Locked
wizjos
Re: Dashticz v2.0, custom positioning and multiple screens
Post by wizjos »
HansieNL wrote:I've a little different error: Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_moon_phase.lua: /home/pi/domoticz/scripts/lua/script_time_moon_phase.lua:118: attempt to call field 'round' (a nil value)
As did I :oops:
Had a look at what was wrong. Cause was a division by zero...
New version of the lua moonphase script is to be found in a later post.
EDIT: code in this post removed...
Wizjos
Martijn85
Domoticz version: Stable
Post by Martijn85 »
SwordFish wrote:I have dashticz running on a rpi and a tablet on the wall. Now i have dashticz also running on my NAS webserver. So i did some dirty custom css and now its fits on my iphone with a different layout as on my tablet 8-)
Nice! Can you please share this custom css? :D
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
WARNING: DASHTICZ HAS MOVED FROM GITLAB TO GITHUB!! BACKUP YOUR CONFIG.JS, CUSTOM.CSS AND CUSTOM.JS!!
From now on, you can find the source over here: https://github.com/robgeerts/dashticz_v2/tree/master
custom.js, custom.css and config.js has been moved to the custom-folder!
Also, I created a beta-branch to test new features, in the future. If you like you can download this branch but be prepared of having more bugs...
AND last but not least, I have moved the mentioned bugs and features to the github issue-tracker, instead of Trello:
https://github.com/robgeerts/dashticz_v2/issues
By the way, did I mention to BACKUP YOUR CONFIG.JS, CUSTOM.CSS AND CUSTOM.JS!! ?
madrian
Post by madrian »
I am going to celebrate this. :lol:
Should we send merge request to the beta branch? Then after test you can move to the stable one.
What about an (automatic) upgrade and backup feature? If it is welcomed, It is possible to get from github info about latest release?
htilburgs
Post by htilburgs »
robgeerts wrote:WARNING: DASHTICZ HAS MOVED FROM GITLAB TO GITHUB!! BACKUP YOUR CONFIG.JS, CUSTOM.CSS AND CUSTOM.JS!!
Mmmm... work to do! Update wiki! ;)
Hardware:
madrian
Post by madrian »
You should consider to manage Wiki on the project's GitHub page too. 8-)
robgeerts
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Post by robgeerts »
madrian wrote:I am going to celebrate this. Image
Yes, merge requests to beta :)
Will look into the upgrade functions/alerts.
madrian
Post by madrian »
Look for "releases" on GitHub, it is possible to make releases here. From that point it is easy as pie /there is an RSS feed for release page/.
https://help.github.com/articles/creating-releases/
htilburgs
Post by htilburgs »
@Robgeerts, this is an option.
I think I've to rewrite the wiki, because Github uses an other format.
And you have to create the wiki, because it's your project ;) (I believe I cannot create a wiki if you not started one).
Hardware:
EdwinK
Post by EdwinK »
You mean we have to backup some files? ;)
EdwinK
Post by EdwinK »
Smallish 'error'. Your script says to get 'Moon.0.png', but it is named 'Moon.00.png' in the images map. Easy to fix by just changing the name of the file, but others might not find it.
robgeerts
Post by robgeerts »
Sort of ;)
EdKo66 wrote:Smallish 'error'. Your script says to get 'Moon.0.png', but it is named 'Moon.00.png' in the images map. Easy to fix by just changing the name of the file, but others might not find it.
I will rename it :)
TapNL
Post by TapNL »
Just updated to the new version. Works brilliant. Happy with the different maps possible.
Everything is set to get a tablet on the wall or to get a touchscreen monitor with a pi connected.
I favour the last option.
@rob: thanks again.
HansieNL
Post by HansieNL »
TapNL wrote:Just updated to the new version. Works brilliant. Happy with the different maps possible.
@rob: thanks again.
MagicMirror² The open source modular smart mirror platform.
https://magicmirror.builders/
Blah blah blah
mvveelen
Post by mvveelen »
Also updated to the latest (beta) from the new location, but I receive an error:
Domoticz error!
Please, double check the path in _HOST_DOMOTICZ-variable!
Nothing changed in the CONFIG.js and Domoticz is still running. What's wrong ??
Edit: read, read, READ !!
Moved config.js to the custom folder :)
bierlaagh
Domoticz version: 4.9984
Post by bierlaagh »
As did I :oops:
-- Variables to customize ------------------------------------------------
local moonpicture = "MoonPicture"           -- name of the uservar to write the name of the moonphase picture to
local checkvar = "MoonphaseCheck"           -- name of the uservar to check if update is allowed
local checktime = 3600                      -- check allowed every x seconds 3600 = 60 min. Check the wundergroud API limitation before changing this
local city = "<your town>"                        -- Your city for Wunderground API
local countryCode = "<YOUR COUNTRY CODE>"                    -- Your country code for Wunderground API
local idxmoonpercentage ='125'              -- Your virtual moon percentage illuminated Device ID
local idxmoonage ='131'                     -- Your virtual moon age Device ID
local idxmoonphase ='132'                   -- Your virtual moon phase Device ID
local idxmoonrise='124'                     -- Your virtual moon rise variable ID
local idxmoonset='127'                      -- Your virtual moon set variable ID
local wuAPIkey = "<your key>"         -- Your Weather Underground API Key
local DOMO_IP = "<your domo ip>"            -- Domoticz ip address
local DOMO_PORT = "<your domo port>"                    -- Domoticz port
local tempfilename = '/var/tmp/phase.tmp'   -- can be anywhere writeable
local debug=false                            -- false, true for domoticz log
function file_exists(path)
    -- function to check if a file exists
    local file = io.open(path, "rb")
    if file then file:close() end
    return file ~= nil
function timedifference(s)
    -- function to determine the difference in seconds between the current time and a given one
    year = string.sub(s, 1, 4)
    month = string.sub(s, 6, 7)
    day = string.sub(s, 9, 10)
    hour = string.sub(s, 12, 13)
    t1 = os.time()
    difference = os.difftime (t1, t2)
    return difference
function may_update(device, timeelapsed)
    -- function to check whether an update is allowed
    return uservariables_lastupdate[device] == nil or timedifference(uservariables_lastupdate[device]) >= timeelapsed
    time = os.date("*t")
    url='http://api.wunderground.com/api/'..wuAPIkey..'/astronomy/q/'..countryCode..'/'..city..'.json'
    if (may_update(checkvar,checktime)==true) or (file_exists(tempfilename)==false) then
       -- read API Wunderground
        if debug then print("Moonphase - Collecting data from: "..url) end
        os.execute('curl -s '..url..' > '..tempfilename)
        -- NOTE: if the command above doens't work in your situation try
        -- read = os.execute('curl -s -o '..tempfilename..' "'..url..'"')
