Milight directly with nRF24Lo1 without RFlink / arduino mega
CaptainSlow
L & G's
I was wandering if anybody has exprience with connection milights directly (without RFlink gateway, arduino mega) to the raspberry using the software of this german guy. I installed the stuff without any problems and now I need to now how to create the devices triggering scripts or something sending the commands to the milight buldbs via the nRF24.
http://torsten-traenkner.de/wissen/smar ... ilight.php Would love to get this working...lean and mean....
willem
willem
____________________________________________________________________
Raspberry PI 3 Model B with USB stick, Domoticz Stable, OTGW LAN with ESP wifi-bridge and Isense Thermostat using the Outside Temp from Buienradar via Domoticz, Milight Ibox-2(V6)
CaptainSlow
Re: Milight directly with nRF24Lo1 without RFlink / arduino mega
I just bought a couple of nRF24L01 from alieexpress together with the handheld remote from milight. I thought I might give it go to get this working.
I created a dummy switch in Domoticz quit simple and with the Openmilight process running on the raspberry I should be able to initiate simple scripts allowing me to send any milight command to the bulbs.
Any thoughts on this?..do miss something completely...?
thx in advance
willem
thx in advance
willem
NietGiftig
- Domoticz version: V3.6224
Yes I would think so.CaptainSlow wrote: ..do miss something completely...?
What software/drivers are you using to tell l the nRF24Lo1 what to send/recieve
For example like the software in the RFLink/Arduino
Or do you expect that the raspberry does this for you without you telling how to do this?
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
CaptainSlow
Well,..offcourse i'm not an expert but I do have openlight software using the RF24 libraries running. I can start openlight and put it in listeningn and sending mode. I added a screenshot. You can find the whole article here
I was thinking if I create dummy switch intiating a script with the command I might be in the ballpark but maybe I'm wrong....
I just ordered the radiochips and the remote from milight. I need the remote to identify the pairing link id and I should be able to do this with the raspberry with openmilihgt in listening mode.
NietGiftig
Maybe the milight dev page has some usable code
http://www.limitlessled.com/dev/
tontze
- Domoticz version: Beta Ch
Very interesting topic, i just ordered few milight rgb´s and wifi controller and wall switch to control. Please keep us updated ! Good luck !
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Did not try this on the RPI, but I have used the openmilight code on an Arduino + NRF24L01 transceiver, and that worked.CaptainSlow wrote:I just bought a couple of nRF24L01 from alieexpress together with the handheld remote from milight. I thought I might give it go to get this working.
Sidenote : The openmilight is limited to sending the older Milight protocol (like RGBW) and does not support the newer RGBWW protocol. The RGBWW protocol is encrypted, and the encryption method is not yes re-engineered.
Since I do not have an RGBW lamp or controller I used the Milight iBox1 for testing. There are 2 ways to instruct the Ibox to send the RGBW protocol:
- use the Milight3.0 app,select the RGBW remote, and push the buttons
- Use Domoticz, configure the RGBW light, and push the buttons
In both cases the Arduino with the Openmilight sketch receives the Milight RGBW command sent by the iBox, something like:
B0 08 61 15 00 01 E8 ............
B0 08 61 15 00 01 E9 .........
B0 08 61 18 00 0F EA ..
B0 08 61 18 00 0F EB ...But you will need additional steps to "connect" the openmilight code on the Rpi to Domoticz, like a script something like:
- if openmilight receives a valid RGBW command then send a JSON to Domoticz to activate a dummy switch.
And a similar script to activate the openmilight send routine.
Let us know how it goes.
burton666
I have been searching and trying alot of alternatives and the best I have found is "atomik controller". Same procedure as the alternative in this thread, you wire a NRF2401+ radio to a raspberry pi (an old Rpi 1 works great)
https://bitbucket.org/CanadianRepublica ... ontroller/
In the link there is a download-link for an sdcard image that you just plug in your rpi (you can also install everything manually if you have the skills).
When complete you can log in to a webgui and pair/unpair lights directly from the webgui. No original controller or mobile is needed. You can also then use a script to turn on/off/dim change color etc. from domoticz.
Only thing I remember was a little problematic was how to set it all up the first time as I missed one step. You have to add lightbulb, create a zone to add the bulb to and also create a remote and add it to the zone. Everything is done in the gui.
