Locked
whiteduck
Re: New Dashboard Design
Post by whiteduck »
Suggested enhancements
1. An icon for a door open/close sensor.
2. In here - W-Visibility is a Wunderground device and 3. can we get an icon for the Alarms.
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "10.0 km",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 4,
         "HardwareName" : "Wunderground",
         "HardwareType" : "Weather Underground",
         "HardwareTypeVal" : 14,
         "HaveTimeout" : false,
         "ID" : "0",
         "LastUpdate" : "2017-04-04 19:48:18",
         "Name" : "W-Visibility",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "Visibility",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "General",
         "TypeImg" : "visibility",
         "Unit" : 1,
         "Used" : 1,
         "Visibility" : 10.0,
         "XOffset" : "0",
         "YOffset" : "0",
         "forecast_url" : "aHR0cDovL3...",
         "idx" : "29"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 100,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "AeonZW",
         "HardwareTypeVal" : 21,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "ID" : "00000729",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2015-12-22 14:03:16",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "Fibaro Smoke Alarm",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "Smoke Detector",
         "SwitchTypeVal" : 5,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "smoke",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "35"
If you have some tips/simple instructions the community can contribute code snippets and icons and distribute the workload - happy to help if I can...
Thanks again and all the best
Ian
Domoticz on Ubuntu 16.04 LTS VM
RFXCom USB transceiver
Aeon Labs V2 USB (Zwave)
Various HomeEasy, Oregon devices and sensors. Now using Z-Wave Fibaro FGMS-001, TKB TZ88Es
TP-Link IP310 Cameras
pvm
Domoticz version: 4.10538
Post by pvm »
robgeerts wrote:I'm also searching for a cheap tablet, only using it for this dashboard, for mounting on my wall. (I have one but the screen is broken) Tips anyone?
I've ordered "Teclast x80 pro 8 ''tablet pc intel x5 z8350 8 inch 1200*1920 Pixels IPS Scherm Windows 10 + Android 5.1 2 GB/32 GB HDMI Tablet PC" last week (Aliexpress, 88 euro, special price).
Goal is to use this as tablet for Domoticz control with your dashboard. I did not receive this however cannot tell about my experiences.
Reasons for choosing this
  • High resolution screen 1920*1200
  • dual boot Android (used on a way too old tablet before, was running fine including automatic turn on of screen when passing by. For what i've found out not possible to do that on an iPad (otherwise i'd prefer ios because all other devices are))
  • dual boot windows support, nice to play around and see if that's the better option for running a domoticz dashboard
  • intels latest Z8350 processor
pvm
Post by pvm »
irishv wrote:...
1) having the background switch based on time of day or weather
Irishv, you can give this a try: https://codepen.io/jamesbarnett/pen/kdDBL
whiteduck
Post by whiteduck »
whiteduck
Post by whiteduck »
A couple of errors I spotted in the debug console on Safari:
all the best
Ian
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Dynamic wrote: I totally agree on this. I really love this new design, but 'easy' customizing is a bit difficult. You added support for the RFXmeter-devices (so I can show my temperatures from the cityheating), but there are other RFXmeter-devices in my environment that I don't want to show on the dashboard.
I'm not a programmer, but a better approach could be something like this. That way it is easy to add support for other devices and we can add manual extra devices to the dashboard.
	<div class="wrapper">
		<div class="column-1">
			<script>ShowModule('fav_scenes');</script>
			<script>ShowModule('fav_switches');</script>
			<script>ShowModule('fav_dimmers');</script>
		</div>
		<div class="column-2">
			<script>ShowModule('weather_forecast');</script>
			<script>ShowModule('players');</script>
			<!-- manual added devices below.
				first parameter is IDX, second the type of device, then the custom icons (if nothing specified, the default icon is used), then a custom text is appended behind the value (for example, if a RFX-meter is device is used but the value is in GJ
			<script>ShowDevice('421','switch','iconon.png','iconoff.png');</script>
			<script>ShowDevice('41','energy','power.png','kWh');</script>
			<script>ShowDevice('321','temp','temp.png','');</script>
		</div>
		<div class="column-3">
			<script>ShowModule('clock');</script>
			<script>ShowModule('buttons');</script>
		</div>
	</div>
I agree too, this is a big change so can take a bit longer dan usual ;)
whiteduck wrote: @robgeerts - thanks a lot for the quick update. I will make a PayPal donation for a coffee or two!
Thank you very much!
I decided to save the donations for buying a new tablet on my wall ;)
whiteduck wrote: The lamp socket which has power usage appears as two blocks but they are out of step (one is ON the other OFF) and you cannot switch the lamp on/off with the energy one because of course the name doesn't match the device - it matches the device-watts.
whiteduck wrote: In this one the pump appears as a light in the energy block
Could you send me (als possible via PM) your COMPLETE json output?
