- EdwinK
- Domoticz version: BETA
Re: Dashticz v2.0, custom positioning and multiple screens
Try this:
You need to take a look at the 'User variables' tab and note the idx of the MoonPicture row.
poudenes
- Domoticz version: 3.8993
Will the news feed also get refreshed by "var _DOMOTICZ_REFRESH = 5;" or does it refresh when you refresh the browser?
I'm using a tablet agains the wall, always plugged in with adapter so screen always on. I don't want refresh it manual.
- EdwinK
What... No more hourly updates on Git? How am I supposed to go through the day nowrobgeerts wrote:Giving back some time to my clients so I'm not answering every hour but I read all your posts and will update again tomorrow or wednesday. Although, good to see that most of your questions are answered by others and users come up with great ideas!
Have fun at work
robgeerts
- Domoticz version: 3.7067
Fixed in latest version!madrian wrote:@Rob,
1, Can you please change title order for percentage and fertility (General-Custom Sensor) type device (red arrow, blue arrow)?
Percentage:
Fertility:Code: Select all
{ "BatteryLevel" : 93, "CustomImage" : 0, "Data" : "54.00%", "Description" : "", "Favorite" : 1, "HardwareID" : 2, "HardwareName" : "Dummy", "HardwareType" : "Dummy (Does nothing, use for virtual switches only)", "HardwareTypeVal" : 15, "HaveTimeout" : true, "Image" : "Computer", "LastUpdate" : "2017-04-23 12:10:09", "Name" : "MiFlora1_moisture", "SubType" : "Percentage", "Type" : "General", "TypeImg" : "hardware", "Unit" : 1, "Used" : 1, "idx" : "41" },
2, add missing FA icon for fertility type sensor. We should use this one.Code: Select all
{ "Data" : "788 Fertility", "HardwareName" : "Dummy", "HardwareType" : "Dummy (Does nothing, use for virtual switches only)", "HardwareTypeVal" : 15, "Image" : "Custom", "LastUpdate" : "2017-04-23 12:10:09", "Name" : "MiFlora1_fertility", "SensorType" : 1, "SensorUnit" : "Fertility", "ShowNotifications" : true, "SubType" : "Custom Sensor", "Type" : "General", "TypeImg" : "Custom", "Unit" : 1, "Used" : 1, "idx" : "42" },
In latest version, you can use (with switches):SuperMouse wrote:Hello all.
Just saying this Dashticz v2.0 is really really greet to play with an looks very nice.
Mayby it is an idea to create a new post and 'show off' you Dashticz?
My question: is it also possible to alter the 'data' value or to clear it totally?
Now I am using green for home and red for away:
See custom css:
.fa.fa-female.on {color: green}
.fa.fa-female.off {color: red}
I think this would look nicer.
blocks[95] = {}
blocks[95]['hide_data'] = true
CoolSuperMouse wrote: Show your Dashticz v2.0 and how-to's!
https://www.domoticz.com/forum/viewtopi ... =8&t=17242
Please check latest version!rbisschops wrote: Another one I checked is the latest blinds version. There is still a part cut off from the 'clickable' part of the + image. I think this is causing it:
Added to my todolist to make this configurable by users..SwordFish wrote:Is it possible to change the color of the graph line?
Ierlandfan wrote:I was thinking about a code for showing the traffic layer on top of Google Maps
Added in latest version!TapNL wrote:.
It's probably as simple as this
In config.js, add 3 variables:
var _APIKEY_MAPS = 'AP_KEY';
var _MAPS_LATITUDE = 51.4275387;
var _MAPS_LONGITUDE = 5.4561574;
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['trafficmap'];
DvD
Just did a git pull and that resulted in a almost empty dashboard without any domoticz buttons nor second screen
Only weather blocks are displayed !!
UPDATE : Working again: didnt had the var _SCREENSLIDER_EFFECT in my config.js and had multiple screens
robgeerts
Thanks, didn't add a default value.
Ierlandfan
Rob, would it be more convenient to remove your api key? Or is it OK to use it?
- EdwinK
AAaaarrggghhh.. I know... backup backup backup.. But just this time I forgot to backup creative.css...
pkrabben
- Domoticz version: 3.5877
for some reason my Graph and traffic map are not working
Before the update of yesterday my graph was working
Does any body have any clue or suggestion
var _APIKEY_MAPS = 'AIzaSyCRgdUxmbzhMPyWAudqbQoaI1HmHZMWP7E';
var _MAPS_LATITUDE = 52.353472;
var _MAPS_LONGITUDE = 5.181684;Code: Select all
columns[4] = {}
columns[4]['blocks'] = ['blocktitle_5','trafficmap','traffic','news']
columns[4]['width'] = 5; Does any body have any clue or suggestion
- EdwinK
Don't post your API-key. It's personal
- EdwinK
Nevermind. Problem was because of a stupid typo...
SwordFish
- Domoticz version: V4.11375
I just updated and my graphic is working, but the trafficmap isn't.
I check on google traffic with my api and lat and lon and there it is working?
robgeerts
Removed my apikey
Did you guys get any error in console??
robgeerts
What if you clear your browser cache?pkrabben wrote:for some reason my Graph and traffic map are not working
var _APIKEY_MAPS = 'AIzaSyCRgdUxmbzhMPyWAudqbQoaI1HmHZMWP7E'; var _MAPS_LATITUDE = 52.353472; var _MAPS_LONGITUDE = 5.181684;Before the update of yesterday my graph was workingCode: Select all
columns[4] = {} columns[4]['blocks'] = ['blocktitle_5','trafficmap','traffic','news'] columns[4]['width'] = 5;
- htilburgs
As far as I know and can test, the var _DOMOTICZ_REFRESH is used to refresh the Domoticz information. The news feed will act on var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds.poudenes wrote:Will the news feed also get refreshed by "var _DOMOTICZ_REFRESH = 5;" or does it refresh when you refresh the browser?
Please test and make sure, before mounting on the wall....
Hardware:
pkrabben
Same issue tried it also on a new device without any history opening this dashboardrobgeerts wrote:What if you clear your browser cache?pkrabben wrote:for some reason my Graph and traffic map are not working
Maartenkr
- Domoticz version: 3.7196
EdKo66 wrote:Try this:
Thank you that was the problem
SwordFish
Can i change the text size of the nest setpoint and the space between the temp and text?
- Knipsel.JPG (11.37 KiB) Viewed 2796 times
sonar
- Domoticz version: 3.8153
It would be nice if the start zoom level for the trafficmap would also be a variable.
Ierlandfan
Yeay, but for now you can set it yourself in main.js
Somewhere along line 290 you find this piece of code: <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
function initMap() {
var map = new google.maps.Map(document.getElementById('trafficmap'), {
zoom: 10,
