Hi there,
I've successfully included Fibaro FGWPE Wall Plug into my network, but I can not find any energy consumption counter device instance in Device list. Got 3 Light/Switch devices (Switch, Alarm Type, Alarm Level) and 4 Usage devices, but all of them display values in Watts. None of them show energy consumed. But in the Control Panel I can see Energy value in kWh together with two (why two?) Power values in Watts. What I did wrong? Is there some workaround to fix this problem?
Can not find energy counter device (Fibaro Wall Plug)
unitedeurope001
Re: Can not find energy counter device (Fibaro Wall Plug)
Try Restart - this helped in my case
Also: Check if the device with consumption is sorted somewhere else in the device list and set to visible
Good luck
Good luck
OutThere
- Domoticz version: 3.5877
Thank you, unitedeurope001. Restart of the controller helped in this case too.
