Sounds like a timezone problem, I'll check this asap.b00n wrote:@madrian
Nice work!!!
Is anyone having problems with the time in the calendar it shows my appointments 2 hours earlier ?
Re: Dashticz v2.0, custom positioning and multiple screens
robgeerts
- Domoticz version: 3.7067
I know, but you only have to use it in some situations.sonar wrote:Am I the only one that thinks it is not a good development that we are relying on https://crossorigin.me/ more and more?
Would it not be better to have a proxy in the code of Dashticz?
Some sites dont like to be included in a frame or getting the content from within a localhost or something?
If someone has a better idea, please let me know!
I will check this outmadrian wrote:Apple Calendar support for iCalendar plugin is here.
How to get Apple Calendar url?
How to get Google Calendar url?
On settings page go to Calendars tab, click on your Calendar name then find Private Access row (or Calendar Address if you set your Calendar public):
One thing is missing: auto update calendar (at this time it is refreshing when you hit the refresh button).
Here is my idea: maybe if we ask Rob nicely, then he will check this part.
Merged in the beta version!madrian wrote: B, Better wait for Rob, in a couple of hours he going to merge the request.
sonar
- Domoticz version: 3.8153
Would this be a solution to this problem?robgeerts wrote:I know, but you only have to use it in some situations.
https://www.eriwen.com/javascript/how-to-cors/
I am trying to display a more zoomed radar image from buienradar.
Using this link, option 1.4. https://www.buienradar.nl/overbuienrada ... s-weerdata
I tweaked the provided link a bit, so it looks now like:
It gives me the right radar image as below.
How can I make sure that the white part on the right is gone and that it fills the block just like the normal radar view?
Any help is appreciated.
frames.buivelp = {height:300,width:6,frameurl:"https://gadgets.buienradar.nl/gadget/zoommap/?lat=51.92324&lng=4.47863&overname=2&zoom=13&naam=3011 AD&size=2&voor=0"}How can I make sure that the white part on the right is gone and that it fills the block just like the normal radar view?
- EdwinK
- Domoticz version: BETA
When I paste my URL instead of showing the calendar, it downloads a file basic.ics.madrian wrote:If you have time, please add more info to the Wiki about:
buttons.calendar = {icon: 'fa-calendar', title: 'Kalender', url: 'PASTE_URL_HERE'}
It is for Google Calendar? Other ical calendars are not supported?
It's a totally new module + you must install dashticz from beta branch, check new CONFIG_DEFAULT.js. buttons.calendar is not for this new module.EdKo66 wrote:When I paste my URL instead of showing the calendar, it downloads a file basic.ics.madrian wrote:If you have time, please add more info to the Wiki about:
BTW this is how you clone beta branch into dashticz directory:
git clone https://github.com/robgeerts/dashticz_v2.git --branch beta dashticzOr go to the project page: https://github.com/robgeerts/dashticz_v2.git then click on 2 branches then select beta branch.
- EdwinK
I did.. Couldn't find it. Checking again.madrian wrote:It's a totally new module + you must install dashticz from beta branch, check new CONFIG_DEFAULT.js. buttons.calendar is not for this new module.EdKo66 wrote:When I paste my URL instead of showing the calendar, it downloads a file basic.ics.madrian wrote:If you have time, please add more info to the Wiki about:
Ah.. Now I see what was wrong. I just did git pull. Thinking it remembers that I was using the beta.
Maybe everybody should run they own crossorigin.me server? I got it working, since it is an open source project.
...maybe we should make 'https://crossorigin.me' into a configurable variable in CONFIG.js =>>>> _CROSS_PROXY_URL = '' so everybody can set they own cross proxy server (=or run it's own)? What about this idea?
Any interest in this idea?
Nautilus
Thanks for the calendar plugin, got it working with google calendar at least. My primary calendar is in Outlook, do you know if it can be synced to google's or apple's calendar (or show directly with some url)? Also, any change of letting user to configure several icalendars (in case syncing between them is not an option)?
- gielie
- Domoticz version: latest β
The code is alleeady there, just change the idx and the name of the switch, if you then change the image location, that's it. All credits goes to Rob.EdKo66 wrote:gielie wrote:Can someone help with the following problem.
Rob created some code to change the on/off status with af/aanwezig in the following code
Removed the code to shorten this post
Where exactly should this code be placed? I rather be 'aanwezig' then 'on'.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
- EdwinK
[deleted[
- EdwinK
Would be a good idea, I think. Atm not needed for me, but who knows.madrian wrote:Maybe everybody should run they own crossorigin.me server? I got it working, since it is an open source project.
SwordFish
- Domoticz version: V4.11375
Got errors on the moon script and a notification from wunderground again. Had to many api calls in one minute.
Someone else have problems?
-----------..."]:65: attempt to concatenate global 'moonsetMinute' (a nil value)
2017-04-29 09:20:00.698 Error: EventSystem: in Moon: [string "-- Variables to customize -------------------..."]:65: attempt to concatenate global 'moonsetMinute' (a nil value)
2017-04-29 09:20:02.521 Error: EventSystem: in Moon: [string "-- Variables to customize -------------------..."]:65: attempt to concatenate global 'moonsetMinute' (a nil value)- EdwinK
SwordFish wrote:Got errors on the moon script and a notification from wunderground again. Had to many api calls in one minute.
-----------..."]:65: attempt to concatenate global 'moonsetMinute' (a nil value) 2017-04-29 09:20:00.698 Error: EventSystem: in Moon: [string "-- Variables to customize -------------------..."]:65: attempt to concatenate global 'moonsetMinute' (a nil value) 2017-04-29 09:20:02.521 Error: EventSystem: in Moon: [string "-- Variables to customize -------------------..."]:65: attempt to concatenate global 'moonsetMinute' (a nil value)
Nope, not here.
Ierlandfan
What i think happens is when you reach the limit of WUnderground, they stop sending the right data.
As your error says, it can't find the right values anymore.
- htilburgs
The developer API can do 500 calls per day, with a max of 10 per minute. So you can place a max of 3 per minute for the 500. After that you'll receive an email.
Hardware:
SwordFish
But i have it set to 7200 sec to check so only once in two hours?
Its started last night about 2 am and the error keeps returning.
Is it that i have to disable the script save it and then enable the script again?
Edit:
I just enabled the script again and the error comes right back
Edit:
rick82
First of all: I'm really liking your dashboard, programming skills and keeping developing it! I've been using your dashboard and configuring it since yesterday and it's running like a charm. Bedankt
Second: if I want to change the transparency of a block how do I do that? I want it to be more dark because of the bright background.....?!
There's so much going on in the CSS-sheet
SuperMouse
Hi Guys.
Back again after 5 days on a holiday. Could not resist to open this forum
I have this idea to make the moon edges transparent
Anybody else interested before I change another 99 moons
- moon.56.png (28.21 KiB) Viewed 2693 times
- moontrans.png (94.47 KiB) Viewed 2693 times
- EdwinK
Yes please, Supermouse
