Locked
robgeerts
Domoticz version: 3.7067
Re: New Dashboard Design
Post by robgeerts »
pvm wrote:EdKo66 / robgeerts
To control the player you need the following urls
I've added this in the latest version, could you check this?
Backup the old version of the dashboard!
EdwinK
Post by EdwinK »
Sorry, do not have time today to integrate this in the dashboard... I would also have to look into adding buttons and behaviour... EdKo66, can you help?
I'll see what I do, but since I'm not a programmer/coder it would not be much.
robgeerts
Post by robgeerts »
pvm wrote:The slider does not work for my fibaro dimmer as its expecting a 0-100% value
Like 71%:
/json.htm?type=command&param=switchlight&idx=26&switchcmd=Set%20Level&level=71
information on this dimmer
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Set Level: 70 %",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 6,
         "HardwareName" : "Aeonlabs Z-wave stick",
         "HardwareTypeVal" : 21,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "00001301",
         "Image" : "Light",
         "IsSubDevice" : false,
         "LastUpdate" : "2017-03-30 00:34:26",
         "Level" : 70,
         "LevelInt" : 70,
         "MaxDimLevel" : 100,
         "Name" : "Dimmer2tst",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Set Level: 70 %",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "Switch",
         "SwitchType" : "Dimmer",
         "SwitchTypeVal" : 7,
         "Timers" : "false",
         "Type" : "Light/Switch",
         "TypeImg" : "dimmer",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "26"
Do you see an option to give dim levels between 0 and 100% for this device (and 0-16 for the device for which it has been developed by you)
Based on maxdimlevel?
ah... and compliments!! Nice dashboard!
Just fixed this in the latest release.
Backup your old version of the dashboard because I changed more stuff.
EdwinK
Post by EdwinK »
Great. HAving some problems with the stop/pause buttons.
robgeerts
Post by robgeerts »
EdKo66 wrote: Great. HAving some problems with the stop/pause buttons.
What problems?
EdwinK
Post by EdwinK »
Both forward and rewind brings me to start of the song. Stop and pause don't seem to work at all.
They do when I just enter the command on the browserbar.
I'm going to check the log files to see if there is something happening there.
EdwinK
Post by EdwinK »
BTW, this is how it looks with two players
robgeerts
Post by robgeerts »
In the latest version it only shows one title!
Whats the Status of the second music player?
l00pz
Post by l00pz »
Wow, nice addition for the Logitech Media Server. Is it also possible to add Sonos to this? This is the Information for the Python Media Player Plugin of Sonos
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 0,
         "CustomImage" : 127,
         "Data" : "",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 69,
         "HardwareName" : "Sonos Kitchen",
         "HardwareType" : "Sonos Players",
         "HardwareTypeVal" : 94,
         "ID" : "0000045",
         "Image" : "Sub",
         "LastUpdate" : "2017-03-30 10:35:41",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "Sonos Kitchen",
         "PlanID" : "6",
         "PlanIDs" : [ 6, 23 ],
         "SignalLevel" : 0,
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "Media Player",
         "SwitchTypeVal" : 17,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "Media",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "1141"
EdwinK
Post by EdwinK »
robgeerts wrote:In the latest version it only shows one title!
It is playing now. When I took the screenshot I had it turned off.
robgeerts
Post by robgeerts »
l00pz wrote:Wow, nice addition for the Logitech Media Server. Is it also possible to add Sonos to this? This is the Information for the Python Media Player Plugin of Sonos
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 0,
         "Data" : "",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 69,
         "ID" : "0000045",
         "Image" : "Sub",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "PlanID" : "6",
         "SignalLevel" : 0,
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "1141"
Should not be a problem but can you send my wich url's it calls when you press a button (play,pause,stop,rewind,forward) ?
And when a song is played, does it enter the songname in Data in the output?
l00pz
Post by l00pz »
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 0,
         "Data" : "",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 69,
         "ID" : "0000045",
         "Image" : "Sub",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "PlanID" : "6",
         "SignalLevel" : 0,
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "1141"
At this time it's only possible to turn on and off the device, so the options are limited ;) As for the song, it's indeed put in the Data output. So a "Current Playing" button or something would be awesome :D
robgeerts
Post by robgeerts »
Pull the latest version :)
pvm
Domoticz version: 4.10538
Post by pvm »
Nice to have the controls also integrated. I'll implement it in my setup this evening.
I wonder whether the buttons are large enough on my tablet.... Let's check
EdwinK
Post by EdwinK »
Quick responses from Rob Geerts. :)
l00pz
Post by l00pz »
robgeerts wrote:Pull the latest version :)
Thanks! I only have one question, at the moment the volume is also added as an information box, is it possible to ignore these?
Another problem I have is that on my Android Tablet which I use on the wall the buttons are not visible. Are there more people with this problem? I tried it in Firefox, Chrome en FullScreenbrowser (also in Incognito Mode). On my Desktop the Website is looking fine.
PS, this is the output of a Volume Slider
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 0,
         "CustomImage" : 8,
         "Data" : "Set Level: 17 %",
         "Description" : "",
         "Favorite" : 0,
         "HardwareID" : 69,
         "ID" : "0000045",
         "Image" : "Speaker",
         "LastUpdate" : "2017-03-30 13:55:32",
         "Level" : 17,
         "LevelInt" : 17,
         "Name" : "Sonos Kitchen - Volume",
         "PlanID" : "6",
         "SignalLevel" : 0,
         "Status" : "Set Level: 17 %",
         "StrParam1" : "",
         "StrParam2" : "",
         "Timers" : "false",
         "Unit" : 2,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "1142"
robgeerts
Post by robgeerts »
Change
if(data.result[r]['HardwareType']=='Sonos Players'){
TO:
if(data.result[r]['HardwareType']=='Sonos Players' && data.result[r]['SwitchType'] == 'Media Player'){
Could you send me a photo of your tablet so I can see the problem of the buttons?
robgeerts
Post by robgeerts »
EdKo66 wrote:Both forward and rewind brings me to start of the song. Stop and pause don't seem to work at all.
Sorry made one mistake...
change, in main.js, the following:
$.ajax({
		url: _HOST_DOMOTICZ+'/json.htm?type=command&param=lmsmediacommand&idx='+idx+'&action=Rewind&jsoncallback=?',
		type: 'GET',async: true,contentType: "application/json",dataType: 'jsonp',
		success: function(data) {
to
$.ajax({
		url: _HOST_DOMOTICZ+'/json.htm?type=command&param=lmsmediacommand&idx='+idx+'&action='+action+'&jsoncallback=?',
l00pz
Post by l00pz »
robgeerts wrote:Change
TO:
Thanks! I changed the main.js File and this is working now. Regarding the buttons, this is my Tablet. As browser I use FullScreenBrowser, but other Browsers like Firefox and Chrome do the same. If I use an old version, the buttons work.
EdwinK
Post by EdwinK »
Decided to do it the easy way and just downloaded main.js again
Locked
