Locked
robgeerts
Domoticz version: 3.7067
Re: New Dashboard Design
Post by robgeerts »
In the latest beta (see gitlab)
You dont have to define every block in de blocks-variable:
blocks[204] = {}
ONLY if you dont want to use de default width:
blocks[204] = {}
blocks[204]['width'] = 6;
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Here you go
Setpoint
   "ActTime" : 1491421162,
   "ServerTime" : "2017-04-05 21:39:22",
   "Sunrise" : "07:06",
   "Sunset" : "20:18",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "20.4",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 23,
         "HardwareName" : "NEST",
         "HardwareType" : "Nest Thermostat/Protect",
         "HardwareTypeVal" : 52,
         "HaveTimeout" : false,
         "ID" : "0000001",
         "LastUpdate" : "2017-04-05 21:38:53",
         "Name" : "Thermostaat ingesteld op",
         "Notifications" : "false",
         "PlanID" : "12",
         "PlanIDs" : [ 12 ],
         "Protected" : false,
         "SetPoint" : "20.4",
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "SetPoint",
         "Timers" : "false",
         "Type" : "Thermostat",
         "TypeImg" : "override_mini",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "195"
   "status" : "OK",
   "title" : "Devices"
   "Sunset" : "20:18",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "20.4",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 23,
         "ID" : "0000001",
         "PlanID" : "12",
         "PlanIDs" : [ 12 ],
         "Timers" : "false",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "195"
   "status" : "OK",
   "title" : "Devices"
Temp and Humidity
   "ActTime" : 1491421297,
   "ServerTime" : "2017-04-05 21:41:37",
   "Sunset" : "20:18",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "20.0 C, 43 %",
         "Description" : "",
         "DewPoint" : "7.04",
         "Favorite" : 1,
         "HardwareID" : 23,
         "Humidity" : 43,
         "HumidityStatus" : "Comfortable",
         "ID" : "0002",
         "LastUpdate" : "2017-04-05 21:41:25",
         "Name" : "Woonkamer",
         "Notifications" : "true",
         "PlanID" : "12",
         "PlanIDs" : [ 12 ],
         "SubType" : "WTGR800",
         "Temp" : 20.0,
         "Timers" : "false",
         "Type" : "Temp + Humidity",
         "TypeImg" : "temperature",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "196"
   "status" : "OK",
   "title" : "Devices"
   "Sunset" : "20:18",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 23,
         "Humidity" : 43,
         "ID" : "0002",
         "PlanID" : "12",
         "PlanIDs" : [ 12 ],
         "Temp" : 20.0,
         "Timers" : "false",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "196"
   "status" : "OK",
   "title" : "Devices"
Heating on/off
   "ActTime" : 1491421622,
   "ServerTime" : "2017-04-05 21:47:02",
   "Sunset" : "20:18",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "On",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 23,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "ID" : "0000071",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-04-05 20:23:28",
         "Level" : 100,
         "LevelInt" : 15,
         "MaxDimLevel" : 15,
         "Name" : "Statenlaan Family Room HeatingOn",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "On",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 0,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "197"
   "status" : "OK",
   "title" : "Devices"
And Home/Away
   "ActTime" : 1491421670,
   "ServerTime" : "2017-04-05 21:47:50",
   "Sunset" : "20:18",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 23,
         "ID" : "0000003",
         "Image" : "Light",
         "LastUpdate" : "2017-03-28 16:40:20",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "Statenlaan Family Room Away",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "198"
   "status" : "OK",
   "title" : "Devices"
The last 2 i haven't tested yet
HansieNL
Post by HansieNL »
Did something change in latest Beta (dashboard (2).zip)?
The Venz M9 button should be next to Mede8er button. It was ok in 1st beta. (dashboard.zip). CONFIG.js is not changed.
Will it be possible in future version to add custom icons and text?
Blah blah blah
robgeerts
Post by robgeerts »
SwordFish wrote:Here you go
heggink wrote:Nest:
Dummy P1 device:
This is what I get in the latest BETA.