I see some more things I would like to fix with your devices
whiteduck wrote: The Energy needs to be watts but is m3 like Gas.
My proposed code fix snippet is here
else if(data.result[r]['Type']=='General' && data.result[r]['SubType']=='kWh'){
                                                        var html = getStateBlock(data.result[r]['idx']+'a','fa fa-plug',lang.energy_usage,number_format(data.result[r]['Usage'],2,',','.')+' watts');
                                                        $('.states').append(html);
                                                        var html = getStateBlock(data.result[r]['idx']+'b','fa fa-plug',lang.energy_usagetoday,number_format(data.result[r]['CounterToday'],2,',','.')+' kWh');
                                                        var html = getStateBlock(data.result[r]['idx']+'c','fa fa-plug',lang.energy_totals,number_format(data.result[r]['Data'],2,',','.')+' kWh');
Fixed in latest version, although, I used 'W' instead of watts.
(If we use the official notation for kilowatts (kWh), we should use it for watts (W) ;)
whiteduck wrote:Suggested enhancements
Fixed in latest version!
pvm wrote: I've ordered "Teclast x80 pro 8 ''tablet pc intel x5 z8350 8 inch 1200*1920 Pixels IPS Scherm Windows 10 + Android 5.1 2 GB/32 GB HDMI Tablet PC" last week (Aliexpress, 88 euro, special price).
When do you expect it?
Please tell me your experience when you installed it!!
whiteduck wrote:A couple of errors I spotted in the debug console on Safari:
Fixed the first one (images not defined)
pvm
Post by pvm »
I'm not sure, probably will take a few weeks, according to tracking it is at HongKong airport now...
pvm
Post by pvm »
Pretty minor issue
The weather prediction title doesn't have a dark background as the other titles have, see:
I'm using the version of about 22:50 today. I really like the new updates with the image and button options
whiteduck
Post by whiteduck »
Thanks a lot Rob - PM sent.
I had another idea for the Dashboard and that is to have sunset/sunrise as per Domoticz - available in the json output.
All the very best
Ian
whiteduck
Post by whiteduck »
HOWTO initial input:
Thought it would be useful to help create a HOWTO with what I know so far.
To install dashboard cd to www directory of domoticz - you can of course use your own web server but if you use IP addresses in CONFIG.js make sure it is on your local LAN
git clone https://gitlab.com/robgeerts/dashboard.git
This creates and populates a directory called dashboard with Rob's directory structure from gitlab - move into this directory (cd)
Edit the CONFIG.js with your preferred editor and enter your language, domoticz server:port, background selection and API key for WUnderground if you use it - you can find this in Domoticz -> Setup -> Hardware
var _LANGUAGE                           = 'en_US';
var _HOST_DOMOTICZ                      = 'http://192.168.0.10:8080';
var _APIKEY_WUNDERGROUND        = 'your key';
var _WEATHER_CITY               = 'pws:IENGLAND560';
var _WEATHER_COUNTRY            = 'UK';
var _USE_DUTCH_TRAFFICINFO      = false;
var _USE_DUTCH_TRAININFO        = false;
var _BACKGROUND_IMAGE           = 'bg4.jpg'
Comment out any sections you don't want with //
To change the page layout edit the file index.html
To exclude any specific devices edit main.js found in dashboard/js directory - there is a loop and you can modify the code to include or exclude your specific devices. Note only devices you mark with a star in Domoticz i.e. a Favourite will appear.
Now head to a browser and enter http://192.168.0.10:8080/dashboard/index.html - you should see the webpage load - if you have blank boxes then perhaps you need to provide a username and password within CONFIG.js as suggested in the README.md
If the weather is missing check your API key and check the City you provided is valid or is the reference of a personal weather station (pws: NAME) - in my case pws:IENGLAND560 which is local to me.
Remember as Rob points out any Domoticz upgrades will blow away this directory - please back up what you need!
Good luck
Ian
HansieNL
Post by HansieNL »
EdKo66 wrote:
robgeerts wrote: You can select the desierd temperature.
Tested this with my own Toon and it works.
For my, 16 C is off, so I use that temperature if I want to set it off.
Could you test if this is working?
Seems to work for me too. :)
Tanks. Great job :!: :D
I've moved the Toon Setpoint to my switches block, because that's more logical for me. I already had a Thermostat Selector Switch in that block.
I tried to get a setpoint value to the status block (like in previous versions), but can't get it to work. Can you give me a hint please.
