framb0ise v2 - awesome new dashboard!
safi78
Domoticz version: LastBeta
Re: framb0ise v2 - awesome new dashboard!
Post by safi78 »
Maikie wrote:
jvdz wrote:
Maikie wrote: When I now browse to my domoticz url with /framb0ise I get the domoticz offline message.
What did I do wrong?
I had the same and had to add /index.html to the end of the url.
Jos
That indeed did the trick, thanks!
did you leave out the trailing slash?
http://192.168.0.100:8080/framb0ise does not work
http://192.168.0.100:8080/framb0ise/ does work
homebridge, rfxcom, zwave, nest, applamp, hue, debian, apple, mysensors, netatmo, fibaro, synology, foscam, otherz
safi78
Post by safi78 »
andi216 wrote:
can you test the new version?
Nothing changed :(
did you emtpy your browser cache? sometimes the older version of the .js files keep being used.
Maikie
Post by Maikie »
safi78 wrote:
Maikie wrote:
jvdz wrote: I had the same and had to add /index.html to the end of the url.
Jos
Ah, I see, yeah with / it also works.
I only see info at the moment but that is because I don't have rooms setup I guess?
qwerk
Post by qwerk »
safi78 wrote:
andi216 wrote:I have a FA20RF smoke detector.
In page icon smoke detector does not change the status (is red) even if the sensor is on or off.
I now have a green smokedetector on my screen.
andi216
Domoticz version: 3.7243
Post by andi216 »
Yes.
Now it's always green. : (
qwerk
Post by qwerk »
Yes.
so, no fire at your place.
just kidding: same here.
always green
safi78
Post by safi78 »
Maikie wrote: I only see info at the moment but that is because I don't have rooms setup I guess?
Si.
safi78
Post by safi78 »
qwerk wrote: so, no fire at your place.
always green
:lol:
Try the new update.
qwerk
Post by qwerk »
safi78 wrote:
:lol:
Try the new update.
green and red smokedetectors ( at the right moments)
man, you're fast
I don't have time to find flaws with this solving rate.
Maikie
Post by Maikie »
Si.
I did have a room already but only had 1 device added to that so I now added more rooms but still nothing showing, any idea?
qwerk
Post by qwerk »
Maikie wrote:
Si.
DO you need a login and password for domoticz and did you put that in the config.js?
are you using room names or device names starting with a $
Maikie
Post by Maikie »
qwerk wrote:
Maikie wrote:
safi78 wrote:
Si.
On the local network there is no need for a login so I didn't put that in the config file.
There is 1 default room with a $ in front called hidden devices. The ones that I created myself don't have a $ in front.
andi216
Post by andi216 »
Status smoke icon:
Domoticz SMOKE ON > framb0ise red
Domoticz SMOKE OFF (Reset) > just refresh page > framb0ise green
qwerk
Post by qwerk »
Just to be on the safe side, please try also with a username and password in the config.js.
Maikie
Post by Maikie »
In my first post I mentioned the config file was empty, it appears I was editing the config file in the domotics www folder. I just found the right config file and I changed the IP, still no luck.
Should I enter with username and pass like the format in the example? https://username:password@ip:port?
jvdz
Domoticz version: 4.107
Post by jvdz »
@safi78,
Guess this setup is becoming quite popular. :)
Adding the slash after the url is indeed now working, but thought I tried that in the beginning as well... not important now.
I noticed that the script is not filtering the scene in the rooms and assumes they are device idx'es. I have scene in rooms as the DTGMENU setup is using the same approach as your web front-end and using the room definitions for the telegram inline menu structure. So I have quite some SCENEs/GROUPs defined in them which are showing now obviously strange information.
How do you feel about this? Should they be filtered out or should there be support for SCENE's/Groups like in the regular frontend?
Jos
safi78
Post by safi78 »
jvdz wrote: I noticed that the script is not filtering the scene in the rooms and assumes they are device idx'es. I have scene in rooms as the DTGMENU setup is using the same approach as your web front-end and using the room definitions for the telegram inline menu structure. So I have quite some SCENEs/GROUPs defined in them which are showing now obviously strange information.
Jos
Hi Jos,
Yeah, let's filter rooms/groups the same way.
Scenes can be a Push On
Groups can be be an On/Off
Agree?
safi78
Post by safi78 »
Maikie wrote: I did have a room already but only had 1 device added to that so I now added more rooms but still nothing showing, any idea?
Nope, no idea. What does the browser console say? (usually in Developer tools in your browser). When stuff goes horribly wrong, it's usually logged in there.
Maikie
Post by Maikie »
safi78
Post by safi78 »
Wow.
You are using https:// (ssl) AND port 8080 ...
Pick 1, don't care which, it's your setup ;)
Either use https or remove 8080 depending on your setup.
Users browsing this forum: BartSr, floris74, Henielma, madpatrick and 1 guest
