Locked
robgeerts
Domoticz version: 3.7067
Re: New Dashboard Design
Post by robgeerts »
I understand but sometimes, when adding functionality, I have to add variables to CONFIG.js...
And last days I changed index.html to be more dynamic. Sorry for the inconvenience ;)
HansieNL
Post by HansieNL »
@robgeerts
Great job you do with this dashboard. Three thumbs up!
My Toon thermostat (setpoint) is still recognized as switch. Should this one be recognized as thermostat already? Am I missing something maybe? Would be great if this one is gonna be recognized as setpoint.
Can you add a Paypal button to this project Gitlab page... then we can buy you a drink :)
This is for the Toon Thermostat setpoint:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "19.0",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"HardwareName" : "Toon Thermostaat",
"HardwareType" : "Toon Thermostat",
"HardwareTypeVal" : 34,
"HaveTimeout" : false,
"ID" : "0000001",
"LastUpdate" : "2017-03-27 17:36:55",
"Name" : "Thermostaatinstelling",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"SetPoint" : "19.0",
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "SetPoint",
"Timers" : "false",
"Type" : "Thermostat",
"TypeImg" : "override_mini",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "35"
Blah blah blah
Dynamic
Post by Dynamic »
I downloaded the latest files, to add my sonos speakers. But now the icons with current energy consumption etc. are gone. How can I add them back in?
pvm
Domoticz version: 4.10538
Post by pvm »
Would be nice to have the configurable domoboard setup. No need to change multiple files and code html. Too bad I'm not able to do that
EdwinK
Post by EdwinK »
And I see that you again have already fixed the Buienradar wind block. Thanks for your quick responses and fixes.
robgeerts
Post by robgeerts »
HansieNL wrote:@robgeerts
https://www.paypal.com/cgi-bin/webscr?c ... ostedGuest
HansieNL wrote: This is for the Toon Thermostat setpoint:
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "19.0",
"Description" : "",
"Favorite" : 1,
"HardwareID" : 7,
"ID" : "0000001",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Timers" : "false",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "35"
In the latest version it's a button with a temperature-icon. (Moved to middle column because the other toon-blocks (temperature and energy are also positioned in that column)
Dynamic wrote:I downloaded the latest files, to add my sonos speakers. But now the icons with current energy consumption etc. are gone. How can I add them back in?
Do you have a screenshot, they do work on my dashboard...
pvm wrote: Would be nice to have the configurable domoboard setup. No need to change multiple files and code html. Too bad I'm not able to do that
Everyday I'm trying to make the dashboard better, piece by piece..
Are you also changing the index.html manually every time you update? If yes, what are you changing? Maybe I can make a quickfix for you (So you wont have to change anything).
EdKo66 wrote:And I see that you again have already fixed the Buienradar wind block. Thanks for your quick responses and fixes.
You're welcome!
HansieNL
Post by HansieNL »
@robgeerts
Enjoy your beer :)
Something is going wrong with the Toon thermostat setpoint. Every second there's added a new setpoint button :lol: ;)
I did add the red text and adding new setpoint button stopped, but I don't know if it has other side effects?
if(!sliding){
$('.solar').remove();
$('#mains').html('');
$('#switches').html('');
$('#groups').html('');
$('#sliders').html('');
$('.states').html('');
for(r in data.result){
I also did change the text in the Toon thermostat setpoint button a little:
switchHTML+='<strong class="state">'+data.result[r]['SetPoint']+'°C</strong><br />';
switchHTML+='<span class="title">'+data.result[r]['Name']+'</span>';
Now the temperature (value) is on top like the other values.
Blah blah blah
irishv
Post by irishv »
Thanks for creating this. I've been wanting to build a better dashboard to use with a mounted iPad for a while now but could never get started. I run Domoticz on Synology NAS with the Aeon Z-stick.
I downloaded the files and was able to connect to my server, adjust language to english and weather to fahrenheit. My favorites come in, but everything shows as light switches. I'm trying to get contact sensors (doors) and motion sensors to say open/closed and motion/no motion.
