Feature request: Set time widget
DutchHans
Post by DutchHans »
Good morning,
I have several scripts that start at a given time. Works all perfect..but it would be nice if you could change the execution time in a widget..similar as the "set temperature". For example: during the week waking up is a standard time,script starts a the same time,every workingday.. but in the weekends the starting of a script depends on what i have planned for that day..if i have to get out at 8 or at 10am..now you have to edit the script or open blockly..would be nice if a widget could be implemented, i guess..
Regards,Hans
strixx
Re: Feature request: Set time widget
Post by strixx »
+1 for this
I would also like this feature. My suggestion is a switch with active/inactive and set time. And the ability to schedule.
Then you would be able to:
Set an time on the dashbord, for example 07:00.
And you could schedule it to be active weekdays only.
And then make an script that turn on lights and starts the radio at the time set on the switch if it is active.
And.. You have a nice working alarmclock in Domoticz..
PDP8
Domoticz version: V4.9700
Post by PDP8 »
Hmm, I have to admit, I'm quite new here... But I'm a bit disappointed to see
this question because I expected a user friendly scheduler in Domoticz already...
In my opinion it is one of the basics for home automation. See my question here:
https://www.domoticz.com/forum/viewtopi ... 28#p128045
There is no way I can explain to other users to edit a script or edit events...
If there is no scheduler in Domotics I'd better install some other domitic software.
Regards, Roland
Users browsing this forum: Google [Bot], jvdz and 1 guest
