Locked
EdwinK
Re: New Dashboard Design v2, custom positioning and multiple screens
Post by EdwinK »
I believe that somewhere I read that Domoticz doesn't support streaming video-feed.
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
True, but I'm testing with another user to fix this :)
(It basically just refreshing the image...)
axelbaas
Post by axelbaas »
EdKo66 wrote:
axelbaas wrote: Hmm.. Mine is shown as a normal switch..
Tried both Text and Light/switch;
IsItGonnaRain	     General	        Text	        Geen regen verwacht binnen komende 15 minuten
Regen verwacht	     Light/Switch	Switch	Off
Is it one of the scripts on this page? https://www.domoticz.com/forum/viewtopi ... =38&t=5903
Yes. I used the script somewhere on page 5.
gielie
Domoticz version: latest β
Post by gielie »
robgeerts wrote:True, but I'm testing with another user to fix this :)
If you need an other tester, i can be a guinea pig.
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
robgeerts
Post by robgeerts »
Latest update contains:
- Changed some http to https
- Alert when something is wrong with the Domoticz-path
- Automatic reloading webcam images, example code:
buttons.mycamera= {width:12, isimage:true, refresh:5000,image: 'http://urltowebcamimage.jpg', url: 'http://urltowebcamimage.jpg'}
AND:
Nautilus wrote:... if there is some way to change the display name for WU widget? .... it's "pws:NAMEOFTOWN18" and I'd like to show there just "NAMEOFTOWN"..:)
Fixed!
Add a new variable to your CONFIG.js:
var _WEATHER_CITYNAME = 'Real name of city';
Unfortunately, selector switches are still not working...
Something weird is going on with this...
Nautilus
Post by Nautilus »
Fixed!
Thanks! Working fine :)
I also tested the webcam and yes that works too. However, first my browser (Chrome) wanted to download the images (it asked something like "do you permit to download multiple images" after it downloaded the first and there I was able to choose "Block", then it just kept updating) which was a bit weird.
Also, still have the issue that if I uncomment the "custom positioning" stuff then the page is just blank. Console log shows one error:
main.js?v=107:190 Uncaught ReferenceError: _APIKEY_WUNDERGROUND is not defined
    at buildScreens (main.js?v=107:190)
    at HTMLDocument.<anonymous> (main.js?v=107:74)
    at i (jquery.min.js:2)
    at Object.fireWith [as resolveWith] (jquery.min.js:2)
    at Function.ready (jquery.min.js:2)
    at HTMLDocument.K (jquery.min.js:2)
...which is weird as well as I have set the api key and it works when the stuff after "custom positioning" is commented out :)
JoshDinsdale
Post by JoshDinsdale »
koowee wrote:
JoshDinsdale wrote:Hey Guys
Im very new to this, discovered this project just yesterday. Im having some issues getting devices to show. If i have var _USE_AUTO_POSITIONING and var _USE_FAVORITES set as true, i get some favorites show, however if i try and do it manually i cant get anything to show. Weather and clock stuff is fine.
Any suggestions?
Just to check, did you remove comments from custom positioning part?
CUSTOM POSITIONING:
//screens[2]['columns'] = [4,5,6]
This is my code from that part...
var blocks = {}
blocks[1] = {}
blocks[1]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[204] = {} //dimmer
blocks[204]['width'] = 12;
blocks[248] = {} //dimmer
blocks[248]['width'] = 12;
blocks[295] = {} //dimmer
blocks[295]['width'] = 12;
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Schakelaars';
//defining number of columns, their contents en widths
//width can be a number 1 to 12, but total widths of all columns should always be 12
var columns = {}
columns[1] = {}
columns[1]['blocks'] = [161,165]
columns[1]['width'] = 5;
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather',5]
columns[2]['width'] = 5;
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise','horizon',buttons.buienradar,buttons.radio,buttons.calendar,buttons.nunl,buttons.nzbget]
columns[3]['width'] = 2;
//if you want to use multiple screens, use the code below:
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg1.jpg';
//screens[2] = {}
//screens[2]['background'] = 'bg3.jpg';
HansieNL
Post by HansieNL »
JoshDinsdale wrote: //screens[2] = {}
Have you tried removing */ the comment end?
Blah blah blah
gielie
Post by gielie »
Wow the webcam part works great, thanks.
- FIBARO FGS223
- Toon
- Kodi Media Server
Ierlandfan
Post by Ierlandfan »
Are the graphs broken? (Cannot load graphs)
irishv
Post by irishv »
robgeerts wrote:NEW FEATURE: BACKGROUND, DEPENDING ON TIME OF THE DAY
irishv wrote: Two wish-list features would be 1) having the background switch based on time of day or weather
If you want to use this, edit the definitions for the screens in config.js!
For example, if you have 2 screens (or slides is a better word possibly?), you can use:
(You can change '.night' to: .noon OR .afternoon OR .morning :)
Very cool! I can't wait to give it a try. Thanks again for all the effort you've put in.
koowee
Post by koowee »
Nautilus wrote: Also, still have the issue that if I uncomment the "custom positioning" stuff then the page is just blank. Console log shows one error:
When you uncomment CUSTOM POSITIONING part, did you also remove text CUSTOM POSITIONING or add // before it (//CUSTOM POSITIONING)?
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Sorry for the late reaction, but yes thats the script. I removed the part wich said "binnen 15 minuten".
Also in my domoticz its a text idx (53) not a switch.
SwordFish
Post by SwordFish »
@robgeerts
Is it possible to add the colorcode for overriding the color off the slidernob in the custum css?
I though i had it but it didn't work.
robgeerts
Post by robgeerts »
Ierlandfan wrote:Are the graphs broken? (Cannot load graphs)
Working here, wich type of sensor is your graph?
koowee wrote: or add // before it (//CUSTOM POSITIONING)?
In next version I added // by default, hope this gives less problems.
gielie wrote:Wow the webcam part works great, thanks.
Cool, but download latest version and use 'refreshimage' instead of 'refresh', like:
var buttons = {}
buttons.mycamera= {width:12, isimage:true, refreshimage:5000, refreshurl:5000,image: 'http://urltowebcamimage.jpg', url: 'http://urltowebcamimage.jpg'}
buttons.buienradar = {width:12, isimage:true, refreshimage:5000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
EdwinK
Post by EdwinK »
Got it working, sort of ;)
Ierlandfan
json.htm?type=graph&sensor=counter&idx=74&range=day (Lux)
json.htm?type=graph&sensor=counter&idx=49&range=day (Solar)
JoshDinsdale
How stupid of me! That was it, i didn't notice that whole block was commented. I removed that comment and commented the CUSTOM POSITIONING: title part and its now working.
robgeerts
Post by robgeerts »
Ierlandfan wrote:json.htm?type=graph&sensor=counter&idx=74&range=day (Lux)
Could you send me the output of both devices (the graphdata) via PM ?
robgeerts
Post by robgeerts »
Only the wrong icon, could you send me the output of this device?
Locked
