Locked
madrian
Re: Dashticz v2.0, custom positioning and multiple screens
Post by madrian »
Manual merge request:
main.js, line 299/300
// $('#npTitle').fadeIn('slow');
// audio.pause();
Please enable audio.pause();
iOS Safari is having a bug, and because of this it won't load next station when you click on next. So you must press on pause button then again play button to play the actual station.
audio.pause(); stops current station when you click prev/next button and fixes the problem above and beside of this I think this is the correct behavior (not everybody want's to listen all station while switching).
Gratis question: is the station title changed in the last versions? It's now smaller.
htilburgs
Post by htilburgs »
mvveelen wrote:Tried to get the newsfeed from Telegraaf.nl (http://feeds.feedburner.com/telegraaf/RiEs) but if I replace the Tweakers.net URL with the Telegraaf URL, the block disappears. Something wrong with the way I tried it?
blocks['news_2'] = {}
blocks['news_2']['feed'] = 'https://crossorigin.me/http://feeds.feedburner.com/telegraaf/RiEs';
Have the same problem with this URL. When I use https://crossorigin.me/http://www.telegraaf.nl/rss/'; no problems...;)
Hardware:
htilburgs
Post by htilburgs »
Looks like a problem with crossorigin.me...
GET https://crossorigin.me/http://feeds.fee ... ers/nieuws 503 (Service Unavailable)
XMLHttpRequest cannot load https://crossorigin.me/http://feeds.fee ... ers/nieuws. No 'Access-Control-Allow-Origin' header is present on the requested resource. Origin 'http://192.168.0.100:8088' is therefore not allowed access. The response had HTTP status code 503.
Hardware:
madrian
Post by madrian »
htilburgs wrote:Looks like a problem with crossorigin.me...
http://downforeveryoneorjustme.com/http ... sorigin.me
It's not just you! http://crossorigin.me looks down from here.
BTW:
PLEASE DO NOT USE THE PROXY ON A PRODUCTION SITE.
I cannot guarantee the stability of the service, and you will probably experience service interruptions.
wizjos
Post by wizjos »
EdKo66 wrote:Will I make this in the tab setup/More Option/User Variables?. If so, I get an err[rror]
Indeed, you need to do it that way. I wonder what causes the error then :shock:
Does this explain a bit more? BTW. The value of the variable is not really important when creating...
Same goes for MoonphaseCheck. That's a string variable as well.
Can you explain where the error occurs?
Wizjos
EdwinK
Post by EdwinK »
I think that was the problem, indeed. Didn't know what to enter, tried it with and without anything in it. I used 'integer'. Now it seems to work.
Awaiting the update to really use it
04-22 16:12:00.461 LUA: script bin_selector executed
2017-04-22 16:12:00.504 LUA: MoonPhase - Update not allowed: Difference is 73 seconds
2017-04-22 16:13:00.192 LUA: script bin_selector executed
2017-04-22 16:13:00.201 LUA: MoonPhase - Update not allowed: Difference is 133 seconds
madrian
Post by madrian »
About slides in Dashticz:
Hardware Acceleration
Superslides is compatible with the jQuery Animate Enhanced plugin. Simply include it before this plugin and it will automatically smooth out transitions using CSS instead of JavaScript.
Why not? I tried out:
With HW acceleration enabled the sliding animation is much smoother, but there is a little graphical glitch at the end (the flashing).
But this superslide project is very old and is not maintanced anymore, isn't there a better option? Like Swiper or any other project.
htilburgs
Post by htilburgs »
@Robgeerts,
I still have the issue with the blinds and showing the STOP button. For that I've consulted the manuals from Fibaro and Qubino. There are 3 main types, which are defined in Domoticz:
  • Blinds (normal up - down)
  • Blinds percentage (up - down & percentage up/down)
  • Venetian blinds EU (In dutch: jaloezieën - EU Variant)
Furthermore there a several derivatives from the 3 main types:
  • Blinds inverted (normal up - down -> inverted)
  • Blinds percentage inverted (up - down & percentage up/down -> inverted)
  • Venetian blinds US (In dutch: jaloezieën - US Variant)
Only the Venetian blinds have the ability for the STOP function. For the blinds and blinds percentage the STOP button is not working (correct). The only thing that happens is no STOP, but a revert action (if going Open than Close / Close than Open).
I made an inventory of types, so maybe it's possible to make a correction?
