Please add support in the tty/serial/usb drop-down lists to select from id's instead of 'hard' ttyACM0/1/2...
The list in /dev/serial/by-id/ contains links to the appropriate ttyACMx.
This helps when the device is moved to another slot and thus can change ttyACMx -> ttyACMy and make Domoticz fail to connect.
Using ids this problem is removed.
Thanks,
Mikkel
List USB (ttyACM) devices by id
- Domoticz version: BETA
Re: List USB (ttyACM) devices by id
how about taking a different approach on that issue and assigning fixed ID's to the USB devices ?
There is a nice wiki article about that:
http://domoticz.com/wiki/PersistentUSBDevices
Yeah I guess that could work too, but just not as user friendly
/M
/M
- Domoticz version: last
it's a geek world here
