When I hit an issue or bug with Domoticz, I always want to find the solution myself, before opening a new topic. However, the search is so dramatically bad it usually drives me mad and I can't find what I'm looking for.
For example. I wanted to list all topics about somfy RTS, or all topics where the RFY or RFY-2 command is used. But I can't. RTS and RFY are too short and RFY-2 contains - and is als ignored. These are just example, in general, a LOT of searches contain very important 3 letter keywords that are just ignored.
I'm always scared to hit into domoticz issues because I know the information is probably around but impossible to find. I'm not trying to be mean, just curious if there are any plans to update this?
Search on this forum is so frustrating Topic is solved
Nautilus
Re: Search on this forum is so frustrating
Agreed. Usually a good workaround (for me at least) is to use google to search the forum...
- jvdz
- Domoticz version: 4.107
Simply go to google and type:
site:domoticz.com whatever you want to search for
Jos
edit: see I am not the only one using this
Jos
markjgabb
- Domoticz version: 3.8153
+1jvdz wrote:Simply go to google and type:
this is the best method
V 2020.2 RPI 3
RFlink 334 mhz
mysensors
broadlink
Mirabella Genio Globes
RFlink 334 mhz
mysensors
broadlink
