Locked
EdwinK
Re: Dashticz v2.0, custom positioning and multiple screens
Post by EdwinK »
Try this:
Screen Shot 2017-04-25 at 08.48.15.png (54.27 KiB) Viewed 2954 times
You need to take a look at the 'User variables' tab and note the idx of the MoonPicture row.
poudenes
Domoticz version: 3.8993
Post by poudenes »
Will the news feed also get refreshed by "var _DOMOTICZ_REFRESH = 5;" or does it refresh when you refresh the browser?
I'm using a tablet agains the wall, always plugged in with adapter so screen always on. I don't want refresh it manual.
EdwinK
Post by EdwinK »
robgeerts wrote:Giving back some time to my clients so I'm not answering every hour but I read all your posts and will update again tomorrow or wednesday. Although, good to see that most of your questions are answered by others and users come up with great ideas!
What... No more hourly updates on Git? How am I supposed to go through the day now ;)
Have fun at work
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
madrian wrote:@Rob,
1, Can you please change title order for percentage and fertility (General-Custom Sensor) type device (red arrow, blue arrow)?
Percentage:
         "BatteryLevel" : 93,
         "CustomImage" : 0,
         "Data" : "54.00%",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "Dummy",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveTimeout" : true,
         "Image" : "Computer",
         "LastUpdate" : "2017-04-23 12:10:09",
         "Name" : "MiFlora1_moisture",
         "SubType" : "Percentage",
         "Type" : "General",
         "TypeImg" : "hardware",
         "Unit" : 1,
         "Used" : 1,
         "idx" : "41"
Fertility:
         "Data" : "788 Fertility",
         "Image" : "Custom",
         "Name" : "MiFlora1_fertility",
         "SensorType" : 1,
         "SensorUnit" : "Fertility",
         "ShowNotifications" : true,
         "SubType" : "Custom Sensor",
         "Type" : "General",
         "TypeImg" : "Custom",
         "Unit" : 1,
         "Used" : 1,
         "idx" : "42"
2, add missing FA icon for fertility type sensor. We should use this one.
Fixed in latest version!
SuperMouse wrote:Hello all.
Just saying this Dashticz v2.0 is really really greet to play with an looks very nice.
Mayby it is an idea to create a new post and 'show off' you Dashticz?
My question: is it also possible to alter the 'data' value or to clear it totally?
Now I am using green for home and red for away:
See custom css:
.fa.fa-female.on {color: green}
.fa.fa-female.off {color: red}
I think this would look nicer.
In latest version, you can use (with switches):
blocks[95] = {}
blocks[95]['hide_data'] = true
SuperMouse wrote: Show your Dashticz v2.0 and how-to's!
https://www.domoticz.com/forum/viewtopi ... =8&t=17242
Cool :)
rbisschops wrote: Another one I checked is the latest blinds version. There is still a part cut off from the 'clickable' part of the + image. I think this is causing it:
Please check latest version!
SwordFish wrote:Is it possible to change the color of the graph line?
Added to my todolist to make this configurable by users..
Ierlandfan wrote:I was thinking about a code for showing the traffic layer on top of Google Maps
TapNL wrote:.
It's probably as simple as this
Added in latest version!
In config.js, add 3 variables:
var _APIKEY_MAPS			= 'AP_KEY';
var _MAPS_LATITUDE			= 51.4275387;
var _MAPS_LONGITUDE		= 5.4561574;
And add the key 'trafficmap' like:
var columns = {}
columns[1] = {}
columns[1]['blocks'] = ['trafficmap'];
DvD
Post by DvD »
Just did a git pull and that resulted in a almost empty dashboard without any domoticz buttons nor second screen
Only weather blocks are displayed !!
UPDATE : Working again: didnt had the var _SCREENSLIDER_EFFECT in my config.js and had multiple screens
robgeerts
Post by robgeerts »
Thanks, didn't add a default value.
Ierlandfan
Post by Ierlandfan »
Rob, would it be more convenient to remove your api key? Or is it OK to use it?
EdwinK
Post by EdwinK »
AAaaarrggghhh.. I know... backup backup backup.. But just this time I forgot to backup creative.css...
pkrabben
Domoticz version: 3.5877
Post by pkrabben »
for some reason my Graph and traffic map are not working
var _APIKEY_MAPS         	= 'AIzaSyCRgdUxmbzhMPyWAudqbQoaI1HmHZMWP7E';
var _MAPS_LATITUDE         	= 52.353472;
var _MAPS_LONGITUDE      	= 5.181684;
columns[4] = {}
columns[4]['blocks'] = ['blocktitle_5','trafficmap','traffic','news']
columns[4]['width'] = 5;
Before the update of yesterday my graph was working
Does any body have any clue or suggestion
EdwinK
Post by EdwinK »
Don't post your API-key. It's personal
EdwinK
Post by EdwinK »
Nevermind. Problem was because of a stupid typo...
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
I just updated and my graphic is working, but the trafficmap isn't.
I check on google traffic with my api and lat and lon and there it is working?
robgeerts
Post by robgeerts »
Removed my apikey ;)
Did you guys get any error in console??
robgeerts
Post by robgeerts »
pkrabben wrote:for some reason my Graph and traffic map are not working
columns[4] = {}
What if you clear your browser cache?
htilburgs
Post by htilburgs »
poudenes wrote:Will the news feed also get refreshed by "var _DOMOTICZ_REFRESH = 5;" or does it refresh when you refresh the browser?
As far as I know and can test, the var _DOMOTICZ_REFRESH is used to refresh the Domoticz information. The news feed will act on var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds.
Please test and make sure, before mounting on the wall....;)
Hardware:
pkrabben
Post by pkrabben »
columns[4] = {}
Same issue tried it also on a new device without any history opening this dashboard
Maartenkr
Domoticz version: 3.7196
Post by Maartenkr »
EdKo66 wrote:Try this:
Thank you that was the problem
SwordFish
Post by SwordFish »
Can i change the text size of the nest setpoint and the space between the temp and text?
sonar
Domoticz version: 3.8153
Post by sonar »
It would be nice if the start zoom level for the trafficmap would also be a variable.
Ierlandfan
Yeay, but for now you can set it yourself in main.js
Somewhere along line 290 you find this piece of code:
function initMap() {
        var map = new google.maps.Map(document.getElementById('trafficmap'), {
          zoom: 10,
Locked