        -- instead! Thanks to EdKo66
        file = io.open(tempfilename, "r")
        s= file:read("*a")
        s = (string.gsub(s, "%c+", ""))
        file:close()
        -- moonrise
        moonriseHour, moonriseMinute = string.match(s, [["moonrise": {"hour":"(%d+)","minute":"(%d+)"]])
        if debug then print("Moonrise:\t"..moonriseHour..":"..moonriseMinute) end
        -- moonset
        moonsetHour, moonsetMinute = string.match(s, [["moonset": {"hour":"(%d+)","minute":"(%d+)"]])
        if debug then print("Moonset:\t"..moonsetHour..":"..moonsetMinute) end
        -- percentage of moon illuminated
        percentIlluminated = string.match(s, [["percentIlluminated":"(%d+)"]])
        if debug then print("Percent:\t"..percentIlluminated.."%") end
        -- age of moon since last new moon
        age = string.match(s, [["ageOfMoon":"(%d+)"]])
        if debug then print("Age:\t\t"..age) end
        -- Phase of the moon
        -- set the moonPhaseIcon to your appropriate icon number (8 x)
        moonPhase = string.match(s, [["phaseofMoon":"(.-)"]])
        if moonPhase=="New Moon" then
            moonPhase = "Nieuwe maan"
            is_waxing = true
        if moonPhase=="Waxing Crescent" then
            moonPhase = "Wassende halve maan"
            is_waxing = true
        if moonPhase=="First Quarter" then
            moonPhase = "Eerste kwartier"
            is_waxing = true
        if moonPhase=="Waxing Gibbous" then
            moonPhase = "Wassende maan"
            is_waxing = true
        if moonPhase=="Full" then
            moonPhase = "Volle maan"
            is_waxing = false
        if moonPhase=="Waning Gibbous" then
            moonPhase = "Afnemende maan"
            is_waxing = false
        if moonPhase=="Last Quarter" then
            moonPhase = "Laatste kwartier"
            is_waxing = false
        if moonPhase=="Waning Crescent" then
            moonPhase = "Afnemende halve maan"
            is_waxing = false
        -- calculate moonphase picture
        if percentIlluminated == '0' then
            n='00'
            if waardecheck==false then
                picnumber=math.floor(math.abs(percentIlluminated-100)/2)
                n=tostring(picnumber)
                if n.length==1 then
                    n='0'+n
                picnumber=math.round(50+(percentIlluminated/2))
                if picnumber == 100 then
	        	    picnumber=99
        picture='moon.'..n..'.png'
        if debug then print('Picture number: '..n..' '..'Picture name: '..picture) end
        commandArray['Variable:'..checkvar]=moonPhase
        commandArray['Variable:'..moonpicture]=picture
        commandArray[1] = {['UpdateDevice'] = idxmoonphase.."|0|"..moonPhase}
        commandArray[2] = {['UpdateDevice'] = idxmoonrise.."|0|"..moonriseHour..":"..moonriseMinute}
        commandArray[3] = {['UpdateDevice'] = idxmoonset.."|0|"..moonsetHour..":"..moonsetMinute}
        commandArray[4] = {['UpdateDevice'] = idxmoonage.."|0|"..age}
        commandArray[5] = {['UpdateDevice'] = idxmoonpercentage.."|0|"..percentIlluminated}
        if debug then print("MoonPhase - Update not allowed: Difference is "..timedifference(uservariables_lastupdate[checkvar]).." seconds") end
Please confirm if this does the trick.
Sorry for the inconvenience!
Wizjos
Edit: typo in script fixed[/quote
partly conformed
Only
n='00'
should be
n='50'
Although my moon.50.png is New Moon and moon.00.png is a full moon
1x Raspberry PI 3 With Domoticz V.3.7318
1X RFXtrx433 USB 433.92MHz
1X Synology DS213j Nas
Toon by Eneco including Toon Zon
several KAKU switches and dimmers
Mysensors WIFI Gateway including meters, switches en humidity sensors
Wifi Dimmers (home made)
mvveelen
Post by mvveelen »
I was wondering: Is it possible to get the "var _SHOW_LASTUPDATE" per device?
For instance: I couldn't care less when the last time it was when I switch off a light, but it would be nice to see when a door sensor has been opened/closed.
EdwinK
Post by EdwinK »
bierlaagh wrote:
[qoute]Edit: typo in script fixed
partly conformed
Only
n='00'
should be
n='50'
Don't know about that. The moon looked good for me. Will see what Rob makes of it :)
robgeerts
Post by robgeerts »
We can better ask @madrian ... He created that part ;)
madrian
Post by madrian »
What part? Moon part wasn't me. :shock: :)
Locked