This is what I tried:
else if((data.result[r]['Type']=='Thermostat' || data.result[r]['HardwareType']=='Toon Thermostat') && data.result[r]['SubType']=='SetPoint'){
	$('.block'+data.result[r]['idx']).remove();
	var switchHTML = '<div class="col-md-4 block'+data.result[r]['idx']+'">';
	switchHTML+='<div class="col-md-4">';
				switchHTML+='<img src="img/heating_on.png" class="on icon" style="max-height:35px;" />';
			switchHTML+='</div>';
			switchHTML+='<div class="col-md-8">';
				switchHTML+='<strong class="title">'+data.result[r]['SetPoint']+'°C</strong><br />';
				switchHTML+='<span class="state">'+data.result[r]['Name']+'</span>';
	$('.states').append(switchHTML);
Blah blah blah
ddahya
Post by ddahya »
ddahya wrote:Great Dashboard, keep up the good work.
i've downloaded the latest version and most of my devices are working, any chance of adding blind support to the dashboard?
The blinds are showing up as on/off devices but should be On/Off/Stop, also i have some dummy setpoint devices i use to control my neohub Thermostats that are also on/off devices.
json output for rflink blinds and Setpoint device
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "YOffset" : "0",
         "idx" : "86"
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "104"
Could you send me the webaddress domoticz calls when clicking the blind-buttons (all three)?
The thermostat setpoints should work now, could you test this? Because another user said the buttons doesnt do anything?[/quote]
Here is the webaddress for the blinds for up/down/off
/json.htm?type=command&param=switchlight&idx=<IDX>&switchcmd=Off&level=0&passcode=
/json.htm?type=command&param=switchlight&idx=<IDX>&switchcmd=Stop&level=0&passcode=
/json.htm?type=command&param=switchlight&idx=<IDX>&switchcmd=On&level=0&passcode=
Also tested Setpoint with latest version, this is working now before it was just on/off. Just wanted to know if you could extend the setpoint range from 16 - 21.5 to 12 - 25? when my thermostats are in standby they are set to 12 degrees and when heating is more than 21.5 degrees
robgeerts
Post by robgeerts »
pvm wrote:Pretty minor issue
The weather prediction title doesn't have a dark background as the other titles have, see:opmaak.png
whiteduck wrote: I had another idea for the Dashboard and that is to have sunset/sunrise as per Domoticz - available in the json output.
To hide, use:
var _SHOW_SUNRISE = false;
HansieNL wrote: I've moved the Toon Setpoint to my switches block, because that's more logical for me. I already had a Thermostat Selector Switch in that block.
I moved it by default in latest version, It's more logical indeed, because there are all other switches too.
HansieNL wrote: I tried to get a setpoint value to the status block (like in previous versions), but can't get it to work. Can you give me a hint please.
Fixed in latest version.
ddahya wrote: Here is the webaddress for the blinds for up/down/off
Fixed in latest version BUT, I CANNOT TEST THIS, could you do that for me?
ddahya wrote: Also tested Setpoint with latest version, this is working now before it was just on/off. Just wanted to know if you could extend the setpoint range from 16 - 21.5 to 12 - 25? when my thermostats are in standby they are set to 12 degrees and when heating is more than 21.5 degrees
Extended the range in latest version!
EdwinK
Post by EdwinK »
Almost as if I want it for me to look :) Almost.
Just the two bottom (wind and barometer) should go up a little more.
*note to self: move all of the 'states', including the last </div> to just above 'sliders'.
ddahya
Post by ddahya »
Extended the range in latest version![/quote]
Just tested, blinds are not working, was looking at the logs and noticed that the command had a lowercase. I'm pretty sure the commands need to be "On", "Off", "Stop". the command sent was "on","off","stop".
ddahya
Post by ddahya »
Just tested, blinds are not working, was looking at the logs and noticed that the command had a lowercase. I'm pretty sure the commands need to be "On", "Off", "Stop". the command sent was "on","off","stop".[/quote]
Just updated lines 510 - 512 in the main.js with
													switchHTML+='<a href="javascript:switchBlinds('+data.result[r]['idx']+',\'Off\');"><em class="fa fa-arrow-up fa-small"></em></a> ';
													switchHTML+='<a href="javascript:switchBlinds('+data.result[r]['idx']+',\'Stop\');"><em class="fa fa-stop-circle fa-small"></em></a> ';
													switchHTML+='<a href="javascript:switchBlinds('+data.result[r]['idx']+',\'On\');"><em class="fa fa-arrow-down fa-small"></em></a>';
all working now
robgeerts
Post by robgeerts »
ddahya wrote: Just updated lines 510 - 512 in the main.js with
all working now
Fixed in latest version too!
EdKo66 wrote: Just the two bottom (wind and barometer) should go up a little more.
Could you test if this is working, add to creative.css:
.states > div {
	height:75px;
#switches > div {
	height:85px;
(or download latest version)
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Great work with this Dashboard.
I have a questing, how can i rearrange the positions off the states?
What i mean is that i like the powerstates on one row etc.
robgeerts
Post by robgeerts »
SwordFish wrote:Great work with this Dashboard.
Well, not possible at the moment but i'm working on it!
SwordFish
Post by SwordFish »
Thanks, take you're time.
Locked
