Locked
poudenes
Domoticz version: 3.8993
Re: Dashticz v2.0, custom positioning and multiple screens
Post by poudenes »
After replace with this script, everything updated again and no errors :D
wizjos wrote:OK I think I've got the moonphase lua script working again. I made the mistake to assume lua has a function 'round' when porting it from js to lua.
But now I think I've 'floored' the problem :lol:
New Moonphase LUA script:
-- Variables to customize ------------------------------------------------
local moonpicture = "MoonPicture"           -- name of the uservar to write the name of the moonphase picture to
local checkvar = "MoonphaseCheck"           -- name of the uservar to check if update is allowed
local checktime = 3600                      -- check allowed every x seconds 3600 = 60 min. Check the wundergroud API limitation before changing this
local city = "<your town>"                        -- Your city for Wunderground API
local countryCode = "<YOUR COUNTRY CODE>"                    -- Your country code for Wunderground API
local idxmoonpercentage ='125'              -- Your virtual moon percentage illuminated Device ID
local idxmoonage ='131'                     -- Your virtual moon age Device ID
local idxmoonphase ='132'                   -- Your virtual moon phase Device ID
local idxmoonrise='124'                     -- Your virtual moon rise variable ID
local idxmoonset='127'                      -- Your virtual moon set variable ID
local wuAPIkey = "<your key>"         -- Your Weather Underground API Key
local DOMO_IP = "<your domo ip>"            -- Domoticz ip address
local DOMO_PORT = "<your domo port>"                    -- Domoticz port
local tempfilename = '/var/tmp/phase.tmp'   -- can be anywhere writeable
local debug=false                            -- false, true for domoticz log
function file_exists(path)
    -- function to check if a file exists
    local file = io.open(path, "rb")
    if file then file:close() end
    return file ~= nil
function timedifference(s)
    -- function to determine the difference in seconds between the current time and a given one
    year = string.sub(s, 1, 4)
    month = string.sub(s, 6, 7)
    day = string.sub(s, 9, 10)
    hour = string.sub(s, 12, 13)
    t1 = os.time()
    difference = os.difftime (t1, t2)
    return difference
function may_update(device, timeelapsed)
    -- function to check whether an update is allowed
    return uservariables_lastupdate[device] == nil or timedifference(uservariables_lastupdate[device]) >= timeelapsed
    time = os.date("*t")
    url='http://api.wunderground.com/api/'..wuAPIkey..'/astronomy/q/'..countryCode..'/'..city..'.json'
    if (may_update(checkvar,checktime)==true) or (file_exists(tempfilename)==false) then
       -- read API Wunderground
        if debug then print("Moonphase - Collecting data from: "..url) end
        os.execute('curl -s '..url..' > '..tempfilename)
        -- NOTE: if the command above doens't work in your situation try
        -- read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
        -- instead! Thanks to EdKo66
        file = io.open(tempfilename, "r")
        s= file:read("*a")
        s = (string.gsub(s, "%c+", ""))
        file:close()
        -- moonrise
        moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]])
        if debug then print("Moonrise:\t"..moonriseHour..":"..moonriseMinute) end
        -- moonset
        moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]])
        if debug then print("Moonset:\t"..moonsetHour..":"..moonsetMinute) end
        -- percentage of moon illuminated
        percentIlluminated = string.match(s, [["percentIlluminated":"(%d+)"]])
        if debug then print("Percent:\t"..percentIlluminated.."%") end
        -- age of moon since last new moon
        age = string.match(s, [["ageOfMoon":"(%d+)"]])
        if debug then print("Age:\t\t"..age) end
        -- Phase of the moon
        -- set the moonPhaseIcon to your appropriate icon number (8 x)
        moonPhase = string.match(s, [["phaseofMoon":"(.-)"]])
        if moonPhase=="New Moon" then
            moonPhase = "Nieuwe maan"
            is_waxing = true
