I have bought a few PIRs from AliExpress. But I think I bought a different one than the ones you're using, since I can't find any DIP switch/short wire holes on the print.
When there is motion detected, the blue LED comes up but most of the times no 433 MHz message is being send.
Any help would be nice.
And in RFXmngr I also see that the PIR sends messages with different IDs
28-3-2017 16:25:29
28-3-2017 16:25:29
Packettype = Lighting4
subtype = PT2262
Sequence nbr = 8
Code = EA9EBA decimal:15376058
S1- S24 = 1110 1010 1001 1110 1011 1010
Pulse = 477 usec
Signal level = 7 -64dBm
28-3-2017 16:25:55
28-3-2017 16:25:55
subtype = PT2262
Sequence nbr = 9
Code = 6A9EBA decimal:6987450
S1- S24 = 0110 1010 1001 1110 1011 1010
Pulse = 479 usec
28-3-2017 16:27:52
28-3-2017 16:27:52
subtype = PT2262
Sequence nbr = 10
Pulse = 477 usec
28-3-2017 16:29:11
28-3-2017 16:29:11
subtype = PT2262
Sequence nbr = 11
Pulse = 479 usec
28-3-2017 16:29:58
28-3-2017 16:29:58
subtype = PT2262
Sequence nbr = 12
Pulse = 472 usec
Signal level = 5 -80dBm
28-3-2017 16:30:20
28-3-2017 16:30:20
subtype = PT2262
Sequence nbr = 13
Pulse = 477 usec
28-3-2017 16:30:29
28-3-2017 16:30:29
subtype = PT2262
Sequence nbr = 14
Pulse = 479 usec
28-3-2017 16:30:47
28-3-2017 16:30:47
subtype = PT2262
Sequence nbr = 15
Pulse = 477 usec
Signal level = 6 -72dBm