Also, I added the following code to index.html get the page to load as a standalone app in iOS if you save it to the home screen.
<meta name="apple-mobile-web-app-capable" content="yes">
Sample door sensor:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Closed",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 3,
         "HardwareName" : "Aeon Z-Stick",
         "HardwareTypeVal" : 21,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "ID" : "00001A00",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-03-06 08:04:07",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 100,
         "Name" : "Sensor-Garage",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Closed",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "Contact",
         "SwitchTypeVal" : 2,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "contact",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "62"
And a sample motion sensor:
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 100,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 3,
         "ID" : "00000A00",
         "Image" : "Light",
         "LastUpdate" : "2017-03-31 21:07:28",
         "Level" : 0,
         "LevelInt" : 0,
         "Name" : "Multisensor Motion",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SwitchType" : "Motion Sensor",
         "SwitchTypeVal" : 8,
         "Timers" : "false",
         "TypeImg" : "motion",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "32"
Two wish-list features would be 1) having the background switch based on time of day or weather and 2) the ability to control Synology's Audio Station like you did for Sonos and Logitech Media Server. I have Audio Station running to several Airport Expresses around the house and would love to just be able to start and stop a single playlist.
pvm
Post by pvm »
I had the same issue as Dynamic. That was a reason for my remark, it took me some time to get things back to original. Indeed changing the html.
I totally agree with your however, it's good in basis and gets even better every day (or even multiple times a day:) )
Hope to have some more time next week to pay with this and get the parts which are not showing on my tablet to work.
pvm
Post by pvm »
irishv wrote:2) the ability to control Synology's Audio Station like you did for Sonos and Logitech Media Server. I have Audio Station running to several Airport Expresses around the house and would love to just be able to start and stop a single playlist.
At you able to do this from Domoticz now?
robgeerts
Post by robgeerts »
Enjoy your beer :)
Thank you very much!
if(!sliding){
Fixed both in latest version :)
irishv wrote: Also, I added the following code to index.html get the page to load as a standalone app in iOS if you save it to the home screen.
Added in latest version!
irishv wrote:I'm trying to get contact sensors (doors) and motion sensors to say open/closed and motion/no motion.
Try to add this asap!
EdwinK
Post by EdwinK »
Almost all of the cells nice and orderly on the screen.
These are the only ones refusing to play nice.
Image it must have something to do with the name of the 'Energie vandaag' cell, being a bit to big.
Also, would it be possible to move those to the left of the 'muziekspelers' section instead of under it?
EdwinK
Post by EdwinK »
Enjoy your coffee(s)
robgeerts
Post by robgeerts »
pvm wrote: I had the same issue as Dynamic. That was a reason for my remark, it took me some time to get things back to original. Indeed changing the html.
Well, in the current version I've added a CONFIG-DEFAULT.js.
I will extend this file with new variables. If there are new variables, you can copy them to the CONFIG.js.
In this way your config.js wont be overwritten again.
About index.html; I'm trying to edit this file not too much.
I just released a new version of the dashboard. I'm hoping I dont have to edit index.html again soon...
EdKo66 wrote: These are the only ones refusing to play nice.
I've changes the CSS, I think its better now, otherwise, you could rename 'Energie vandaag' in /lang/nl_NL.js (just added multiple language support)
EdKo66 wrote: Also, would it be possible to move those to the left of the 'muziekspelers' section instead of under it?
Do you mean under the switches?
Thanks for the coffee!
EdwinK
Post by EdwinK »
Yes, under the switches would be good for me.I don't have a big tablet, so if I can save on scrolling, it would be nice :)
robgeerts
Post by robgeerts »
In index.html you can move:
<div class="players"></div>
to just after:
<div id="switches"></div>
EdwinK
Post by EdwinK »
Ow,. That is easy. Even *I* can do that
EdwinK
Post by EdwinK »
Almost there :)
irishv
Post by irishv »
No, I should have been more clear. I can't currently do this in Domoticz, but some others have found the right way to send requests. More of a longer term thing I would need to figure out on my own.
irishv
Post by irishv »
Awesome, thanks for your work!
Locked
