RaspberryPi - MAINS AC Dimmer Setup
trackerj
Post by trackerj »
This time we will directly connect the MPDMv4 MAINS AC Dimmer board to a Raspberry PI and we will drive it using the PWM signal provided by the RPi Board thru the onboard gpio extension header:
https://www.youtube.com/watch?v=wqY4-gHqvZI
Related Article with source code: http://www.esp8266-projects.com/2017/04 ... art-1.html
In Part 2 we will continue with the related Domoticz setup & tests.
trackerj
Re: RaspberryPi - MAINS AC Dimmer Setup
Post by trackerj »
Part 2: Domoticz Setup and live testing:
https://www.youtube.com/edit?o=U&video_id=z-eSTDL9qdY
Related source code can be found in the related post here: http://www.esp8266-projects.com/2017/04 ... immer.html
