Unable to control Etekcity ZAP Topic is solved
433Mhz opensource Receiver & Transmitter.
tho071088
Domoticz version: Stable
Post by tho071088 »
I have a Etekcity ZAP 4LX, it works fine with the remote.
In Domoticz, it detects Eurodomest or TriState, but they do not work, nothing happens.
(5 other (no name) remote plug are working fine)
Is there an other way to add them ?
I tried to add manually an Energenie 5-Gang, tried all home codes with the 4 switches plugged, nothing happened.
Is there a way to send manually something with RFLink ? (Its working with WiringPi (rfoutlet))
(./codesend 5266691 -l 184)
Thanks for your help !
Domoticz Beta on Rasbperry Pi 3
RFLink / YeeLight / Xiaomi Devices / 433MHz / SonOff via MQTT
Stuntteam
Re: Unable to control Etekcity ZAP
Post by Stuntteam »
Do not use the manual add but use the create rflink device button in the hardware tab.
For the Etekcity use the RFFind feature.
tho071088
Post by tho071088 »
Thanks for your help, it worked with RFFind. :)
I was stucked, but upgrading to the Beta version resolved the problem.
(RFCustom type was not found in Domoticz)
dalonsic
Post by dalonsic »
I have a Etekcity ZAP 4LX too,
I try to plugin with domoticz 3.7450 (rasperry pi with raspbian and a RFXtrx433E USB)...
on the hardware menu, i have add RFXCOM - RFXtrx433 USB 433.92MHz Transceiver Version: Ext/1017
on the switches menu, i have add manually on/off Energenie 5-Gang.
with a good House Code and Unit Code combinaison, i can de/activate all devices on the same time :)
but i can't find a way to manage 1 by 1...
I dont know RFFind or rflink
on the hardware menu, with RFLink Gateway USB, i have a button "create rflink devices", is it the good way ?
but how to know the command to enter ?
Thank's
(sorry for my bad english...)
Stuntteam
Post by Stuntteam »
Do you actually own a RFLink device?
If not.. you might wanna get one..
dalonsic
Post by dalonsic »
I have a RFXCOM RFXtrx433E USB but not RFLink,
I am not a good handyman, so i bought a plug and play device...
maybe i can find a rflink kit for noobs ? :D
dalonsic
Post by dalonsic »
I find a solution !!!
with an other combinaison off house and unit code, i can control 1 by 1...
and sometimes, all in one...
strange but it works :D :D :D
romejay
Post by romejay »
i have the same problem. 2 works on 4.
House A code 4 --> OK
House A code 5 --> OK
What house code and unit code do you use ?
