pychromecast get device but not the status - Need help :(
Thecyp31
Post by Thecyp31 »
Hello all !
So i tried to get the status of my chromecast with pychromecast.
I have a ubuntu server 16 with the latest version of pychomecast.
When i run this scripts (is under pychromecast folder) :
from __future__ import print_function
import time
import sys
import logging
import json
import codecs
import urllib
import pychromecast
cast = pychromecast.Chromecast("192.168.xx.xx")
print(cast.device)
print(cast.status)
print(cast.media_controller.status)
i have this result :
DeviceStatus(friendly_name=u'Salon', model_name=u'Eureka Dongle', manufacturer=u'Google Inc.', api_version=(1, 0), uuid=UUID('xx'), cast_type='cast')
None
<MediaStatus {'player_state': 'UNKNOWN', 'volume_level': 1, 'images': [], 'media_custom_data': {}, 'duration': None, 'current_time': 0, 'playback_rate': 1, 'title': None, 'media_session_id': None, 'volume_muted': False, 'supports_skip_forward': False, 'track': None, 'season': None, 'idle_reason': None, 'stream_type': 'UNKNOWN', 'supports_stream_mute': False, 'supports_stream_volume': False, 'content_type': None, 'metadata_type': None, 'subtitle_tracks': {}, 'album_name': None, 'series_title': None, 'album_artist': None, 'media_metadata': {}, 'episode': None, 'artist': None, 'supported_media_commands': 0, 'supports_seek': False, 'current_subtitle_tracks': [], 'content_id': None, 'supports_skip_backward': False, 'supports_pause': False}>
But i be have "player_state : Idle" and not UNKNOW.
I don't understand my probleme because the value of cast.status is good ! :(
Thanks !
Thecyp31
Re: pychromecast get device but not the status - Need help :(
Post by Thecyp31 »
Help ^^ :)
Ewaldharmsen
Post by Ewaldharmsen »
what does it have for a value when you play youtube or netflix?
triton
Domoticz version: 4.9701
Post by triton »
Don't know if this helps you. I've looked at pychomecast but wanted something simpler to get the casting state and discovered they use MDNS which also returns the current connected casting application. If you use a Raspberry pi install the avahi-utils and you can use:
avahi-browse -rt _googlecast._tcp
which returns something like below for every Chromecast it can find on your network:
+   eth0 IPv4 Chromecast-90580754da3ed1b3e4be38c9b277bc9b   _googlecast._tcp     local
=   eth0 IPv4 Chromecast-90580754da3ed1b3e4be38c9b277bc9b   _googlecast._tcp     local
   hostname = [90580754-da3e-d1b3-e4be-38c9b277bc9b.local]
   address = [192.x.x.x]
   port = [8009]
   txt = ["rs=Netflix" "bs=DE34FSD4WDS4" "st=0" "ca=4101" "fn=Chromecast_1" "ic=/setup/icon.png" "md=Chromecast" "ve=05" "rm=" "id=90580754da3ed1b3e4be38c9b277bc9b"]
If you look at the txt line you can see "rs=Netflix" Means Netflix is connected to the chromecast. It does not give me a state such as paused, playing etc. But this was all I wanted and you can write a wrapper script in any language that suits you best and feed Domoticz the info.
Hope it helps!
