Domoboard - General Discussions
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
- EdwinK
- Domoticz version: BETA
Re: Domoboard - General Discussions
Dont' have systemd/ in my Synology
- Domoticz version: 3.5837
perhaps than with screen ?EdKo66 wrote:Dont' have systemd/ in my Synology
Thank you very much for the information. I really like the interface and the possibilities!squandor wrote:
Hi jjnj,
It's looking greatunfortunately the scrolling is an temporary bug so the menu can be scrolled on mobile devices. We will try to fix the menu scrolling bug so that the unnecessary scrolling of the page can be disabled again
- EdwinK
Not there either. I'm on Synology, so maybe they have different commands.squandor wrote:perhaps than with screen ?EdKo66 wrote:Dont' have systemd/ in my Synology
EdKo66 wrote:Not there either. I'm on Synology, so maybe they have different commands.squandor wrote:perhaps than with screen ?EdKo66 wrote:Dont' have systemd/ in my Synology
I do not have such complicated setup for Synology to keep the service running (yet). I found that if I kick of the service in debug mode it keeps running when I close the ssh session.
Drawback is that when the Synology Goes down the service needs to be restarted.
Debug mode is described somewhere in this forum thread.
- EdwinK
Going to try that. Thanx
Same problem
Same problem
two Domoticz temp graph results into an error where domoboard tries to merge values:
Also is it possible to disable the percentage pop-up for the sliders? I'm touching on the percentage of the slider below the slider i want to change
[history]
[[display_components]]
components = domoticz_temp_charts[Woonkamer], domoticz_temp_charts[Buiten]
[[domoticz_temp_charts]]
[[[Woonkamer]]]
Woonkamer = 1025, month, temp
[[[Buiten]]]
Buiten = 1036, month, temp
- Domoticz version: v3.8742
I have a problem with the sync between Domoticz and Domoboard
If I change a switch in Domoticz GUI it doesn't change in Domoboard dashboard
The opposite works perferctly fine
Any clues?
Any clues?
- Domoticz version: 4.10717
Hi jjnj,jjnj wrote:two Domoticz temp graph results into an error where domoboard tries to merge values:Code: Select all
[history] [[display_components]] components = domoticz_temp_charts[Woonkamer], domoticz_temp_charts[Buiten] [[domoticz_temp_charts]] [[[Woonkamer]]] Woonkamer = 1025, month, temp [[[Buiten]]] Buiten = 1036, month, temp
i got the same error with two of the same graphs on the same page. unfortunately there is, as squandor mentioned, no solution for this at the moment. a new version might be on its way which might have the solution to combine graphs, which might do the trick. I am also really looking forward having this possibility. anyway way big thanks for the team for considering this as a possible new feature.
Cheers
Hi Miljume,miljume wrote:Hello,
Any clues?
It could take a moment for the buttons to change. We used an timer to update the buttons because we didn't want to blow up the domoticz server by unlimited pulls
Thanks but something strange is going on,the swith is always going back to "On" when i refresh the page in Domoboard even if the connected switch in Domoticz is "Off"squandor wrote:Hi Miljume,miljume wrote:Hello,
Any clues?
If I change the swithc to "Off" again in Domoboard and refresh the page it reverts back to "On" immediately
The sync between Domoticz to Domoboard must be broken, no matter how long I wait the swith stays in "On" position in DOmoboard
And did you get an error in the console.log?miljume wrote:Thanks but something strange is going on,the swith is always going back to "On" when i refresh the page in Domoboard even if the connected switch in Domoticz is "Off"squandor wrote:Hi Miljume,miljume wrote:Hello,
Any clues?
Sorry but where do I find console.log?squandor wrote:And did you get an error in the console.log?miljume wrote:Thanks but something strange is going on,the swith is always going back to "On" when i refresh the page in Domoboard even if the connected switch in Domoticz is "Off"squandor wrote: Hi Miljume,
In chrome you can use right mouse click on the page and then choose inspectmiljume wrote:Sorry but where do I find console.log?squandor wrote:And did you get an error in the console.log?miljume wrote:
OK, seems to have an error theresquandor wrote:In chrome you can use right mouse click on the page and then choose inspectmiljume wrote:Sorry but where do I find console.log?squandor wrote: And did you get an error in the console.log?