HansieNL wrote:Did something change in latest Beta (dashboard (2).zip)?
Hmm weird... could you send me your current config (only the blocks/columns part) and the output of Venz M9?
HansieNL wrote: Will it be possible in future version to add custom icons and text?
Yes, that's the plan :)
whiteduck
Post by whiteduck »
Thanks Rob - looking really good now with sunrise/sunset, the lux icon and the improved energy use.
There is still a gap with the Energy and Energy today shown the following as you don't know what has used the energy :)
Thanks a lot
Ian
Domoticz on Ubuntu 16.04 LTS VM
RFXCom USB transceiver
Aeon Labs V2 USB (Zwave)
Various HomeEasy, Oregon devices and sensors. Now using Z-Wave Fibaro FGMS-001, TKB TZ88Es
TP-Link IP310 Cameras
SwordFish
Post by SwordFish »
heggink wrote:Nest:
Dummy P1 device:
Looks good.
SwordFish
Post by SwordFish »
is it possible to change the textsize and image from the currentweather?
I want to replace "weersvoorspelling" with the currentweather
robgeerts
Post by robgeerts »
whiteduck wrote:Thanks Rob - looking really good now with sunrise/sunset, the lux icon and the improved energy use.
Thanks a lot
Ian
I've tested with some of your device.
Do you want something like:
This is the result in the latest version wich I will publish later today.
robgeerts
Post by robgeerts »
SwordFish wrote:is it possible to change the textsize and image from the currentweather?
This will be possible in latest version, publishing today/tonight:
SwordFish
Post by SwordFish »
Thanks man
robgeerts
Re: New Dashboard Design v2
Post by robgeerts »
LATEST VERSION ON GITLAB!
In this version its possible to set a custom position per block!
BACKUP YOUR CURRENT DASHBOARD.
Please share a screenshot when done configuring :)
robgeerts
Post by robgeerts »
SwordFish wrote: Thanks man
Checkout the latest version in gitlab.
Use 'currentweather_big' in config js, example:
columns[2] = {}
columns[2]['blocks'] = ['currentweather_big','weather',5,145,97];
columns[2]['width'] = 5;
SwordFish
Re: New Dashboard Design v2, with custom positioning
Post by SwordFish »
Thanks for the big weather.
I just move this dashboard to my pi so that it displayed on my Tab 3 but it is verry small :?
robgeerts
Post by robgeerts »
It look likes your zoomed out or something..
What if you zoom in?
EdwinK
Post by EdwinK »
This is how it looks atm. Just put some of the KaKu/CoCo switches in there so it doesn;'t look too empty :)
next thing is to put it to work on my Tab3, but that would be for some other day.
SwordFish
Post by SwordFish »
My fault, i did set the initial-scale to 0,5 last night and i forgot that i did it :oops:
But is it possible to make 2 columns in this view instead of one?
SwordFish
Post by SwordFish »
I just downloaded the last version with auto position.
But when i set it to false and set use favorites to false or true and removed the quote's to custom positioning i get a white screen as dashboard.
When i set auto position to true and use favorites to true and out quote custom positioning it is working?
robgeerts
Post by robgeerts »
SwordFish wrote:I just downloaded the last version with auto position.
Could you show me a screenshot of the console-window (F12) ?
SwordFish
Post by SwordFish »
Found the problem. I had to quote out the text "CUSTOM POSITIONING:" in the config file.
heggink
Domoticz version: 12451
Post by heggink »
Hey Rob,
I kind of lost track of how the new template is supposed to work with the blocks and all (I was pretty happy with the default behaviour). Any chance you can explain a bit in the README how to configure this? I installed the version of yesterday evening but didn't entirely get how it is supposed to work.
I can confirm that the Thermostats work as well as the dummy p1 so many thanks for that. Looks really nice! Well done.
H
P1 meter & solar panel
Locked