BLINDS
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Open",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "Aeon Labs Z-Stick GEN5",
         "HardwareTypeVal" : 21,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "00000201",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-04-22 16:05:44",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "Rolluik Woonkamer",
         "Notifications" : "false",
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Open",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "Blinds",
         "SwitchTypeVal" : 3,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "blinds",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "741",
         "YOffset" : "287",
         "idx" : "6"
BLINDS PERCENTAGE
         "SwitchType" : "Blinds Percentage",
         "SwitchTypeVal" : 13,
VENETIAN BLINDS EU
         "SwitchType" : "Venetian Blinds EU",
         "SwitchTypeVal" : 15,
BLINDS INVERTED
         "SwitchType" : "Blinds Inverted",
         "SwitchTypeVal" : 6,
BLINDS PERCENTAGE INVERTED
         "SwitchType" : "Blinds Percentage Inverted",
         "SwitchTypeVal" : 16,
VENETIAN BLINDS US
         "SwitchType" : "Venetian Blinds US",
         "SwitchTypeVal" : 14,
Hardware:
wizjos
Post by wizjos »
EdKo66 wrote:I think that was the problem, indeed. Didn't know what to enter, tried it with and without anything in it. I used 'integer'. Now it seems to work.
Cool! I expect it to be working smoothly now... Let's await @robgeerts' new update 8-)
BTW You can set the interval a bit lower for one time only. I don't think Wunderground will charge you for it :lol:
Edited my initial post with the remark about the uservars both being 'text'...
Wizjos
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
htilburgs wrote:@Robgeerts,
BLINDS
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Open",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "00000201",
         "Image" : "Light",
         "Level" : 0,
         "LevelInt" : 0,
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "Open",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "741",
         "YOffset" : "287",
         "idx" : "6"
BLINDS PERCENTAGE
VENETIAN BLINDS EU
BLINDS INVERTED
VENETIAN BLINDS US
Well, I made an option to hide the stop button in latest version (coming tonight) ...
Can anyone confirm that ONLY venetian blinds have a stop button? I thought someone posted he needed the stop button with regular blinds...
robgeerts
Post by robgeerts »
madrian wrote:About slides in Dashticz:
Thanks, will look into this!
rbisschops
Domoticz version: 2.2563
Post by rbisschops »
madrian wrote:Rob, do you know what causes this? Can we except a bugfix?
+I think whole bug reporting would be easier to follow if you migrate the project to GitHub and we can use GitHub's Issues page.
I agree with @madrian GitHub would be so much easier (also for forking this great project ;))
Also it is maybe good to start a stable (master) and and a beta (development) branche when moving to GitHub anyway. That way you can keep a lower pace on the stable releases based on wider tested beta's. Saving you a lot of bug reports I guess :).
Another suggestion I would like to make is to have all the customised code (so custom.css, custom.js and config.js and potentially more in the future) in a separate directory that remains untouched in case of an update. It is now so easy to overwrite the custom files with an update :oops: .
Thx
Ralph
RPi 3B (master): RFXtrx433, Harmony Hub, Z-Wave devices, CoCo units, Hue, Xiaomi Aquara
RPi 2B (slave): P1 connection, MySensors with custom built watermeter sensors on Aquadis+
RPi’s with: Mosquitto MQTT, Home Bridge, Home Assistant (for evaluation only)
robgeerts
Post by robgeerts »
Thx
Ralph
Thanks for the suggestions, added to my todolist at: https://trello.com/b/qsNqHtie/dashboard
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
BLINDS
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Open",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "00000201",
         "Image" : "Light",
         "Level" : 0,
         "LevelInt" : 0,
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "Open",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "741",
         "YOffset" : "287",
         "idx" : "6"
BLINDS PERCENTAGE
VENETIAN BLINDS EU
BLINDS INVERTED
VENETIAN BLINDS US
I have blinds as type and the stop button is working.
EdwinK
Post by EdwinK »
2017-04-22 17:26:00.433 Error: EventSystem: in Moon: [string "-- Variables to customize..."]:59: attempt to concatenate global 'moonriseMinute' (a nil value)
Not quite
Will forward it if they do ;)
SwordFish
Post by SwordFish »
BLINDS
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Open",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "00000201",
         "Image" : "Light",
         "Level" : 0,
         "LevelInt" : 0,
         "PlanID" : "2",
         "PlanIDs" : [ 2 ],
         "Status" : "Open",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "741",
         "YOffset" : "287",
         "idx" : "6"
BLINDS PERCENTAGE
VENETIAN BLINDS EU
BLINDS INVERTED
VENETIAN BLINDS US
Bestand 22-04-17 17 40 51.jpeg (45.85 KiB) Viewed 1945 times
rbisschops
I have tried with KAKU, stop is not working for this type.
robgeerts
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Post by robgeerts »
Not quite
BTW You can set the interval a bit lower for one time only. I don't think Wunderground will charge you for it Image
Is your tempfile writable?
I had the same problem..
EdwinK
Post by EdwinK »
I think it is. chmod 777, not sure though how to make sure. It could be that the path isn't correct.
This is my path to the tmp file: ../volume1/web/tmp/Moon.tmp
Jonb
Domoticz version: 3.5877
Post by Jonb »
You can change it to Fade instead of Slide function. I did it myself and it has a superb result! 100% smoothly and looks better too!
1. edit your jquery.superslides.js
2. find animation:"slide"
3. change to animation:"fade"
4. done (I'm sure you will like it)
You also can change the speed if you want, for me the standard speed value is great.
Locked
