robgeerts
- Domoticz version: 3.7067
Re: Dashticz v2.0, custom positioning and multiple screens
Well, I submitted a POSSIBLE fix half an hour ago (or something)...
I dont know if it helps in your case but worth a try...
- EdwinK
- Domoticz version: BETA
Here too.
b00n
Same result
To be sure do you have a link to get the api key ?
- mvveelen
Downloaded the latest 2 minutes ago, overwritten all files, except the config: same problem on multiple devices.
sonar
- Domoticz version: 3.8153
traffic map is working fine here.
It is important to not place the long, lat and zoomlevel between ticks ' in the config file.
var _MAPS_LATITUDE = 52.090737;
var _MAPS_LONGITUDE = 5.121420;
var _MAPS_ZOOMLEVEL = 11;
robgeerts
Edit(never mind)
b00n
sonar wrote:traffic map is working fine here.
HERO !!!
Works like a charm now THNX
robgeerts
Why did I not think about that!!
b00n
Easy to forget i think
- mvveelen
Not the solution for me. I'm not using 'ticks', so still the same problem.
Rob, I've sent you the Teamviewer credentials.....
- EdwinK
Works, thanks
b00n
Is it possible to set last update for specified blocks like:
blocks[21]['lastupdate'] = true- htilburgs
+1... Already been looking in the CSS, looks like has someting to do with position: but can't find the exact reason or solutionsonar wrote:After todays pull the up and down arrow of my blinds are positioned on top of eachother.
Hardware:
robgeerts
Together with @mvveelen I did fix a little bug that caused the map wasnt loading for some people!
Download the latest version!
- mvveelen
Thanks Rob, much appreciated !
robgeerts
Its because the <li>-tags have position absolute and zindex 9999 (needed because otherwise a small part of the top button wasnt clickable because of the rotated stop button...) But, at my tablet, it shows the buttons correctly.... could it be cache problem?htilburgs wrote:+1... Already been looking in the CSS, looks like has someting to do with position: but can't find the exact reason or solutionsonar wrote:After todays pull the up and down arrow of my blinds are positioned on top of eachother.
- htilburgs
Nope, no chache....
Can it be, it's missing class .btn.btn-number.min in css?
Hardware:
sonar
No, I don't think so. Same problem in Edge, Firefox, Incognito mode, etc.robgeerts wrote:Could it be cache problem?
robgeerts
It turned out the trafficmap was also not working on a second screen.... just pushed a fix for this...now going to bed
- HansieNL
Working on 2nd screen here.robgeerts wrote:It turned out the trafficmap was also not working on a second screen.... just pushed a fix for this...now going to bed
Blah blah blah
