Locked
Blueone
Re: Dashticz v2.0, custom positioning and multiple screens
Post by Blueone »
I found a little issue,
When I add this in the custom css in won't use it (changing the stand-by background color)
.standby .fullslider {
	background-image:none !important;
	background-color:#000000 !important;
When I change it in the creative.css is does work, maybe a bug?
crashingdutchman
Domoticz version: Latest
Post by crashingdutchman »
robgeerts wrote:
crashingdutchman wrote:I wanted to use the mediaplayer next button twice to change to 2 stations up, but my clicks were noted as a double click and my iPad zoomed in on that part of the screen. Can you disable the registration of double clicks on buttons like these and handle them as 2 single clicks?
Also, the nu.nl frame (or popup) is still to big for my iPad Mini.
Edit: also valid for other popups like radio (nederland.fm) and my TV guide popups.
Will check out the popups.
Regarding the zoom-function, could you try adding this snippet to custom.js, right BEFORE:
function afterGetDevices(){
(function($) {
  var IS_IOS = /iphone|ipad/i.test(navigator.userAgent);
  $.fn.nodoubletapzoom = function() {
    if (IS_IOS)
      $(this).bind('touchstart', function preventZoom(e) {
        var t2 = e.timeStamp
          , t1 = $(this).data('lastTouch') || t2
          , dt = t2 - t1
          , fingers = e.originalEvent.touches.length;
        $(this).data('lastTouch', t2);
        if (!dt || dt > 500 || fingers > 1) return; // not double-tap
        e.preventDefault(); // double tap - prevent the zoom
        // also synthesize click events we just swallowed up
        $(this).trigger('click').trigger('click');
})(jQuery);
If this works, I'll add it to the core scripts :)
Rob,
Thank you for your response!
That didn't work. I did some testing myself and found that changing the viewport to the following in index.html solved it:
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=0"/>
I am not sure if this is recommended for other devices, most likely it isn't. However, you could maybe change it programmatically for just iOS devices, just as you are trying to catch the double-click event with your suggested code.
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Well, i found that fix too but they said it doesnt work for ios10...
Blueone
Post by Blueone »
I updated it to the last version but the following code isn't working for the raspberry with touchscreen:
   if(!isMobile){
	$('body').bind('mousemove', function(e){
		standbyTime=0;
		disableStandby();
It doesn't go to standby with this code active.
crashingdutchman
robgeerts wrote:Well, i found that fix too but they said it doesnt work for ios10...
It works for me, both on Chrome and Safari on an iPad Mini with the latest iOS 10(.3.2).
Edit: it also works in Chrome in my browser (Chrome on Windows 10)
bierlaagh
Domoticz version: 4.9984
Post by bierlaagh »
Very happy with Dashticz V2.0 Thnx for that!
But now i encounter an issue wich i don't know if it is resolved or not (could not find it searching this topic)
I have a button and a Scene , Botch have IDX2
blocks[2] = {}
blocks[2]['width'] = 4;
blocks[2]['title'] = 'onkyo'
blocks[2]['icon'] = 'fa-volume-up';
in Config.js i already renamed the Scene :
blocks['s2'] = {}
blocks['s2']['type'] = 'Scene';
blocks['s2']['width'] = 12;
blocks['s2']['title'] = 'Alles uit'
blocks['s2']['icon'] = 'fa-power-off';
But still the scene has the same name as the power button and i haven't figured out why.
2017-04-18 16_15_55-Microsoft Edge.png (302.93 KiB) Viewed 3093 times
Hope someone can helpme getting back on the right track :)
1x Raspberry PI 3 With Domoticz V.3.7318
1X RFXtrx433 USB 433.92MHz
1X Synology DS213j Nas
Toon by Eneco including Toon Zon
several KAKU switches and dimmers
Mysensors WIFI Gateway including meters, switches en humidity sensors
Wifi Dimmers (home made)
marcotrumpet
Post by marcotrumpet »
marcotrumpet wrote:Guys, just thinking..
Do you think it is possible to show (maybe with a buttons.panel) the domoticz security panel to insert allarm code?
Done simply adding a button with the url of the panel but it's too large on my phone.. I don't know how to resize
Inviato dal mio iPhone utilizzando Tapatalk
marcotrumpet
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
I'm sorry to say but since the last few updates i also noticed that the dashboard is responding slow. For example the clock isn't showing instantly and when its show its take a few seconds before its is on time. I've try to clear cache, reboot pi etc etc. On my tablet i looked this morning and just now its still said that it was 10.10u and within seconds its start to update the clock. I had this not with previous versions? Can it have anything to do with the way the rss feeds are working now for train, trafic etc? Just think out loud ;)
madrian
Post by madrian »
SwordFish wrote:I'm sorry to say but since the last few updates i also noticed that the dashboard is responding slow. For example the clock isn't showing instantly and when its show its take a few seconds before its is on time. I've try to clear cache, reboot pi etc etc. On my tablet i looked this morning and just now its still said that it was 10.10u and within seconds its start to update the clock. I had this not with previous versions? Can it have anything to do with the way the rss feeds are working now for train, trafic etc? Just think out loud ;)
Check network tab in Developer Tools (Chrome/FF: right click Inspect then Network tab). For me it is around 2.5sec.
