]
Thanks. Works great. Now I need to figure out how to adapt the afvalwijzer changes in to this.
BTW.. Did I say You Rock
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
When i add the new calendar plugin my dashboard stops working.
I have add (on the dots is my code);
calendars.business = { title: 'business', icalurl: 'https://crossorigin.me/https://calendar.google.com/calendar/ical/...................................................../basic.ics' }
And add
columns[4] = {}
columns[4]['blocks'] = [196,195,197,49,268,calendars.business] //news, ,'train','traffic'
columns[4]['width'] = 5;
Or is this still broken?
Edit:
Found the problem.
Was forgot to add var calendars = {} :oops:
But is it possible to add the title in the calendar block?
Also when using also calendars.private the calendars.business isn't working anymore.
mvveelen
Post by mvveelen »
The news blocks are (on my dashboard) very large and show all news items in just 1 block. Is this a bug or is there something wrong with the way I have it set up?
Using:
blocks['news_1'] = {} // NU.NL
blocks['news_1']['feed'] = 'https://crossorigin.me/http://www.telegraaf.nl/rss';
blocks['news_2'] = {} // TWEAKERS
blocks['news_2']['feed'] = 'https://crossorigin.me/http://feeds.feedburner.com/tweakers/nieuws';
and I don't really think I can go wrong here.....
HansieNL
Post by HansieNL »
robgeerts wrote:Will do :)
Edit: inlatest beta, add to config.js:
var _USE_STATIC_WEATHERICONS= true;
Thx... saves me a trip to the funny farm :lol:
Blah blah blah
Phantom
Domoticz version: 4.11652
Post by Phantom »
Hey, i used "git clone https://github.com/robgeerts/dashticz_v2 dashboard" to install the dashboard a couple of days ago and it works and looks great but i want to use the beta version now.
Now when i use git pull i get the message "Already up-to-date." what must i do?
First time for me to work with github :oops:
EdwinK
Post by EdwinK »
Phantom wrote:Hey, i used "git clone https://github.com/robgeerts/dashticz_v2 dashboard" to install the dashboard a couple of days ago and it works and looks great but i want to use the beta version now.
Backup everything (CONFIG.js, custom.css and anything you might have changed. Remove the map.Then
BTW this is how you clone beta branch into dashticz directory:
CODE: SELECT ALL
git clone https://github.com/robgeerts/dashticz_v2.git --branch beta dashticz
Or simple click here. https://github.com/robgeerts/dashticz_v ... e/beta.zip
Or go to the project page: https://github.com/robgeerts/dashticz_v2.git then click on 2 branches then select beta branch.
EdwinK
Post by EdwinK »
Might be fun there
koowee
Post by koowee »
When using "var _USE_STATIC_WEATHERICONS = false;", normal screen weather icons are ok, but there is no weather icons on standby screen. When static weather icons are selected (var _USE_STATIC_WEATHERICONS = true;), then standby screen shows weather icons.
Phantom
Post by Phantom »
CODE: SELECT ALL
Thanks that worked :)
bsmeding
Post by bsmeding »
I try to change the icon for my windows sensors when they are open/closed
in Domoticz they have an On/Off switch because i can change the icon then. But i want to see open/closed in Dashticz v2.0 so I changed them to 'Door Sensor' in domoticz but then the icon is also a door sensor and does not change
// Ramen
blocks[386] = {}
blocks[386]['icon'] = 'fa-sign-out';
blocks[386]['title'] = 'raam slaapkamer';
Is it possible to either change the icon, or change the On/Off state to Open/Close? The last one i do prefer because then i can also change the the state of 'At home' or 'Not at home' i found some other topic articles related to 'Aanwezig/Afwezig' but not a final solution yet. Does anyone know a proper solution which will keep in place by any updates?
SuperMouse
Post by SuperMouse »
I have been looking around for an hour now, but I can not find how to change the font-size of 1 (text) device? I want my rain prediction smaller and all the others as they are.
Can anybody tell me how to do this? Is there also a way to put the text next to the cloud?
Derik
Post by Derik »
Dear sir Geerts... :roll: :roll:
Is there a solution for this problem?
When Domoticz is updated, it has removed this dashboard?!
Unfortunately, this occurs when the dashboard is installed into Domoticz's www-directory. When Domoticz installs an update, it complete removes the www-directory, before placing the updated version back. Currently, there is no solution for this (except for installing the dashboard on another webserver), you have to re-install this dashboard.
Or is it not possible on the same board to run a other server?
Everytime reinstall is a lot of work when you run the Beta...:-(
Looks realy cool...
Only every time......... grrrr....
robgeerts
Post by robgeerts »
I've installed Dashticz outside Domoticz-folder. Every folder you can reach via your webbrowser is suitable to put Dashticz in... you dont need to run a webserver for it ;)
robgeerts
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Post by robgeerts »
SuperMouse wrote:Hi,
Not at my laptop right now but i thought every block has a unique identifier-classname like '.block233'... wich you can use in css. But if not (will check this out later) I will fix this ;)
Derik
Post by Derik »
robgeerts wrote:I've installed Dashticz outside Domoticz-folder. Every folder you can reach via your webbrowser is suitable to put Dashticz in... you dont need to run a webserver for it ;)
So there is no problem?
Please a example :-) What map and place u use..
xx
x
Derik
Post by Derik »
xx
x
HansieNL
Post by HansieNL »
xx
x
Just updated Domoticz beta and my Dashticz folder is still in place.
Blah blah blah
Locked