Uncaught TypeError: Cannot read property '0' of undefined
at domoboard.js:93
at Object.success (domoboard.js:9)
at i (jquery-3.1.0.min.js:2)
at Object.fireWith [as resolveWith] (jquery-3.1.0.min.js:2)
at A (jquery-3.1.0.min.js:4)
at XMLHttpRequest.<anonymous> (jquery-3.1.0.min.js:4)
well that's you're problem but the question is where is it coming from. It seems that you're connection between domoboard en domoticz isn't flaweless. Do you have authentication enabled in domoticz?miljume wrote:OK, seems to have an error theresquandor wrote:In chrome you can use right mouse click on the page and then choose inspectmiljume wrote:
Keeps popping up with a regular frequencyCode: Select all
Uncaught TypeError: Cannot read property '0' of undefined at domoboard.js:93 at Object.success (domoboard.js:9) at i (jquery-3.1.0.min.js:2) at Object.fireWith [as resolveWith] (jquery-3.1.0.min.js:2) at A (jquery-3.1.0.min.js:4) at XMLHttpRequest.<anonymous> (jquery-3.1.0.min.js:4)
Yes, I have authentication enabled but not for local IP adresses and the Domoboard is on the same RPI so that shouldnt be the problem
I did a git pull from the development branch so I am on the latest development version
Could you send the [general_settings] part of the config so we can see if the problem is in there.miljume wrote:Yes, I have authentication enabled but not for local IP adresses and the Domoboard is on the same RPI so that shouldnt be the problem
Sure, see belowsquandor wrote:Could you send the [general_settings] part of the config so we can see if the problem is in there.miljume wrote:Yes, I have authentication enabled but not for local IP adresses and the Domoboard is on the same RPI so that shouldnt be the problem
I guess the username/password part for Domoticz isn't needed when I have excluded login for local IP's?
[general_settings]
[[server]]
url = 192.168.0.51:8081 # IP-address of Domoticz backend
flask_url = 192.168.0.51:8090 # Please note: this is the internal IP-address including port of the Domoboard server
user = username # Username for Domoticz (if required)
password = password # Password for Domoticz (if required)
secret_key = <secret key> # A random secret key used for Python authentication. Change to anything random.
[[users]]
user1 = password1 # Add users for Domoboard here. In this case login with username "username" and password "password"
user2 = password2
[[domoboard]]
time = True # True/False: show time in top bar
date = True # True/False: show date in top bar
language = "sv" # Change this to display date/time in local language and format
#google_maps_api_key = <api key> # Google Maps Embed API key
autologon = True # True/False: enable autologon
[[wunderground]]
api = <api key>
language = en
you could try that to make sure that it's not needed and also set something in the secret key to make sure that all the possibility's are filled in. beside that you could try to set the url to url = 127.0.0.1:8081miljume wrote:Sure, see belowsquandor wrote:Could you send the [general_settings] part of the config so we can see if the problem is in there.miljume wrote:Yes, I have authentication enabled but not for local IP adresses and the Domoboard is on the same RPI so that shouldnt be the problem
[general_settings] [[server]] url = 192.168.0.51:8081 # IP-address of Domoticz backend flask_url = 192.168.0.51:8090 # Please note: this is the internal IP-address including port of the Domoboard server user = username # Username for Domoticz (if required) password = password # Password for Domoticz (if required) secret_key = <secret key> # A random secret key used for Python authentication. Change to anything random. [[users]] user1 = password1 # Add users for Domoboard here. In this case login with username "username" and password "password" user2 = password2 [[domoboard]] time = True # True/False: show time in top bar date = True # True/False: show date in top bar language = "sv" # Change this to display date/time in local language and format #google_maps_api_key = <api key> # Google Maps Embed API key autologon = True # True/False: enable autologon [[wunderground]] api = <api key> language = en