SwordFish
Post by SwordFish »
Somewhere around that, 2 to 4 seconds
madrian
Post by madrian »
Robert,
For buttons.radar I have a gif file. But it's constantly reloading generating huge traffic.
buttons.radar = {icon: 'fa-cloud', title: 'Radar', url: 'http://192.168.1.54:8080/frontpage/idokep.gif?rand='+ Math.random()}
(math.random part is to prevent caching image).
madrian
Post by madrian »
SwordFish wrote: Check network tab in Developer Tools (Chrome/FF: right click Inspect then Network tab). For me it is around 2.5sec.
That's normal. For me in 2.54sec everything is showing instantly, but I am running domoticz on an Intel Atom platform.
robgeerts
Post by robgeerts »
A quick post (not at home). The larger the dashboard gets, the larger response times etc. BUT i am going to speed uo things. Please stay tuned :)
SwordFish
Post by SwordFish »
Thanks, looking forward to
robgeerts
Post by robgeerts »
Ok, added that fix to latest version. (Pushing tomorrow, I think, to gitlab!)
bierlaagh wrote:Very happy with Dashticz V2.0 Thnx for that!
blocks[2] = {}
blocks['s2'] = {}
Ok, fixed in latest version. (Pushing tomorrow, I think, to gitlab!)
madrian
Post by madrian »
C'mon guys, no new post in the last hour? Is this project dead?
I don't think so, new Thermostat selector is submitted for review. :lol:
p.s: you won't belive how many hours needs a little modification like this (100 line of code). :shock:
p.s.2: I am not 100% satisfied with the CSS, it works, but If there is a CSS master he should check it. 8-)
robgeerts
Post by robgeerts »
Looks nice, when can i implement this? (Good night for now)
madrian
Post by madrian »
robgeerts wrote:Looks nice, when can i implement this? (Good night for now)
It's already merge requested, it's up to you. :)
wizjos
Post by wizjos »
Personally I don't like the wind-direction as Domoticz returns it... All english texts like 'ENE', 'WSW' etc.
Created a function to change this and give more descriptive texts like 'oost-noordoost' or 'west-zuidwest'.
To achieve this I hacked in to blocks.js...
Created a function TranslateDirection:
function TranslateDirection(directionstr){
	directionstr='direction_'+directionstr;
	return lang[directionstr];
Altered the line:
blocktypes.Type['Wind'] = { icon: 'wi wi-wind-direction', title: lang.wind, value: '<Speed> m/s, <Direction> <DirectionStr>' }
in:
blocktypes.Type['Wind'] = { icon: 'wi wi-wind-direction', title: lang.wind, value: '<Speed> m/s, <Direction>&deg; ' }
(with a degree sign as well)
and added an extra line (the third) in this piece of code:
	if(typeof(device['Direction'])!=='undefined' && typeof(device['DirectionStr'])!=='undefined'){
		attr+=' style="-webkit-transform: rotate('+device['Direction']+'deg);-moz-transform: rotate('+device['Direction']+'deg);-ms-transform: rotate('+device['Direction']+'deg);-o-transform: rotate('+device['Direction']+'deg); transform: rotate('+device['Direction']+'deg);"';
		value = value+TranslateDirection(device['DirectionStr']);
And finally added in the language file these lines
lang['direction_N'] = 'noord'
lang['direction_NNE'] = 'noord-noordoost';
lang['direction_NE'] = 'noordoost'
lang['direction_ENE'] = 'oost-noordoost';
lang['direction_E'] = 'oost';
lang['direction_ESE'] = 'oost-zuidoost' ;
lang['direction_SE'] = 'zuidoost' ;
lang['direction_SSE'] = 'zuid-zuidoost' ;
lang['direction_S'] = 'zuid' ;
lang['direction_SSW'] = 'zuid-zuidwest' ;
lang['direction_SW'] = 'zuid-west' ;
lang['direction_WSW'] = 'west-zuidwest' ;
lang['direction_W'] = 'west' ;
lang['direction_WNW'] = 'west-noordwest' ;
lang['direction_NW'] = 'noordwest' ;
lang['direction_NNW'] = 'noord-noordwest' ;
All that remains now is a translation from m/s into Bft (Beaufort) :mrgreen:
Wizjos
EDIT: forgot some directions :oops:
Locked
