I'm having a problem with one of my blocky events. I suspect I've got a fundamental misunderstanding of the way it works. Maybe someone can help me?
Essentially, I want some logic as follows:
If SwitchA = 1 and SwitchB = 1, set SwitchB to 2.
Else if Switch A = 1 and Switch B =2, set SwitchB to 3.
I have implemented this in Blocky but if I then set Switch A to 1 and Switch B to 1, Switch B changes to 3 whereas I would expect it to be 2.
From the log, I can see that what is happening is that the first part is running (and Switch B is set to 2) and then the event is immediately triggered again and this time the second part is applied and Switch B is set to 3.
Can anyone give me any tips?
Help with Else If logic
- sisaenkov
- Domoticz version: 3.8
Re: Help with Else If logic
This works as expected. All is correct and meets the conditions.
What do you want to do?
gavacac
Without going into loads of detail, when Switch A is set to 1 for the first time, I want to set Switch B to 2. When Switch A is set to 1 for the second time, I want to set Switch B to 3.
- emme
- Domoticz version: latest
you want a toggle button.....
try this:
the first block is a simple IF
the inner block is a IF/else block
(they are different
try this:
If SwitchA = 1 then
If SwitchB = 2 then
SwitchB = 0
SwitchC = 3
SwitchB = 2
SwitchC = 0the inner block is a IF/else block
(they are different
"We always done this way"
- sisaenkov
Also you can use a variable.
If SwitchA == 1 and SwitchB == 1 and Var == 0 then
SwitchA = 0
SwitchB = 2
Var = 1
elseif SwitchA == 1 and SwitchB == 2 and Var == 1 then
SwitchA = 0
SwitchB = 3
Var = 1
It's all depends on your detailed conditions.
SwitchA = 0
SwitchB = 2
Var = 1
SwitchA = 0
SwitchB = 3
Var = 1
jannl
- Domoticz version: 2026.1.x
I think blockly is the problem in this case, try with lua.
gavacac
I managed to get it to work with a variable. Thanks for the suggestions.
Spitfire
Domoticz blocky 'else if' handling is broken. Nothing should be run after a condition has been true.
