Locked
pvm
Domoticz version: 4.10538
Re: New Dashboard Design v2, custom positioning and multiple screens
Post by pvm »
Did some more testing today (also updated to version of 15 minutes ago)
An idea: can you supply a favicon.ico? that will give a nice icon on my ipad as shortcut
edit: other minor issue, the time isn't centered in the topright date/time box (the 1 at the end fits, a 2 does not fit in the box)
I have an issue, the domoticz data is not displayed on the ipad:
While as I was testing before in chrome with the ipad layout it works correctl, this image is made with the same version/config etc, but using chrome on windows
What can I do to analyse this issue?
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Hold on, I'll check my wife's ipad 2..
Edit: Yes, same issue, will try to fix this asap!
Meanwhile...
GRAPHS ARE LIVE (BETA!!!)
Download latest version from gitlab.
Enter the follow key in the definitions: 'graph_IDX', if your graph in Domoticz is idx 150, use:
columns[2]['blocks'] = ['graph_150']
ATTENTION: Only tested it with my energy and gas from Toon Thermostat!
Clemen
Post by Clemen »
pvm wrote:Did some more testing today (also updated to version of 15 minutes ago)
I had same issue on iPad, fixed it by making the last block with 3, and the middle block with 4 instead of 5
robgeerts
Post by robgeerts »
pvm wrote: An idea: can you supply a favicon.ico? that will give a nice icon on my ipad as shortcuts
Will do!
pvm wrote: edit: other minor issue, the time isn't centered in the topright date/time box (the 1 at the end fits, a 2 does not fit in the box)
Fixed!
Clemen
Post by Clemen »
robgeerts wrote:Hold on, I'll check my wife's ipad 2..
Meanwhile...
In latest version i get this 404 in log
http://10.200.0.4:8080/dashboard2/vendo ... in.css.map Failed to load resource: the server responded with a status of 404 (Not Found)
EdwinK
Post by EdwinK »
Latest version only give me a blank page :(
Edit: Seems to be fixed
robgeerts
Post by robgeerts »
EdKo66 wrote:Latest version only give me a blank page :(
Wich browser are you working in?
Maybe a typo in your config.js? Just testen in chrome, firefox and on my tablet.. works over here?
Clemen wrote: In latest version i get this 404 in log
Although this is not an issue, it should be fixed in latest version.
EdwinK
Post by EdwinK »
Seems to be working now. Redownloaded the files and now I see a nice graph. :
robgeerts
Post by robgeerts »
Cool :)
Screenshot? Just curious!
For now, I'm going to shut down my pc!
Good night everybody!
EdwinK
Post by EdwinK »
Page 1:
Page 2:
Clemen
Post by Clemen »
robgeerts wrote:Cool :)
Current is not present in every counter.
So for my watt graph it says undefined
Screen Shot 2017-04-08 at 23.13.44.png (282.32 KiB) Viewed 3242 times
It can be fixed with this in the graphs.js, its not the cleanest solution but i works :)
if (!current){
					current = '';
Screen Shot 2017-04-08 at 23.14.43.png (278.13 KiB) Viewed 3242 times
pvm
Post by pvm »
Thanks for fixing the clock not being centered, Goodnight!
I've tested the graph for PI temperature and CPU usage, it reports "PITemperature: undefined" and does not show a graph
another question, is it possible to show the current weather icon in 'currentweather_big' right now (while it is pretty dark) it shows a nice sunny icon. I'm not sure whether that kind of info is available?
robgeerts
Post by robgeerts »
Well, I have to extend the graph functionality to support more devices! Soon to come :)
(Got a notification on my phone. I just had to reply ;)
EdwinK
Post by EdwinK »
I know you are sleeping right now (or at least should by now), but could you one day find a way to remove the empty field above column 1
Image (need to find a better image host place)
EdwinK
Post by EdwinK »
Just kidding
robgeerts
Post by robgeerts »
(Send me your config via pm, so I can fix the empty row you have...tomorrow)
Clemen
Post by Clemen »
EdKo66 wrote:I know you are sleeping right now (or at least should by now), but could you one day find a way to remove the empty field above column 1
Paste your
columns[1]['blocks'] = [.......
HansieNL
Post by HansieNL »
Hello Rob,
- I tried to us a pattern picture as background, but the picture is just stretched. Can you fix that a pattern can be used? I also tried to load this background via custom.css in the body section, but didn't work either.
background:
radial-gradient(black 15%, transparent 16%) 0 0,
radial-gradient(black 15%, transparent 16%) 8px 8px,
radial-gradient(rgba(255,255,255,.1) 15%, transparent 20%) 0 1px,
radial-gradient(rgba(255,255,255,.1) 15%, transparent 20%) 8px 9px;
background-color:#282828;
background-size:16px 16px;
- I created a 3rd screen. I see the 3 screen dots at the bottom of the screen, but if I try to load 3rd screen the 2nd screen is shown.
I hope you can fix both some day... Thanks
Blah blah blah
Ierlandfan
Post by Ierlandfan »
Sweet dreams for now and days to come. And I think I speak for all of us when I say we all enjoy and appreciate the hard work you put in this every day! If anybody feels he deserves credits where credits are due..well..there's a button for that!
Bob123bob
Post by Bob123bob »
Is there a way to add Alert device type ?
Alert device
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "No weather alert",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 5,
         "HardwareName" : "Virtual Switches",
         "HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
         "HardwareTypeVal" : 15,
         "HaveTimeout" : false,
         "ID" : "82106",
         "LastUpdate" : "2017-04-09 08:10:01",
         "Level" : 1,
         "Name" : "Weather alert",
         "Notifications" : "true",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Alert",
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "Alert",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "107"
Locked