        if moonPhase=="Waxing Crescent" then
            moonPhase = "Wassende halve maan"
            is_waxing = true
        if moonPhase=="First Quarter" then
            moonPhase = "Eerste kwartier"
            is_waxing = true
        if moonPhase=="Waxing Gibbous" then
            moonPhase = "Wassende maan"
            is_waxing = true
        if moonPhase=="Full" then
            moonPhase = "Volle maan"
            is_waxing = false
        if moonPhase=="Waning Gibbous" then
            moonPhase = "Afnemende maan"
            is_waxing = false
        if moonPhase=="Last Quarter" then
            moonPhase = "Laatste kwartier"
            is_waxing = false
        if moonPhase=="Waning Crescent" then
            moonPhase = "Afnemende halve maan"
            is_waxing = false
        -- calculate moonphase picture
        if percentIlluminated == '0' then
            n='50'
            if waardecheck==false then
                picnumber=math.floor(math.abs(percentIlluminated-100)/2)
                n=tostring(picnumber)
                if n.length==1 then
                    n='0'+n
                picnumber=math.floor(50+(percentIlluminated/2))
                if picnumber == 100 then
                  picnumber=99
        picture='moon.'..n..'.png'
        if debug then print('Picture number: '..n..' '..'Picture name: '..picture) end
        commandArray['Variable:'..checkvar]=moonPhase
        commandArray['Variable:'..moonpicture]=picture
        commandArray[1] = {['UpdateDevice'] = idxmoonphase.."|0|"..moonPhase}
        commandArray[2] = {['UpdateDevice'] = idxmoonrise.."|0|"..moonriseHour..":"..moonriseMinute}
        commandArray[3] = {['UpdateDevice'] = idxmoonset.."|0|"..moonsetHour..":"..moonsetMinute}
        commandArray[4] = {['UpdateDevice'] = idxmoonage.."|0|"..age}
        commandArray[5] = {['UpdateDevice'] = idxmoonpercentage.."|0|"..percentIlluminated}
        if debug then print("MoonPhase - Update not allowed: Difference is "..timedifference(uservariables_lastupdate[checkvar]).." seconds") end
Please confirm...
Wizjos
madrian
Post by madrian »
Ierlandfan wrote: add frames.calendar to some column.
Edit: For some reason when dashboard reloads the page the calendar isn't filled anymore. Need to look into that.
Enjoy
Thank you, maybe I am going to develop an advanced plugin for this (with iCal support, so you can use any Calendar application which support it: Apple Calendar, Google Calendar etc.).
wizjos
Post by wizjos »
Enjoy
+1 :!:
At the moment struggling with this myself...
poudenes
Post by poudenes »
Enjoy
That will be a great idea :) i can't wait already ...
madrian
Post by madrian »
OK guys, I opened a ticket for this on GitHUB, we'll see when it's coming. :)
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Enjoy
I will look into this tonight, unless you are already on it..
Blueone wrote:I have the following block:
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_Verbruik','281_1','281_2','282']
columns[2]['width'] = 6;
Device 281 is the powerusage and 282 the gas usage.
When I click the gas block the graph is showing in a popup. When I click the power blocks the graph isn't showing, probably because of the _1 and _2, is it possible to show the graph also at these kind of blocks?
Will fix this asap!
mvveelen wrote:
mvveelen wrote:I was wondering: Is it possible to get the "var _SHOW_LASTUPDATE" per device?
For instance: I couldn't care less when the last time it was when I switch off a light, but it would be nice to see when a door sensor has been opened/closed.
And another question: I'd like to display the CV pressure (general, pressure), but all I see is: "Nefit - CV druk : AAN", where it should read 1.6 BAR. Is it possible to change that too ?
Could you send me the device output?
madrian
Post by madrian »
I am on it, we'll see how it goes.
Ierlandfan
Post by Ierlandfan »
I have a new idea for Toon and I think it's already possible but I am not sure.
The roomsetpoint now shows a icon. I would be nice if this icon resembles the state of the burner ("Heating on" which is a switch)
Can we have the icon resembles the heating (switch on/off) while the room setpoint part stays the same?
