- EdwinK
- Domoticz version: BETA
Re: New Dashboard Design v2, custom positioning and multiple screens
I believe that somewhere I read that Domoticz doesn't support streaming video-feed.
robgeerts
- Domoticz version: 3.7067
True, but I'm testing with another user to fix this
(It basically just refreshing the image...)
axelbaas
Yes. I used the script somewhere on page 5.EdKo66 wrote:axelbaas wrote: Hmm.. Mine is shown as a normal switch..
Tried both Text and Light/switch;Code: Select all
IsItGonnaRain General Text Geen regen verwacht binnen komende 15 minuten Regen verwacht Light/Switch Switch Off
Is it one of the scripts on this page? https://www.domoticz.com/forum/viewtopi ... =38&t=5903
- gielie
- Domoticz version: latest β
If you need an other tester, i can be a guinea pig.robgeerts wrote:True, but I'm testing with another user to fix this
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
robgeerts
Latest update contains:
- Changed some http to https
- Alert when something is wrong with the Domoticz-path
- Automatic reloading webcam images, example code:
AND:
Add a new variable to your CONFIG.js:
Unfortunately, selector switches are still not working...
Something weird is going on with this...
buttons.mycamera= {width:12, isimage:true, refresh:5000,image: 'http://urltowebcamimage.jpg', url: 'http://urltowebcamimage.jpg'}
Fixed!Nautilus wrote:... if there is some way to change the display name for WU widget? .... it's "pws:NAMEOFTOWN18" and I'd like to show there just "NAMEOFTOWN"..
var _WEATHER_CITYNAME = 'Real name of city';
Nautilus
Thanks! Working finerobgeerts wrote:Fixed!Nautilus wrote:... if there is some way to change the display name for WU widget? .... it's "pws:NAMEOFTOWN18" and I'd like to show there just "NAMEOFTOWN"..
Add a new variable to your CONFIG.js:Code: Select all
I also tested the webcam and yes that works too. However, first my browser (Chrome) wanted to download the images (it asked something like "do you permit to download multiple images" after it downloaded the first and there I was able to choose "Block", then it just kept updating) which was a bit weird.
Also, still have the issue that if I uncomment the "custom positioning" stuff then the page is just blank. Console log shows one error:
main.js?v=107:190 Uncaught ReferenceError: _APIKEY_WUNDERGROUND is not defined
at buildScreens (main.js?v=107:190)
at HTMLDocument.<anonymous> (main.js?v=107:74)
at i (jquery.min.js:2)
at Object.fireWith [as resolveWith] (jquery.min.js:2)
at Function.ready (jquery.min.js:2)
at HTMLDocument.K (jquery.min.js:2)-
JoshDinsdale
koowee wrote:Just to check, did you remove comments from custom positioning part?JoshDinsdale wrote:Hey Guys
Im very new to this, discovered this project just yesterday. Im having some issues getting devices to show. If i have var _USE_AUTO_POSITIONING and var _USE_FAVORITES set as true, i get some favorites show, however if i try and do it manually i cant get anything to show. Weather and clock stuff is fine.
Any suggestions?Code: Select all
/* CUSTOM POSITIONING: ... //screens[2]['columns'] = [4,5,6] */
This is my code from that part...
var blocks = {}
blocks[1] = {}
blocks[1]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[204] = {} //dimmer
blocks[204]['width'] = 12;
blocks[248] = {} //dimmer
blocks[248]['width'] = 12;
blocks[295] = {} //dimmer
blocks[295]['width'] = 12;
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [161,165]
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather',5]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise','horizon',buttons.buienradar,buttons.radio,buttons.calendar,buttons.nunl,buttons.nzbget]
columns[3]['width'] = 2;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg1.jpg';
//screens[2] = {}
//screens[2]['background'] = 'bg3.jpg';
- HansieNL
Have you tried removing */ the comment end?JoshDinsdale wrote: //screens[2] = {}
Blah blah blah
- gielie
Wow the webcam part works great, thanks.
