Thanks, i have lot of patient , i only have done was let rob see what is happen on my dash, think maybe a issue. did known that you have declared.HansieNL wrote:Has to be fixed. I have the same problem with a Toon Thermostat selector switch. I'm sure Rob will fix it asap... please be patient in the meantime.maluko wrote:robgeerts wrote:
maluko
Re: New Dashboard Design v2, custom positioning and multiple screens
robgeerts wrote:
Will fix the celcius/fahrenheit switch.. changing ºC to ºF is enough?
Or do I have to recalculate the output?
EDIT: set in config.js:Code: Select all
var _USE_FAHRENHEIT = true;
Looks like the new setting switches it for sensors, but does not update weather coming from Weather Underground. For that I think you'll need to update weather.js
html += '<h2><span>'+Math.round(currentweather.temp_c)+'°C</span> <i class="wi '+wiclass+'"></i></h2>';
$(".weather").html('<i class="wi '+wiclass+'"></i>');
$(".weatherdegrees").html('<strong>'+Math.round(currentweather.temp_c)+'°C</strong><span class="rainrate"></span>');
$(".weatherloc").html(location);
html += '<div class="temp"><span class="dayT">'+curfor.high.celsius+'°C</span><span class="nightT">'+curfor.low.celsius+'°C</span></div>';
pkrabben
- Domoticz version: 3.5877
This Dashboard looks really nice.
Downloaded it and the first start is there
My knowledge about this is not that high but I need to play with it.
The start is already there
Can some give me some inside how to add the weather forecast or what I need to change.
robgeerts
- Domoticz version: 3.7067
Thanks, forgot to change this earlier, did only test with 2 screens...HansieNL wrote:Hello Rob,
If I change css from -100% to -200% 3rd page is shown. Can you check if the code in creative.css should be corrected?
.slide-radio3:checked ~ .fullslider {
-webkit-transform: translateX(-200%);
Fixed!irishv wrote: Looks like the new setting switches it for sensors, but does not update weather coming from Weather Underground. For that I think you'll need to update weather.js
Maartenkr
- Domoticz version: 3.7196
you must create an account at wunderground
and the information you fill in as following (in config)
var _APIKEY_WUNDERGROUND = 'apikey wunderground';
var _WEATHER_CITY = 'you place';
var _WEATHER_COUNTRY = 'NL';-
pkrabben
var _APIKEY_WUNDERGROUND = 'apikey wunderground'; var _WEATHER_CITY = 'you place'; var _WEATHER_COUNTRY = 'NL';
I have the following code in the config.js file
var _APIKEY_WUNDERGROUND = '53673cfb6708097f';
var _WEATHER_CITY = 'Almere';
robgeerts
The key you are using is not correct, this is the result from Wunderground:
"error": {
"type": "keynotfound"
,"description": "this key does not exist"
"error": {
pkrabben
Found the issue it was not recognizing 'Almere' needs to be 'Almere Stad' and created a new API key
robgeerts
Use 's1' where 1 is de idx of the scene or group.
pkrabben
Hi Rob thanks for your quick replyrobgeerts wrote:Use 's1' where 1 is de idx of the scene or group.
you mean in this line
columns[1] = {}
columns[1]['blocks'] = ['blocktitle_1',1,6,8,9,11,'blocktitle_2',s1,'blocktitle_4','train','traffic']
columns[1]['width'] = 5;
If I do that the dashboard is completly blanc
See below the IDX of the scene I'm looking to control "Lampen wk aan"
robgeerts
Add single quotes to s1
pkrabben
Thanks it's working.robgeerts wrote:Add single quotes to s1
I will buy you some beers later today
SwordFish
- Domoticz version: V4.11375
@Robgeerts,
This gets better and better
Can you add this door contact. Its now show with switch icon.
"ActTime" : 1491822723,
"ServerTime" : "2017-04-10 13:12:03",
"Sunrise" : "06:55",
"Sunset" : "20:26",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Closed",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"HardwareName" : "RFXCOM",
"HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
"HardwareTypeVal" : 1,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0EEED8E",
"Image" : "Light",
"InternalState" : "Closed",
"IsSubDevice" : false,
"LastUpdate" : "2017-04-10 13:11:16",
"Level" : 0,
"LevelInt" : 0,
"MaxDimLevel" : 15,
"Name" : "voordeur",
"Notifications" : "true",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : true,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "Closed",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "AC",
"SwitchType" : "Door Contact",
"SwitchTypeVal" : 11,
"Timers" : "false",
"Type" : "Lighting 2",
"TypeImg" : "door",
"Unit" : 10,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "121"
"status" : "OK",
"title" : "Devices"
Blueone
A very nice project! I want to replace my eneco toon with a raspberry with the original touchscreen and put in on the wall in my living room. The toon also have a stand-by view which is black and white and is very usefull when it is not in use and still can see the time etc without having a bright screen at the wall. Is there also an option available in this dashboard which opens a simple few after a few minutes. Please see the screenshot as an example.
Active: Standby:
Active: Standby:
robgeerts
Thanks!pkrabben wrote: I will buy you some beers later today
FixedSwordFish wrote: Can you add this door contact. Its now show with switch icon.
Not possible at the moment but will add this asap!Blueone wrote:The toon also have a stand-by view which is black and white and is very usefull when it is not in use and still can see the time etc without having a bright screen at the wall.
Clemen
Would be nice with a standby view that activates after x-min of inactivity, and goes away with a touch on the device.robgeerts wrote:Thanks!pkrabben wrote: I will buy you some beers later today
robgeerts
Almost done with that feature
pkrabben
I noticed when reading to the whole forum post that it should be possible to change the icon of a light_on to a yellow bulb.
I noticed the image in the img folder but where can you set to use that image when a light is turned on?
robgeerts
At the moment not possible anymore at the moment, I will fix this asap. Together with the possibility to change other icons as well.