Output of switch "Heating on"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 3,
         "HardwareName" : "Toon",
         "HardwareType" : "Toon Thermostat",
         "HardwareTypeVal" : 34,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "0000071",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-04-27 20:44:00",
         "Level" : 100,
         "LevelInt" : 15,
         "MaxDimLevel" : 15,
         "Name" : "HeatingOn",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "38"
madrian
Post by madrian »
Work in progress. 8-)
robgeerts
Post by robgeerts »
New version is live.
Check out the fixes at:
https://github.com/robgeerts/dashticz_v ... dated-desc
poudenes
Post by poudenes »
madrian wrote:Work in progress. 8-)
Cool, and so fast... To bad im not into programming... haha Im a happy user
Ierlandfan
Would the original creator of the "trash"/"bin"/"afvalwijzer" lua script step in? I hate not to give credits where credits are due.
I never mentioned him/her because it was a modified script for personal use without original creator name and I can't find the original message.
Everyone is quoting me while i just modified the script. My fault. I am sorry for that. Give me a PM and I 'll make it up to you.
madrian
Post by madrian »
It's live, merge request was sent to Rob.
Until he accepts the request, go and find your iCal URL at Google Calendar:
Gear Icon -> Settings -> Calendars Tab -> click on desidered calendar name -> in Private address row click on ical icon and copy your URL.
The plugin (it shows the next 5 events):
robgeerts
Post by robgeerts »
Thanks, I will do some testing tomorrow night and merge it with the beta branch!
By the way, is it xompatible with 24-hour format and multiple language s (didnt take a look at the code yet)
madrian
Post by madrian »
robgeerts wrote:Thanks, I will do some testing tomorrow night and merge it with the beta branch!
Of course it is, you can set date/time format from CONFIG.js (it is accepting moment.js format) or IMHO the best (default) is to show event time in "friendly" format -> Tomorrow at XY, etc... you can change the locale for this one too.
HansieNL
Post by HansieNL »
Ierlandfan wrote:I have a new idea for Toon and I think it's already possible but I am not sure.
As far as I know this was already on the to do list. I hope it will be integrated soon.
Maybe the Toon selector switch can be the same.
Blah blah blah
mvveelen
Post by mvveelen »
Don't know the exact JSON for this device,
but when I open "http://192.168.0.124:8084/json.htm?type ... 529&plan=0" I get:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "1.3 Bar",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 10,
         "HardwareName" : "Nefit Easy SYNO",
         "HardwareType" : "Nefit Easy HTTP server over LAN interface",
         "HardwareTypeVal" : 68,
         "ID" : "00000101",
         "LastUpdate" : "2017-04-28 07:28:09",
         "Name" : "Nefit - CV druk",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Pressure" : 1.3,
         "SubType" : "Pressure",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "gauge",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "807"
madrian wrote:It's live, merge request was sent to Rob.
Will there be a version in which we can use the Apple (iCloud) calendar ?
Turn off last update date per device enhancement
#18 by robgeerts was closed 12 hours ago updated 12 hours ago
Does this mean we can show the last update per device? If so, how :) ?
Edit:
Would it be possible to add a wiki-file / how-to / readme for the extra's some users have made?
For instance:
- The waste calendar: how-to ad the switch, the contents of the lua script, etc.
- The moon add-on: what switches to add (and how), etc (nice, but not really sure HOW to add which switches etc).
- The calendar add-on (most recent)
- How to adjust the height (and witdh) of the traffic
- etc.
We can read this topic, but if it is in the package, then it would me much easier to maintain and find. Right?
madrian
Post by madrian »
Hmmm, I thought that it is possible to export .ics from Apple Calendar, but now I can't find it. This needs more research.
mvveelen
Post by mvveelen »
madrian wrote:Hmmm, I thought that it is possible to export .ics from Apple Calendar, but now I can't find it. This needs more research.
Yes, it's possible. But that's a one-time export, and it would be better if you can just add the 'live' calendar.
TapNL
Post by TapNL »
For instance:
- etc.
I think this is a good idea, and are more then happy to contribute to this.
The way I imagine it is that we make per function as short description in the wiki and keep updating that.
If we create a trello board of functions that need to be fixed and functions that changed we can set this up quite easy.
@Rob: what do you think?
@Others: who wants to participate?
Locked