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
Ierlandfan
Are the graphs broken? (Cannot load graphs)
Very cool! I can't wait to give it a try. Thanks again for all the effort you've put in.robgeerts wrote:NEW FEATURE: BACKGROUND, DEPENDING ON TIME OF THE DAY
irishv wrote: Two wish-list features would be 1) having the background switch based on time of day or weather
If you want to use this, edit the definitions for the screens in config.js!
For example, if you have 2 screens (or slides is a better word possibly?), you can use:
(You can change '.night' to: .noon OR .afternoon OR .morning
koowee
When you uncomment CUSTOM POSITIONING part, did you also remove text CUSTOM POSITIONING or add // before it (//CUSTOM POSITIONING)?Nautilus wrote: Also, still have the issue that if I uncomment the "custom positioning" stuff then the page is just blank. Console log shows one error:...which is weird as well as I have set the api key and it works when the stuff after "custom positioning" is commented outCode: Select all
main.js?v=107:190 Uncaught ReferenceError: _APIKEY_WUNDERGROUND is not defined at buildScreens (main.js?v=107:190) at HTMLDocument.<anonymous> (main.js?v=107:74) at i (jquery.min.js:2) at Object.fireWith [as resolveWith] (jquery.min.js:2) at Function.ready (jquery.min.js:2) at HTMLDocument.K (jquery.min.js:2)
SwordFish
- Domoticz version: V4.11375
Sorry for the late reaction, but yes thats the script. I removed the part wich said "binnen 15 minuten".EdKo66 wrote:axelbaas wrote: Hmm.. Mine is shown as a normal switch..
Also in my domoticz its a text idx (53) not a switch.
- Knipsel2.JPG (14.44 KiB) Viewed 2426 times
- Knipsel.JPG (18.75 KiB) Viewed 2426 times
SwordFish
@robgeerts
Is it possible to add the colorcode for overriding the color off the slidernob in the custum css?
I though i had it but it didn't work.
- Knipsel4.jpg (11.43 KiB) Viewed 2421 times
robgeerts
Working here, wich type of sensor is your graph?Ierlandfan wrote:Are the graphs broken? (Cannot load graphs)
In next version I added // by default, hope this gives less problems.koowee wrote: or add // before it (//CUSTOM POSITIONING)?
Cool, but download latest version and use 'refreshimage' instead of 'refresh', like:gielie wrote:Wow the webcam part works great, thanks.
var buttons = {}
buttons.mycamera= {width:12, isimage:true, refreshimage:5000, refreshurl:5000,image: 'http://urltowebcamimage.jpg', url: 'http://urltowebcamimage.jpg'}
buttons.buienradar = {width:12, isimage:true, refreshimage:5000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
- EdwinK
Got it working, sort ofSwordFish wrote:Sorry for the late reaction, but yes thats the script. I removed the part wich said "binnen 15 minuten".EdKo66 wrote:axelbaas wrote: Hmm.. Mine is shown as a normal switch..
Ierlandfan
json.htm?type=graph&sensor=counter&idx=74&range=day (Lux)
json.htm?type=graph&sensor=counter&idx=49&range=day (Solar)
JoshDinsdale
How stupid of me! That was it, i didn't notice that whole block was commented. I removed that comment and commented the CUSTOM POSITIONING: title part and its now working.HansieNL wrote:Have you tried removing */ the comment end?JoshDinsdale wrote: //screens[2] = {}
robgeerts
Could you send me the output of both devices (the graphdata) via PM ?Ierlandfan wrote:json.htm?type=graph&sensor=counter&idx=74&range=day (Lux)
robgeerts
Only the wrong icon, could you send me the output of this device?EdKo66 wrote:Got it working, sort ofSwordFish wrote:Sorry for the late reaction, but yes thats the script. I removed the part wich said "binnen 15 minuten".EdKo66 wrote:
Also in my domoticz its a text idx (53) not a switch.![]()
